Left Side Fog Light Not Working Help.
Discussion in 'Technical Chat' started by mike92y, Jan 3, 2017.
  1. Jan 3, 2017 at 6:28 AM
    mike92y
    mike92y [OP] Well-Known Member
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    OME all around. SPC UCA. This and that.
    My Left side Fog light is not working. Any advice would help. Below I listed what I have done to trouble shoot this. I am not sure what to do at this point.
    1. Bought new light still did not work.
    2. Swapped out right side light (working light) with left side still no love.
    3. Left side light works in right side.
    4. Ohm Meter only registering .036 Volts Left side. I get 12 volts right side.
    5. Stuck Needles in Wires to see if the plug is the problem. Still only .036 volts
    6. Swapped out relay in fuse box (making sure swapped relay had same part #). Still no light.
    Do you think the switch in the cab is the issue?
