Less MPGs after tune up.
Discussion in 'Performance and Tuning' started by Jpeg1900, Mar 17, 2018.
  1. Mar 17, 2018 at 7:09 PM
    Jpeg1900
    Jpeg1900 [OP] Member
    Greensboro, NC
    2010 black sand pearl Double cab LB 4x4, JBL sound system, black leather seats
    Hey guys, I'm having an issue with my MPGs. I did some tune up and maintenance work on my tacoma a couple of weeks ago, and I'm getting about 1.5 to 2 MPGs less now. I replaced the plugs, which I'm assuming are the originals. I bought the truck used, so Idk about how much maintenance the previous owners did. It has 127,000 miles on it. Anyways, I used the NGK and Denso combination that it came with, so same OEM plugs. I changed the air filter. Also changed the fluid in the front and rear diff, and transfer case. I rotated the tires as well. I was getting right around 16.5-17 MPGs before, and now it's dropped down to 15. I've also been a little easier on the throttle, so I figure that alone should improve it a little bit. Anyone else had this experience? Does anyone know what the reason behind this is?
  2. Mar 20, 2018 at 1:03 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Dirty throttle body.. I believe mine is the same I need to clean it too
    Jpeg1900[OP] likes this.
  3. Mar 20, 2018 at 1:09 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    It could just be your computer re-learning the new plugs. Give it a tankful or two and then check.
    Did you go with a higher viscosity fluid in your rear diff? I'm going the lightest possible next time. I don't tow or drive hard very often.
  4. Mar 20, 2018 at 1:56 PM
    Jpeg1900
    Greensboro, NC
    Thanks guys. I feel like if the throttle body was dirty before, wouldn't I have been getting worse mileage before I did the tune-up? IlI' still clean it. It probably needs it anyways. Thanks for the suggestion. I have no idea what type of gear oil was in it previously, since I bought it used. I've only put about 15,000 on the truck since I bought it. I just assumed it needed to be changed. I put Mobil 1 75w-90 synthetic back in it. I have heard about the computer needing to adjust. I'll wait a while and see if it changes.
  5. Mar 20, 2018 at 1:58 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    I just changed my diffs and tc today.. Mobil 1
  6. Mar 22, 2018 at 10:51 AM
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    What’s this?
  7. Mar 22, 2018 at 11:30 AM
    Jpeg1900
    Greensboro, NC
    I don't know what you're asking about...
  8. Mar 22, 2018 at 12:14 PM
    FinnJ
    Finland
    Tune up, do you mean just maintenance or some tuning (ECU)?
  9. Mar 22, 2018 at 12:42 PM
    Jpeg1900
    Greensboro, NC
    Just spark plugs and air filter, and the other stuff in the original post.
