Left turn signal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kahuna757, Jun 2, 2022.
  1. Jun 2, 2022 at 2:02 PM
    kahuna757
    kahuna757 [OP] New Member
    Front turn signal doesn't flash. Swapped bulbs and did not fix the problem. running light is out but when you put all the lights on it works. Any idea why the signal flasher isnt working? Its a 2015 Tacoma
  2. Jun 2, 2022 at 3:31 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Does it flash with the emergency Hazard switch?
    Are you sure you have it plugged in completely?
    Have you checked for voltage at the socket with the turn signal on?
    Dm93 and Geeves77 like this.
  3. Jun 3, 2022 at 2:25 PM
    kahuna757
    yep plugged in
    good volts
    doesn't flash with the hazards
    Thinking its the flasher box???
  4. Jun 3, 2022 at 2:31 PM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    If the light works, and it's simply not flashing, that sounds like a relay issue.
  5. Jun 3, 2022 at 3:43 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Try another bulb first, or look at the one you installed and make sure the element is complete.
    Also, you have to push pretty hard to make sure they are snapped into the socket. I'd recommend wearing a mechanics glove or leather glove on that hand when you verify. I was surprised how hard I had to push when I replaced mine last year.
    kools likes this.
  6. Jun 4, 2022 at 1:55 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    If you get voltage at the socket with the turn signal on and it doesn't blink it is most likely the flasher unit.
  7. Sep 29, 2022 at 6:24 PM
    kools
    kools Member
    DFW
    2012 DCSB TRD Sport
    to add to this thread...
    my 2012 left turn signal started rapidly flashing the other day. figured the bulb was bad. bought a new bulb and it still did it. However, if I press and hold the socket in to the bulb it starts working correctly. I hear and feel it snap into place but its like its just not getting a good connection. Should I use an anti-corrosion spray on it? Or what is the fix for this?
    Stock bulbs.
    I hope this is similar or the same issue OP is having, otherwise my apologies.
  8. Sep 30, 2022 at 10:56 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    High resistance connection between the bulb and the socket terminals causes rapid blinking. The truck thinks the bulb is blown. Either it isn't in completely, you have a defective socket or the incorrect type bulb. In that order of likelyhood.
    Too Stroked and TnShooter like this.
  9. Sep 30, 2022 at 11:08 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Inspect the socket for corrosion :notsure: If you see corrosion, you'd need to clean it up with a small file or sandpaper, then hose it down with Dexoit spray.
    If you don't see corrosion, the fingers in the bulb may be too spread out due to age. Simple enough to use a pocket screwdriver to pry them closer. I had to do this with my 3rd brake light bulbs when I replaced the LEDs in 2018.
  10. Sep 30, 2022 at 12:48 PM
    kools
    kools Member
    DFW
    2012 DCSB TRD Sport
    ok thanks. the bulb in it now is brand new. I threw the old one away. so it has to be something with the plug. unless the bulb is the wrong bulb
  11. Sep 30, 2022 at 1:29 PM
    kools
    kools Member
    DFW
    2012 DCSB TRD Sport
    Welp. I went to check the bulb and it came out really easily. I didn’t push the bulb into the adaptor housing tight enough until it clicked. Now it works. carry on. Nothing to see here.
    Jimmyh and winkel like this.
  12. Sep 30, 2022 at 2:16 PM
    winkel
    Corydon, IN
    Glad you got it figured out! Thanks for circling back.
  13. Sep 30, 2022 at 2:20 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yeah those take some force to get them fully inserted.
