Lesson Learned
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WVTacoma08, Jul 24, 2012.
  1. Jul 24, 2012 at 9:11 AM
    WVTacoma08
    WVTacoma08 [OP] Well-Known Member
    West Virginia
    '20 TRD PRO Super White
    Long story short.....
    Lost both black master keys & 1 Fob. Had only one working fob & gray valet key. Called dealership to have 2 new black "master keys" made. Truck's computer system had to be re-set from factory (2hrs labor) along with master techs skills.
    So in the end: 2 new black master keys & 2 hrs labor & programming 2 new fobs (1 original & 1 spare that I kept from prev truck I just traded in) was $210.
    Moral of the story....don't lose your keys :wink:
  2. Jul 24, 2012 at 9:13 AM
    1stacoma
    1stacoma Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    Would it have been less expensive if you had still had one key and just wanted to get a 2nd key?
  3. Jul 24, 2012 at 11:56 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Damn! Were those chipped keys? If not, you were screwed.
    I do not have chipped keys for my 12.
  4. Jul 25, 2012 at 3:55 AM
    chewingonabone
    chewingonabone Well-Known Member
    Josh
    Charlotte, NC
    09 Tacoma SR5
    Retrax One tonneau, bull bar, step bar, PL8521
    How do you not have a chipped key?? I thought all keys needed to have a chip to start truck.
    My truck only came with 1 key, 1 remote fob. Called stealership, they wanted $300 for 1 more set of key/remote. I told them to keep the damn key.
  5. Jul 25, 2012 at 4:12 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    My California built '10 SR5 is not chipped/immobilized either.
    The moral of this story: All trucks are not created equal it seems ... :eek:
  6. Jul 25, 2012 at 4:52 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Nope no chip or immobilizer. I can get a key made anywhere for a couple of dollars. As a matter of fact I always get a spare made of each and store them at home just because it is cheap insurance. I also keep the little tag that comes on the original keys so I could ( if need be ) get keys made from that code.
    Fuck a chip!
  7. Jul 25, 2012 at 5:23 AM
    WVTacoma08
    West Virginia
    Yep...my '11 has chip keys. Not sure if that is because I have the engine
    immobilizer or ??. But the computer had to be reset as well. But get this...after all of this, my original valet key still works. Just assumed that it wouldn't since all of this other stuff had to be done
  8. Jul 25, 2012 at 6:17 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    The valet key doesn't communicate with the ECU in any way. It just mechanically actuates the lock.
    The engine immobilizer Must communicate with a properly coded chip in order for it to allow the engine to start. You could tape the chipped key near the sensor inside the dash and then use a key made from Lowes etc without a chip. Of course that would defeat the purpose of the engine immobilizer system.
  9. Jul 25, 2012 at 6:33 AM
    WVTacoma08
    West Virginia
    Great point....but of course that would defeat the purpose. Didn't think about that though
  10. Jul 25, 2012 at 6:42 AM
    PaintDrinkingPete
    PaintDrinkingPete Well-Known Member
    NoVA
    2012 4x4 TRD Sport DCSB
    I believe all the TRD models do have immobilizer, but my 2005 SR5 did as well. I do know that not all Tacomas have it...which I was a bit surprised to learn.
    I guess this is a lesson learned to thieves as well: only attempt to steal base model Tacos!
  11. Jul 25, 2012 at 6:53 AM
    Hard
    Hard Well-Known Member
    H
    4X4X4
    My base model 2011 has the chipped keys. I was 100% confident it was a standard feature until reading this thread....live and learn.
  12. Jul 25, 2012 at 12:29 PM
    jpmorrisvb
    Jimmy
    Virginia Beach
    A case of the haves and have nots ... my base '06 did ... my '10 SR5 does not ... drat!
    I can't figure out why ... :confused:
  13. Jul 25, 2012 at 12:35 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Weird. My '11 SR5 has the chippies. Nice of Toyota to come up with some standardization on this. :confused:
  14. Jul 25, 2012 at 12:38 PM
    blunt
    blunt Active Member
    Syracuse
    2009 Tacoma SR5
    My valet key starts the truck just fine. In fact, since there is no glove box lock, I'm not even sure what it's purpose is.
    Does that mean my ignition system doesn't use the chip technology? And if so, can I make a copy of the valet key or even the real key to have a spare?
    I'm a little confused by this.
  15. Jul 25, 2012 at 12:43 PM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    I know locally of a place that installs auto-start systems in vehicles that uses a device to defeat the transponder in the truck. Several guys I work with use them to buy simple, $5, double-cut keys at the hardware store.
  16. Jul 25, 2012 at 12:46 PM
    Smoke2
    Smoke2 Well-Known Member
    Tacoma
    07 DC 4X4 LB
    Rear TSB, Firestone Air bags
    You should have got 3 keys
    2 keys with one fobs each and 1 valet key
    My SR5 has chipped keys.
  17. Jul 25, 2012 at 1:07 PM
    PaintDrinkingPete
    NoVA
    I believe with the base model or SR5 package it is available as an "option", but I'm pretty sure it's standard on all TRD models.
    It has a chip, just doesn't have the keyless entry remote...
    *If* you had a truck/glove box/etc with a keyed lock, the valet key wouldn't open it, but does seem useless on a Taco...maybe some factories just cut em anyway?
    My 2012 came only with 2 sets of keys, no valet. I didn't even realize they existed, since as was mentioned above, we don't have locking trunks/glove box/etc...
  18. Jul 25, 2012 at 1:12 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    6 lug vs 5 lug?
  19. Jul 25, 2012 at 1:14 PM
    nammer
    Nam
    Bradenton, Florida
    my understanding is the valet key cannot be copied (in the sense of the transponder) but i'm pretty sure if you put a valet in the key cutter at home depot, it will still copy you a key to open your door (I have not tried it yet, but I think that is what happens)
  20. Jul 25, 2012 at 1:18 PM
    nammer
    Nam
    Bradenton, Florida
