less capable vehicle shunning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MagnumTaco, Feb 19, 2014.
  1. Feb 19, 2014 at 10:15 AM
    MagnumTaco
    MagnumTaco [OP] Well-Known Member
    Tony
    New Mexico
    Supercharger, Baja Suspension, TRD exhuast, Stealth pulley.
    http://www.youtube.com/watch?v=gw1nNdEVPf8
    Question, at what point in time do you tell a friend that drives a Subaru enough is enough? :mad: His less capable vehicle starts to affect our trips. Such as having to turn around, due to something breaking. We have gotten him through obstacles with towing/winching and shoveling. I do not want to be mean to the guy he can't afford anything else and likes the trips. On the upside I have gotten good at spotting and winching. The Jeeper in the group is fed up.
  2. Feb 19, 2014 at 10:18 AM
    Smooth Operator
    Smooth Operator Well-Known Member
    G
    Central, PA
    2013 TRD Sport / Long Bed
    None
    >>I don't want to be mean.
    Sometimes the truth hurts.
  3. Feb 19, 2014 at 10:22 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Thats a beautiful trail to wheel on!
  4. Feb 19, 2014 at 10:24 AM
    BamaToy1997
    Bill
    Navarre, FL
    I will be honest. After watching that video, I don't think it is the truck. I think the driver needs some proper education on off-road driving. He is running incorrect lines, using skinny pedal and clutch feathering when he should run a lower range and let the engine do the work, and all around just does not look like he knows what he is doing. That is my opinion from just watching the video.
  5. Feb 19, 2014 at 10:24 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I think you have your mind wrong. The only data I have to go off of is that video so ........... Looks like he has no clue how to drive. That's what's holding him back. Not his vehicle. Suburas are very capable offroad vehicles and have great 4wd systems. He just can't fuckin drive. If he is your friend then you should have no problem telling him that. Depending upon how he reacts to that, it may be time to tell him to stay behind. But if hes open to critisizm and wants to learn and you think you are a capable person of teaching him then should stick with yall.
    The jeep guy ........... Know one cares what he thinks anyway. ;)
  6. Feb 19, 2014 at 10:26 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    Oh, just let him have some fun.
    Interesting video to watch.
  7. Feb 19, 2014 at 10:27 AM
    spencer44306
    spencer44306 Well-Known Member
    Spencer
    Upstate Ny
    13 TRD Sport 4x4
    :burnrubber: :burnrubber::burnrubber: :burnrubber: :burnrubber::burnrubber: :burnrubber::burnrubber::burnrubber::burnrubber::burnrubber::burnrubber::burnrubber::burnrubber: :facepalm::facepalm:(this is all I saw the whole video)
    10+ minutes of clutch burning, trail ruining action
  8. Feb 19, 2014 at 10:27 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Vehicle looks capable, driver does not....
  9. Feb 19, 2014 at 10:28 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    You would think he would want to spare his Subaru the wear and tear and eventual carnage.
    They are nice on pavement but not an offroad rig
    Az
  10. Feb 19, 2014 at 10:32 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Eh Subaru's weren't meant to go off road like that. I'd tell him to get a jeep or quit wheeling with you guys. I mean seriously you can get a jeep for pretty cheap on craigslist.
  11. Feb 19, 2014 at 10:46 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Id tell him next time it breaks on the trail it stays on the trail unless he can fix it by himself. If thats all he can afford why tear it up? Not really, that would be mean, but his driving skills are very lacking. Know when to say when.
  12. Feb 19, 2014 at 10:47 AM
    jdavis92
    jdavis92 Well-Known Member
    Boise, ID
    2010 Regular Cab, 2.7L, 5spd
    Stock
    X2
    I had a 2001 Ford Focus wagon that could handle some of the stuff on those vids. Not because it was made to (it most certainly wasn't) but because I had off-road driving experience.
    My wife's Outback could go a lot of places if you knew how to drive it right.
    Jeff in Flagstaff
  13. Feb 19, 2014 at 10:51 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    this!
    Guy needs to learn how to drive offroad!
  14. Feb 19, 2014 at 10:54 AM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    http://www.youtube.com/watch?v=KFwPXEeJ3aI
    He needs one of these!
    In the biking world....if you cant hang and the group is moving on, you're dropped. Friend or not (unless it's a girl and she is cute, but your friend is neither the first nor the second, then I will wait :) )
  15. Feb 19, 2014 at 10:54 AM
    xodeuce
    xodeuce mmmmmmbourbon.
    Alabama
    2004 UZJ100
    Sometimes the truth hurts. Particularly when the truth is that you're trying to wheel a Subaru.
  16. Feb 19, 2014 at 10:56 AM
    Drinknmolson
    Drinknmolson Well-Known Member
    Wheat Ridge, CO
    10 DCSB sport
  17. Feb 19, 2014 at 10:57 AM
    Yotamac
    Yotamac Well-Known Member Vendor
    Ze
    562- Cerritos, CA
    07 PreRunner
    Stuff, stuff and more stuff
    just be patient... he'll destroy it in no time...then be riding bitch before you know it...
  18. Feb 19, 2014 at 10:59 AM
    TeamSarcasm
    The better coast
    Why don't you just say "the only way you are coming is if you are riding in someone's vehicle"
  19. Feb 19, 2014 at 11:11 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    I don't wheel anymore but I used to for about 5-6 years when I had an '01 taco with 4" lift on 33s's with a bunch of armor to protect the rockers and drivetrain. Had this friend that wanted to come along with his stock Rav4. Here in the northeast, every trail is strewn with large rocks. I convinced him that he did not have the ground clearance for the trails we were running. A year later he bought a full size dually quad cab with 8' bed and wanted to wheel that. The thing was a freight train. I believe it was about 25' long. Some people just don't understand what constitutes an off-road vehicle. Subaru's are great cars with amazing traction control and decent ground clearance but they are not meant for rock crawling.
  20. Feb 19, 2014 at 11:19 AM
    MagnumTaco
    Tony
    New Mexico
    God points, I wanted others perspectives. The jeeper and I might just let him break it until he learns or doesn't have a vehicle, then rides shotgun in the Ruby. Thanks you guys are awesome.
