left side sag
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoma2002, Feb 11, 2010.
  1. Feb 11, 2010 at 4:37 PM
    tacoma2002
    tacoma2002 [OP] Member
    Pacific Northwest
    Tacoma 4x4 TRD
    2.5" OME suspension lift 3" body lift canopy fog lights/brush guard
    My 3" body-lifted 2002 Tacoma is sagging 3/4" to the left. Les Schwab says the leaf springs are old and it needs an AAL. My mechanic says it needs new struts. Both contradict one another. The truck looks weird leaning to the left. Anyone ever had this problem?
  2. Feb 11, 2010 at 4:38 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    it's because you, your gas tank, and your battery all sit on the left side
  3. Feb 11, 2010 at 4:42 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
  4. Feb 11, 2010 at 4:50 PM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
  5. Feb 11, 2010 at 4:50 PM
    Flynn Diesel
    Flynn Diesel Well-Known Member
    Phoenix, AZ
    2010 PreRunner SR5 Double Cab
    •BFG AT KO 285/70/17, XD Addict 17x9, Light Racing UCA’s, Billstein 5100’s, OME 885’s, Toytec AAL, Seat Belt warning disable, Grill Craft Black MX Upper & Lower Grill, VisionX 55/65 watt xenon Low/High Beam lights. FOG Light only Mod. Tailgate theft prevention mod. Wet Okole armrest mod. Redline Hood Struts, Weathertech floor liners. AMP Bed Extender. Wet Okole Seat Covers. Pioneer P4200DVD
    X2 :cheers:
  6. Feb 11, 2010 at 4:53 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    you just have to loose a good 200#, or make your passenger gain 200#
  7. Feb 11, 2010 at 4:57 PM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    on my first gen i broke a leaf spring,and it did the same thing. Had a crack that was hidden inside the pack.
  8. Feb 11, 2010 at 5:00 PM
    Jason'sLawnCare
    No preference just what ever will fit and make it level. The description to the ome spacer says it will only fit the ome shocks so I don't know if it will work with his. I just linked that one to show the op it's a common problem and there's an easy/cheap fix for it.
  9. Feb 11, 2010 at 5:27 PM
    tacoma2002
    Pacific Northwest
    Tacoma 4x4 TRD
    So, when you replaced the leaf springs did the truck level out?
  10. Feb 12, 2010 at 8:35 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    yes. is the sag just in the rear?
  11. Feb 12, 2010 at 10:02 PM
    tacoma2002
    Pacific Northwest
    Tacoma 4x4 TRD
    Here is an FYI for folks... So, after lots of research and talking to different people, the local 4x4 shop found that my sway bar/stabilizer bar is bent causing the truck's 1" lean to the left side. I must have beaten my truck a little too hard. Not a terribly expensive fix. Was quoted $150 for the part plus labor. I just didn't think the "taco lean" theory held water. A full tank of gas wouldn't pull the truck down 1 inch. Anyhow please respond with your thoughts...
  12. Feb 13, 2010 at 5:43 PM
    Jason'sLawnCare
    Yeah I think one inch is too much taco lean. haha. But it is a common problem post lift.
  13. Apr 28, 2010 at 6:40 AM
    ywen
    ywen Well-Known Member
    Damn I have 1/2" lean on the driver side. How much spacer do I need to correct 1/2" ?
  14. Apr 28, 2010 at 9:35 AM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    1/4": Toytec sells a 1/4" spacer and is supposed to add 1/2" to correct drivers side lean
