legally driving without side mirrors?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tonymhouts, Jul 18, 2014.
  1. Jul 18, 2014 at 8:29 AM
    tonymhouts
    tonymhouts [OP] Active Member
    Wisconsin
    97 Toyota Tacoma
    low profile front/rear bumper, coil overs, 3 inch lift.
    Last night I got pulled over by a cop for multiple vehicle violations. I plan on fighting them all because its bs, but I am concerned that I might lose on the side mirrors.
    My set up is I took of the doors and put on tube doors. I have seen jeeps run through the city with no doors at all, so most don't have side mirrors, so I took it as I would have no problem either.
    The citation I got essentially states that any vehicle that is manufactured with a left side mirror shall have a left side mirror. But another statute says that as long as I can see 200 feet behind me, I don't need side mirror, but I need a rear view mirror, which I have.
    I am going to go to court about this, was curious as to see if you guys think I'm right or wrong. And if I'm wrong, do you know of any after market side mirrors that I can attach to the frame?
    The other violations I got was my tires sticking out more than 2 inches past the fender (which according to statute, it is measured from the fender to the highest point of the tire, which would be my treads, which seems to be just at 2 inches). And a Tail lamp burnt out, fucker didn't even give me a warning. Probably because he tried to tell me that the manufacturer gave me side mirrors, it wasn't an option, so they are required. I told him that my heater wasn't an option on my truck either, but that's not required.
  2. Jul 18, 2014 at 9:25 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    lol, just put on side mirrors. super easy setup, get ones that can just clamp onto your tube doors. i know some state laws say you have to have doors unless its a vehicle that has a 4-5" lip on the bottom. like a jeep has to keep crap from rolling out.
  3. Jul 18, 2014 at 9:39 AM
    BamaToy1997
    Bill
    Navarre, FL
    I will tell you that most every state will ding you if you don't have at least a driver's side door mirror, if it came from the factory with one. As for the tail lamp, sure it sucks, but they are not required to give you a warning. Then can cite you first time, right off. Your argument about the heater is apples and oranges. Your heater is not a safety device, the mirror is. I know it isn't what you want to hear, but I wouldn't be surprised at all if you lost on all 3 citations. Good luck though! I would suggest getting all 3 issues fixed, then take pictures of it and take them to court. A judge would be more likely to dismiss or reduce the fine if he sees you made an effort to fix the problem.
  4. Jul 19, 2014 at 10:52 AM
    Yarddog
    Yarddog Member
    Vance
    Santa Clarita, CA
    Prerunner TRD Off-Road
    You're a lucky guy to have more time than most folks do...Bama Toy has the right idea. Get 'em fixed...you're gonna waste more time fighting these things cuz you're mad than do the right thing and fix things. OK, you're angry because you think these things were BS, but what we don't know is how YOU handled the traffic stop...I have a feeling that the tail light cite was a result of your attitude! You're right, most cops would warn on that one, not because they're nice guys, but because the likelihood is that you won't fix it and the cop will have PC to stop you in the future!
  5. Jul 19, 2014 at 11:01 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I agree fix the issues then go to court the judge may let you slide.You didn't argue with the cop did you?
  6. Jul 19, 2014 at 11:02 AM
    WThomas1250
    WThomas1250 Well-Known Member
    x2. That's what makes the biggest difference at a traffic stop
    OP, I had a Wrangler for awhile and frequently drive with no side mirrors and never had a problem. But I'm not 100% sure what the law is in my state.
  7. Jul 19, 2014 at 12:13 PM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    You didn't pass the attitude test! All minor violations but still violations.
    I can't imagine any state having a law that permits you drive around without any mirrors, but then I haven't traveled in every state either. Common sense would have to win out on that one. How can you see 200ft behind you while you're driving down the road at freeway speed without the use of a mirror?
    As far as the tires go, I haven't seen a tread that is wider than the sidewall when properly inflated, they buldge out a bit so if one had to measure from the widest part I would measure from the sidewall. You will either have to get fender flares or a different set of tires that are flush with the side of body to satisfy that violation.
    The tail light is a safety violation as well.
    My guess is that this police officer was looking for some reason to stop you and through your own negligence by not having your truck in good repair, he had enough probable cause to do just that.
    If it were me, I'd take my lumps and save the embarassment of trying to fight it in court and the next time check my atittude before I back out of the driveway.
    Good luck, I hope it all works out for you.
  8. Jul 19, 2014 at 12:23 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You should've done your homework and rigged up your modifications to stay legal.
    Here in Pennsylvania...You gotta have side mirrors. You tires can't stick out past the flares, your offroad lights have to be 20" apart, and a shit ton of other things.
    We owned a Jeep and had the doors off all the time, but we bought special mirror mounting brackets that moved the mirrors to mount on the windshield. Not only that, but we got fender flares that were large enough to cover the 35X12.50" tires. Legal and passed inspection every year. It's not that hard.....
  9. Jul 19, 2014 at 12:35 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    ^^ There ya go, Bud. I gotta side with the Janmeister. [​IMG]
  10. Jul 19, 2014 at 2:40 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Op, don't think you can beat these 3 citations. Even motorcycles have to have mirrors now. Tires that go past fenders can fling rocks at vehicles behind. Taillights have to work. Think maybe you got sarcastic and cop didn't give you a break.(heater comment).Most states think the same way with safety issues. Real good advice to fix these things ,photograph them and take to court and be humble. Just an opinion from someone who has been there,done that. GL
  11. Jul 19, 2014 at 3:01 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    never argue with the police--99.99% of the time-you will loose and get additional fines.
    ATTITUDE makes a BIG difference when you get pulled over-DOES NOT MATTER how right or wrong you are.
    Remember-they are there to KEEP you SAFE--not just give out tickets.
    That is their job!!
    NO- I am NOT a COP--just passing along the experience.
    Last THREE times I was pulled over( for various reasons-NO tickets.
    BE NICE--goes a long way!
    Do NOT be an ASS that is always correct.
    I have been BOTH--go with what works.
  12. Jul 19, 2014 at 3:37 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Lot of holier than thou going on here... Cop was looking to prove a point by pulling him over for only safety violations. Nothing better to do apparently. It sucks the OP got tickets for them all, just show up in court and the cop prolly won't show (unless you are in Madison). Just tack a bike mirror on and fix the tail light and call it a day.
  13. Jul 19, 2014 at 3:43 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
  14. Jul 19, 2014 at 3:48 PM
    1993t100
    1993t100 I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    Yeah, just get the problems fixed. Prevents you from getting pulled in the future too. I drove my old t100 without a bumper for almost a year, got pulled over at least 4 times for it. They said that because it came with the truck it needs to be on there. Never got a ticket for it though.
  15. Jul 19, 2014 at 4:00 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    I've been involved with law enforcement since 2000.....volunteering (civy) and I ride a lot with friends...I can tell you attitude and honesty can go a long ways.....obviously, they cannot write you a coupon based on attitude, but they way you conduct yourself can make a difference between a coupon or just a verbal warning....then again, most times, if you have an attitude, but have multiple violations, they may just give you a warning on all of the major things, and write a fix-it cite....just Officer dependent....another thing to take into mind may have a zero tolerance on certain violations (like we all have zero tolerance views on one thing or another) so, you're going to get written anyways...just my .02.....or .03
  16. Jul 19, 2014 at 4:04 PM
    OKJC
    OKJC Well-Known Member
    Justin
    NWArkansas
    '10 SC 4x4 TRD Sport
    I have a restriction on my license stating I must have a left outside side mirror because i'm legally blind in my left eye. That wouldn't be necessary if everyone has to have them, so i'm skeptical. Then again, every state is different i'm sure.
  17. Jul 19, 2014 at 8:16 PM
    WThomas1250
    How do you figure that he "probably won't show"? Most police get all of their tickets lined up so they can go into court one day
  18. Jul 19, 2014 at 8:33 PM
    Andy.G
    Andy
    Virginia
    Hey sean266, they call a ticket coupons in Colorado? Never heard that before. Around here attitude will get you a ticket for everything they can find wrong. I guess living here within 1 hr of D.C. keeps the police on edge. A good attitude works wonders most of the time. Couple yrs ago got pulled over for speeding.(77mph in 55mph). Considered reckless driving because of spd. Cop asked me why I thought he pulled me over and I said because I was speeding. He reduced my spd on ticket to below reckless from my demeanor for sure. I live in a police state with random roadblocks(checks). Guess my whole point is it comes down to the state you live in , and the part of that state you live in. Just a thought.
  19. Jul 19, 2014 at 8:54 PM
    WThomas1250
    Same thing happened to me a couple weeks ago. Politeness (and no record) help a lot. Coulda gotten reckless driving but got "Fail to obey hwy sign" instead
  20. Jul 19, 2014 at 8:55 PM
    T-Rex266
    Elon
    They call it "coupon" in quite a few states...well, from the City standpoint...
