Lesson Learned
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DRP6833, Aug 13, 2014.
  1. Aug 13, 2014 at 11:26 AM
    DRP6833
    DRP6833 [OP] Well-Known Member
    Dave
    Frederick, CO
    2014 Tacoma I4 4WD
    Just wanted to pass this along for those like me who didn't know. This weekend I installed intermittent wipers on my '14 and in the process learned that if you disconnect the battery the trip odometers are reset to zero.
  2. Aug 13, 2014 at 11:28 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    not a bad learn learned...there was a bad one a few weeks ago where someone set off their side airbags to the tune of 6k.
    Howard
  3. Aug 13, 2014 at 11:36 AM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    normal on almost any car...I had a jeep that would show 74F (actually -25) in winter when I installed a new battery. You had to go more than 50mph for a few seconds to reset it, who knew
    BTW don't have that problem now, since my 14 doesn't even have outside temp
  4. Aug 13, 2014 at 11:51 AM
    bw4706
    bw4706 Well-Known Member
    Illinois
    09 Toyota Tacoma DCSB
    Bilstein 6112's , Eibach Coils,Hankook Dyna Pro MT 265/75/16, SPC UCA's, General Spring HD leaf packs, De-Badged, Ranch Bed Cap, Mag Light Seat Mount driver and passenger, Mini Mag Console Mount,Hard wired GPS, LED's in and out, MB TKO Wheels, After market grill, Heated seats, Diff breather relocation mod, LED Under Hood Lighting, LED Bed Lights, Aux. LED Reverse Lights, 30" L.E.D. Light Bar, Redline Tuning Hood Struts & EZ Down Tailgate. 6 Circuit Aux. Fuse Panel W/Circuit Breaker. Front & Rear Facing DVR cameras, High Lift Jack Bed Rail Mount. Clazio Leather Seat Covers. All Pro Heavy Duty Rock Sliders, 4x4 illuminated switch mod, Ignition converted to Push to Start. Bushwacker fender flares, Cali Raised side projector ditch lights. Cali Raised L.E.D. fog lights. 3 x 3 L.E.D. rear spotlights , Anzo headlights and taillights.
  5. Aug 13, 2014 at 12:53 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Pep Boys sells one of these things for $9, if nothing else it saves your radio stations.
  6. Aug 14, 2014 at 11:12 AM
    DRP6833
    Dave
    Frederick, CO
    2014 Tacoma I4 4WD
    The airbag story was exactly why I disconnected the battery, I sure didn't want to deal with that! :rolleyes:
    BTW, I was concerned about the radio presets but they were retained. It was less than half an hour, though, so that may be why.
    Thanks for the link to the 9V memory saver. I remember hearing about those years ago; needless to say it's on my wish list now.
  7. Aug 14, 2014 at 11:17 AM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Not really important! Better then the problems you can have for leaving it connected. As for the radio I have nothing set cause I never listen to fm.
  8. Aug 14, 2014 at 11:17 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Memory saver looks handy, and airbag replacement sounds like a shitty mod day.
