Leitner Designs Active Cargo System
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Coaltown992, Aug 2, 2019.
  1. May 31, 2020 at 7:22 PM
    #41
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    Glad you asked this. The stock load capacity is rated for stock suspension and stock bed. Strengthen the bed by bolting it all together, and add some bed stiffeners and you just completely changed the structural integrity of the entire rear half of the truck. Couple that with a rear spring upgrade and whats the new load capacity? You wanna get real fancy? Regear it... Now you've got an entirely different truck.
  2. Jun 1, 2020 at 9:29 AM
    #42
    Swan2020
    Swan2020 Active Member
    Andrew
    2020 White TRD OR
    Thanks for the information. I went ahead and got a forged a week or two ago as I figured you had a good reasoning.
    Kevinpd325[QUOTED] likes this.
  3. Jul 18, 2020 at 6:43 PM
    #43
    Swan2020
    Andrew
    2020 White TRD OR
    What material did you use for the inner canopy? That's an awesome rack. I just installed a leitner and am trying to figure out how to put an inner canopy in it. Mostly just looking for something that'll produce some shade and keep thing reasonably dry when I'm not moving. My current thinking is some sort of waterproof canvas with elastic/straps to the rack and the bed tie downs.
  4. Jul 22, 2020 at 8:01 PM
    #44
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    I wanted to let anyone who was interested know that I emailed questions to Leitner about their bed rack. Really nice people. They actually responded within in hour. They did say to stay tuned because they were working on making the rack compatible with some kind of tonneau. If that is the case and I can get the rack and have it work with a tonneau then I am 100% going this route. Lots of good stuff on their Web site about the product. Really well designed. Really well made. And, one of the few companies that are very open about their static weight capacities -- I think 1,400 pounds on the newer ACS rack. That says alot about the product and the company. Every other rack manufacturer hems and haws when you ask them about the weight capacity of their rack. Yes you pay for it but it seems worth the cost to solve a problem and not have to worry about it.
    Tacodelphia likes this.
  5. Sep 20, 2020 at 11:44 AM
    #45
    Tacodelphia
    Tacodelphia Well-Known Member
    David
    Philly
    2020 TRD OR MT Cement
    I would be SO into this. Hopefully it shows up sooner than later.
    averagejp[QUOTED] likes this.
  6. Aug 12, 2021 at 12:28 AM
    #46
    Mt133677
    Mt133677 Well-Known Member
    SoCal
    2020 DCSB TRD OR
    All the things
    +1 on the forged rack. Love the sliding rear cross bar and quad t slot mounts. My buddies got a RCI universal adjustable bed rack and I hate loading and unloading under his bars. Cargo boxes are very convenient compared to the pelican Harddigs I used to load up.
  7. Jan 6, 2022 at 6:05 PM
    #47
    PipsTaco
    PipsTaco Well-Known Member
    Jarrod
    Central Valley, Ca
    2020 TRD Off Road
    I recently installed the ACS forged rack on my 2020. Leitner Designs customer service is great. I emailed them with some questions and they were very prompt with their response. They also recently started offering 20% off to military and first responders which helps a lot considering the price of the rack and accessories. The shipping was fast and the parts all came packaged and labeled very well. The instructions made installation easy. I intend to mount a rooftop tent and some camping accessories to the rack. I am very impressed with the engineering behind this system. It is very evident how much though went behind the entire system, from the fit and finish of the rack itself, to the hardware and ease of installation of the accessories. Yes, the price of the rack and accessories is on the higher end for bed racks but in this case you really do get what you pay for. If your budget allows, this system is impressive and I do not think you will be disappointed one bit with your decision to purchase.
    az300 likes this.
  8. Jan 13, 2022 at 1:48 AM
    #48
    celmassry
    celmassry Well-Known Member
    Christian
    Huntington Beach, CA
    TRD PRO GRILL TRD PRO WHEELS
    I have an acs classic setup that I am trying to set rid of. Let me know if anyone is interested
  9. Apr 24, 2023 at 6:29 PM
    #49
    ripley76er
    ripley76er Well-Known Member
    Nantucket
    2014 Tacoma TX Baja Series
    I know this is over a year old but did you ever get rid of your classic acs rack? im in the mkt for one
