Lefty's golden taco.
Discussion in '1st Gen. Builds (1995-2004)' started by chrslefty, Aug 25, 2018.
  1. Mar 20, 2020 at 6:46 AM
    #141
    Phessor
    Phessor Well-Known Member
    Your rig is looking good. I ordered some Diode Dynamics fog lights for my ARB.
    chrslefty[OP] likes this.
  2. Mar 20, 2020 at 6:51 AM
    #142
    chrslefty
    chrslefty [OP] Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Nice I've seen some really good reviews on those. Did you get the pro or sae?
  3. Mar 20, 2020 at 10:09 AM
    #143
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Yea I like how yours turned out. I did think about doing a tiregate a while back. I started building one very similar to @Fuergrissa's, but ended up ditching the idea because I realized that I use my tailgate too much as a platform and didn't wanna eliminate it.
    chrslefty[QUOTED][OP] likes this.
  4. Mar 20, 2020 at 11:10 AM
    #144
    Phessor
    Just the SAE's
  5. Apr 8, 2020 at 11:57 PM
    #145
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    So I've done just a few little things here and there.
    Fixed the stereo. Well I grounded out the parking brake wires. In stalled the microphone. Put in a correct front facing cam.
    Got a couple of trim bits
    Tryed to clean up a little bit of the wiring.
    Instaled some splash gards.
    Relocated/put in new washer bottle.
    So I no longer have any lights on the dash, for the moment.
    So a quick look under at the bussman while I was trying to clean up the wires.
    The new washerbottel. I got the idea off a member here. Seams to work well enough.
    The splash gards. I had to cut them to work with the upper control arm braces.
    Phessor likes this.
  6. Apr 21, 2020 at 8:04 PM
    #146
    betterbuckleup
    Ian
    Concord, CA
    Hey Chris, do you think you could possibly grab some pictures of parts of your swingout for me?
    I like how yours turned out and I'm looking into doing one on mine. I'm curious on how your hinge and latch are setup on either end.
    We have pretty much the same rear bumper, but mine just has a step platform on either side.
  7. Apr 23, 2020 at 1:21 AM
    #147
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    What angle are you wanting to see?
    The actual swing out has a bend in it to fit the contours of the bumper.
    Phessor likes this.
  8. Apr 23, 2020 at 6:15 AM
    #148
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Is that a hydraulic support on the swing out?
  9. Apr 23, 2020 at 7:43 AM
    #149
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Yeah its pretty sweet. Itll hold it open on a hill.
  10. Apr 23, 2020 at 6:26 PM
    #150
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    pic of mounting details plz! I could use that upgrade for my swing out
  11. Apr 23, 2020 at 8:48 PM
    #151
    betterbuckleup
    Ian
    Concord, CA
    Thanks, that's helpful. I was curious on what kind of gusseting/mounting was done on either side to mount the hinge and latch since there isn't much to mount off of other than the tube.
  12. Apr 23, 2020 at 9:18 PM
    #152
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Yeah,not a lot there for sure. But it seems to be pretty solid. It helps that there is a tube the going back to the frame from the bottom. I can get some better pics in the morning if there's a specific angle that you wanna see.
  13. Apr 23, 2020 at 9:20 PM
    #153
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    I'll get it for you in the morning. Your more than welcome to stop by and look at it. I need to get that quote from you anyways.
  14. Apr 23, 2020 at 9:34 PM
    #154
    betterbuckleup
    Ian
    Concord, CA
    Yea I was just curious to see what a professional shop did to solidly mount the hinge and latch in that space on either side.
    Maybe a closer pic of the hinge where you can see how it was welded to the bumper and the backside kinda? Appreciate it!
    When you swing it all the way out, is there any significant flex from the hinge on the bumper or around that area?
    Do you have to manually lift it at all when you swing it closed to get it to line up, or is there a sort of guide plate to put it in position for latching?
  15. Apr 23, 2020 at 10:13 PM
    #155
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    There's a plate. I believe.it just goes into position. Its pretty solid I don't believe that there's any flex.but I haven't really tried to get it to move. I think I did when I first got it. Ill get a video in the morning with pictures to show it.
    betterbuckleup likes this.
  16. Apr 23, 2020 at 10:18 PM
    #156
    betterbuckleup
    Ian
    Concord, CA
    Thanks. Most everyone that adds a swingout to even a plate bumper has to add reinforcements behind the hinge point because of the flex. Curious how that plays out with our tube bumpers. :thumbsup:
  17. Apr 24, 2020 at 9:24 AM
    #157
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Here's the pic's and video. It looked like the whole rear corner of the bumper was moving. Sorry I did the best I could buy myself.
    https://youtu.be/sDjvW0Nrqfk
    20200424_090857.jpg 20200424_090925.jpg 20200424_090937.jpg 20200424_090942.jpg 20200424_091104.jpg 20200424_091119.jpg 20200424_091128.jpg
    betterbuckleup and Ace115 like this.
  18. Apr 24, 2020 at 3:02 PM
    #158
    betterbuckleup
    Ian
    Concord, CA
    Damn that thing is beefy! Thanks for the pics.
    Didn't know there was that much tube work behind the mounting of all of that. Whoever made it did a killer job.
    Also that's a thick ass piece of metal used to mount the tube to the hinge, at least it looks solid. More than likely he sleeved the holes and used plate. That would be my guess, but again: impressive fab work.
    As for the deflection, doesn't look to be too bad actually. Stronger than I thought. Not like you're gonna be doing pull ups on it either so no doubt it'll stay together.
    If you don't mind me asking, how much did the fab work of all that run you?
  19. Apr 24, 2020 at 5:46 PM
    #159
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Thanks I think they did a great job. I wanna say it was like 700 for the swing out and the work on the front bumper.
    Avid offroad. In mesa az.
    https://avidoffroad.com/cart/index.php
    They've done all of the fab work on my truck.
    Front bumper hoop
    Rear swing out
    Sliders.
    Rear frame plates
    Coil bucket gussets
    Stering knuckle braces.
    Reinforced lower skid mounts.
    Bed rack work. I think it was made in there shop not sure.
  20. Apr 24, 2020 at 5:50 PM
    #160
    betterbuckleup
    Ian
    Concord, CA
    Pretty reasonable for all the work that went into it, id say
    I'll have to check them out if i'm ever in the area.
