Left Turn Signal - Fask blinking - Nothing burned out.
Discussion in '1st Gen. Tacomas (1995-2004)' started by lougar, Feb 18, 2016.
  1. Feb 18, 2016 at 6:57 AM
    lougar
    lougar [OP] Member
    Luis
    Mobile, AL
    18 Silver Tacoma TRD 4x4 Offroad. Crawl & MTS. 06 Blue TRD Tacoma Sport 4x4.
    My 01 Prerunner left turn signal is fast blinking, about 4 times faster than the right side. I've replaced the bulbs front and back(although they were both working), but still has the same fast blinking problem. They work...but it's annoying to say the least. I've traced the wires and nothing looks pinched or grounded. I would think if the flasher relay was the problem, it would be doing it on both sides since there's only one relay, correct?
    Any ideas what to look for next would be appreciated.
  2. Feb 18, 2016 at 3:48 PM
    1988Mercedes
    1988Mercedes Well-Known Member
    CHARLES
    ARKANSAS
    2020 AG PRO MT
    Change all left side to the right and right to left and see if your issue moves. I had the same issue and found a bulb problem that would light. I can see where a incorrect watt bulb would cause the issue. Don't overlook a short in the trailer plug wiring. Beyond that, I would throw a flasher at it.
  3. Feb 18, 2016 at 3:50 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    You didn't check your fuses?
  4. Feb 18, 2016 at 10:01 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    mechanical flashers work off resistance. if you have smaller bulbs, more power gets to the flashers and makes them blink faster. nearly burned bulbs will also mimic this effect! you should also check to see if any of your bulbs are shorting inside the socket. possible. did you put in any LED lights recently? they will cause this.
    if everything seems fine you should be able to switch your flasher to an electronic flasher, it will keep the standard speed no matter what happens.
  5. Feb 19, 2016 at 7:20 AM
    lougar
    lougar [OP] Member
    Luis
    Mobile, AL
    Thanks for the replies. I will try swapping sides to see if the problem moves. If that doesn't change change, I like the electronic flasher idea.
  6. Feb 19, 2016 at 7:21 AM
    lougar
    lougar [OP] Member
    Luis
    Mobile, AL
    I did check the fuses, and all are good.
  7. Feb 22, 2016 at 11:25 AM
    lougar
    lougar [OP] Member
    Luis
    Mobile, AL
    Swapped the bulbs, but no change. I will purchase the electronic flasher next and replace the one that's there. From looking at other threads, the EP-35 by Tridon or Novita is the one to go with. I checked with my local auto zone and they do carry it. Hopefully, that will fix the hyperblink problem.
  8. Feb 22, 2016 at 11:59 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Do you happen to have a trailer wiring harness installed on your truck?
  9. Feb 22, 2016 at 12:06 PM
    lougar
    lougar [OP] Member
    Luis
    Mobile, AL
    Not on this one. I looked under the bumper and it does not look like it was ever wired for trailer lights.
  10. Feb 23, 2016 at 6:02 AM
    lougar
    lougar [OP] Member
    Luis
    Mobile, AL
    Thanks for the all the inputs on this issue. The EP-35 Electronic flasher did the trick. No more hyperblinking.
    tgtech570 likes this.
  11. Feb 23, 2016 at 5:26 PM
    CodeSeven
    Serge.
    Coachella Valley
    where was your flasher located? ill be needing to do this soon.
  12. Feb 25, 2016 at 6:32 AM
    lougar
    lougar [OP] Member
    Luis
    Mobile, AL
    Flasher is attached to the back of the interior fuse block. You have to remove the panel under the steering column to get to it.
