Left side valve cover cracked can't find new one *help*
Discussion in 'Technical Chat' started by KalamaKid, Dec 20, 2011.
  1. Dec 20, 2011 at 3:09 PM
    KalamaKid
    KalamaKid [OP] Well-Known Member
    Oregon
    same shit as everyone else
    I'm helping some family in Houston Texas fix up a broken down T-100. It has the 5VZ-FE engine (same as Tacoma/4-runner) and it needs a new valve cover. Someone in the past over torqued the bolt just forward of the oil filler plug and now the cover has cracked all the way through and is spitting out oil. I called every junk yard in town and none have a "good" part to replace this with. I called NAPA and they can't even find a part number for it. I just put some RTV around the broken piece and bolted it up :eek:, but if this doesn't work where and how can I find one quick without going to a stealership? (this truck has 300,000 miles and on its 8th life)
    Thanks! :)
  2. Dec 20, 2011 at 3:19 PM
    KalamaKid
    Oregon
    ttora says (your fucked if your break it) :(
  3. Dec 20, 2011 at 6:43 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Find a welding shop and ask if they can fix it.
    Wouldn't be a job for an amateur, but if it's just a crack a professional should be able to weld it up without warping the cover.
  4. Dec 20, 2011 at 8:45 PM
    KalamaKid
    Oregon
    Welding would probably work but it would be a last ditch effort.
    TTT
  5. Dec 20, 2011 at 8:51 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
  6. Dec 20, 2011 at 9:13 PM
    KalamaKid
    Oregon
  7. Dec 20, 2011 at 9:24 PM
    KalamaKid
    Oregon
    If the JB weld doesn't hold up for the next two days i'll pull the trigger on those Egay ones. +1 for you sir
  8. Dec 20, 2011 at 9:30 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    how about rancho truck parts?
  9. Dec 20, 2011 at 11:57 PM
    KalamaKid
    Oregon
    Them and a few other places won't sell just one valve cover. I need to buy the head or larger assembly.
    Also found out not all 5vz valve covers are the same as Toyota added coil packs a few years down the road. Merry Christmas!!!
  10. Dec 21, 2011 at 4:54 AM
    NelsonTacoma
    Tucson, AZ
    Always happy to help. Let us know how the JB weld hold up. :D:D
  11. Dec 23, 2011 at 11:56 AM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    JB Weld for a temporary (or long term) fix. I've seen it done on race quads.
  12. Dec 26, 2011 at 5:39 PM
    Mr Texas
    Mr Texas Member
    Nick
    Ventura
    99 TRD PreRunner 4x4
    Magnaflow Exhaust
    I just cracked mine in the same place, I guess they werent kidding about the 53 in lbs. I was trying to tighten mine to stop it seeping oil on my exhaust crossover. I found this website for new covers, a lot cheaper than ebay, under $200.
    http://www.toyota-parts-dealer.com/
    Im gonna see if JB weld will hold too before replacing it.
