Lehigh Valley Area Clubs
Discussion in 'North East' started by KennyF, Aug 7, 2013.
  1. Sep 17, 2017 at 5:00 PM
    #1901
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Same to you.
    Cooktop86[QUOTED] and Blackout14 like this.
  2. Sep 18, 2017 at 7:29 PM
    #1902
    Cooktop86
    Cooktop86 Well-Known Member
    Jeff
    Hatfield, Pa
    2017 Tacoma TRD sport MGM
    Quick question if I put spacers on the truck can I get 285s?
    ProjectTgen3 and Blackout14 like this.
  3. Sep 18, 2017 at 7:31 PM
    #1903
    Cooktop86
    Jeff
    Hatfield, Pa
    How much would have to be cut? I don't want to lift it until it's not my DD
  4. Sep 18, 2017 at 7:34 PM
    #1904
    Cooktop86
    Jeff
    Hatfield, Pa
    I thought with spacers I wouldn't have to do the cmc.
    ProjectTgen3 likes this.
  5. Sep 18, 2017 at 7:36 PM
    #1905
    Cooktop86
    Jeff
    Hatfield, Pa
    Thanks. I'm working on getting the rims powder coated. Then tires
    Blackout14 likes this.
  6. Sep 18, 2017 at 7:58 PM
    #1906
    ProjectTgen3
    ProjectTgen3 Well-Known Member
    Keandrew
    Pennsylvania
    2016 Super White Tacoma TRD Off-Road
    Bilstein 5100 with OME Lift Springs Fox Performance rear 2.0 shocks DX4 Tuff wheels 17x8.5 -6 Falken Wildpeak A/T3W 285/70/17 RCI Rock Sliders
    I have 285/70/17 on a 17x8.5 -6 offset wheel. No cmc needed just slight plastic for driver side. Tool a heat gun and folded some parts, no big deal. Just my experience.
    Cooktop86[QUOTED] likes this.
  7. Sep 18, 2017 at 8:38 PM
    #1907
    Cooktop86
    Jeff
    Hatfield, Pa
    Thanks for the help. One of these days I'll get new tires.
  8. Sep 19, 2017 at 2:49 PM
    #1908
    PiedsterT
    PiedsterT Member
    Allentown, PA
    17' TRD Off Road DCSB
    I was there last Sunday and despite the 4x4 theme they had this time around i still ended up showing up in this lol.20170827_103007.jpg
    ProjectTgen3 and Kohan21n like this.
  9. Sep 19, 2017 at 2:53 PM
    #1909
    Kohan21n
    Kohan21n A caffeine dependent life form - IG @dizzy.trd
    Nazareth, PA
    2016 DCSB MGM 6MT
    Should have brought the Yota!
  10. Sep 19, 2017 at 3:01 PM
    #1910
    PiedsterT
    PiedsterT Member
    Allentown, PA
    I was really really close to bringing it because of the 4x4 theme. But im not the biggest fan on bringing a bone stock vehicle to Cars and Coffee for whatever reason. Kind of wish i did though...
  11. Sep 19, 2017 at 3:52 PM
    #1911
    Cooktop86
    Jeff
    Hatfield, Pa
    I will take you up on that. Thanks.
  12. Sep 19, 2017 at 9:54 PM
    #1912
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    In the process of a headlight retrofit. Until I make a thread bout it, I will document it here. Once I'm finally done and installed, I will make a thread.
    New aftermarket headlights
    Box of retrofit stuff. All Morimoto brand. Mini D2S 4.0 projectors with etched lenses, panamera shrouds, LED demon eyes, LED Halo for back-lighting the shrouds, Bluetooth controller for all the LEDs
    First attempt at baking the light was disastrous
    I found an OEM set of lights and then followed a procedure that @Blackout14 suggested which worked great.
    After I got all the parts out, I took the chrome pieces to work (easier to do this there) and cleaned all the chrome off with some kind of oven cleaner. Shit works like magic. Under the chrome was actually pretty shiny still. I did NOT scratch or scuff the surface before painting. We'll see how it goes.
    Here is the first coat of paint. It's a paint and primer in one. got it from Lowe's. It's satin black by (I think) Valspar
    Second coat of paint.
    WBF610, Grand dude and Blackout14 like this.
  13. Sep 20, 2017 at 8:09 PM
    #1913
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    I started trimming my projector shrouds today. what a pain in the ass! I am using a dremel with a cut off disc to cut most of the material I need out of there. Then I'm hitting it with a sanding attachment. I only got one shroud trimmed in about an hour, maybe 1.5 hours. It's not even fully finished. It ALMOST clips on to the projector at this point.
    Lessons I learned today:
    1. Don't bother painting any of the reflectors or shrouds until AFTER you trim the shroud. All the in and out of test fitting WILL scratch the paint. I will now have to DE-paint, then repaint! :D
    2. When trimming with the dremel, wear eye protection. I got plastic in the eye.
    3. When trimming with the dremel, don't get your shirt caught in the cut off wheel.
    4. When your done painting, make sure the parts are 100% dry before packing them in a box for transport. I'm doing this retrofit mostly at work, so I have been keeping the pieces in a box in my truck. Even though I wrapped in bubble wrap, I will have some small spots that I don't like and will have to touch up.
    5. The headlight reflector bowls have a lot of areas that you'll need to trim around. theres a bunch of ridges and what not. It would be nice to scribe the shroud, but I didn't have anything to do that with. I also don't know how well I COULD have scribed it since its pretty tight in there with the projector and the shroud.
    Lessons I learned yesterday:
    1. Oven cleaner stinks pretty bad and it actually pretty greasy when dry. I had to wipe the parts with windex before painting. Also, don't step on the cleaner. It's slippery. I sprayed the parts on the ground on top of a piece of cardboard. Almost broke my ass slipping on it. Use gloves. Do it outside.
    2. There's little tabs on the back of the reflector bowl. everyone says to grind it. I honestly did not see a reson to do so, other than to get my fingers around the locknut for the projector. I could still tighten it with the tabs there, but I ground it down just because that's what I've seen done. The bowls are some tough plastic or maybe fiberglass. I used a full face shield when doing this. it gets very dusty and you'll be cleaning white powder out of places you didn't think it would get.
  14. Sep 21, 2017 at 8:03 AM
    #1914
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    This is why I don't ever touch headlights.
  15. Sep 21, 2017 at 8:05 AM
    #1915
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    I hear ya. I feel like it's worth it to just buy them already retro'd
  16. Sep 23, 2017 at 7:00 AM
    #1916
    Rus TRD
    Rus TRD Well-Known Member
    Don
    Pa.
    2015 DC TRD Sport
    Bilstein 5100 with 884 Springs. Full audio system. Stealth 6 Wheels. Cali led light.
    Last chance for someone in Pa. Looking for a bed cover. Dropped the price $200.00. Trading truck in about two weeks.
    fatfurious2 likes this.
  17. Sep 23, 2017 at 7:17 AM
    #1917
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    how did the high beams go out? The way I see it, at least on the Mini D2S 4.0, it has one bulb with one function. for high beam, it has a small lever that moves up and down to either hide or reveal more of the bulb for high beam low beam. wouldn't that just be a simple fix? like changing the bulb?
  18. Sep 23, 2017 at 7:29 AM
    #1918
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    I could also be wrong.
  19. Sep 23, 2017 at 7:32 AM
    #1919
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Ohhh gotcha. Yeah I'm only familiar with the ones I have. It has the shutter.
  20. Sep 26, 2017 at 7:36 PM
    #1920
    Kohan21n
    Nazareth, PA
    2016 DCSB MGM 6MT
    Well guys, I am officially a Tacoma owner again! 5 long months after my accident I found one. I know I know.. I said at the Steel Stacks I didn't want a 3rd Gen but shit, I couldn't pass up the deal I got on this one.
    @Grand dude @Redmann @Braves95
    *orders lift kit
