Let’s see dem Silver Tacos!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FtApache, Sep 20, 2015.
  1. Mar 26, 2023 at 7:08 PM
    #6281
    rwinkster
    rwinkster Active Member
    Prescott AZ
    2000 4runner, 2019 Tacoma OR
    pretty much everything
  2. Mar 26, 2023 at 8:52 PM
    #6282
    Integerdy
    Integerdy Aspiring "SR5 Pro"
    Eric
    So-Lame, Oregon
    21 SR5 Silver Sky DCSB
    I'd never recommend an AAL and block.. usually it's one or the other, with blocks being cheaper and aal being more functional
    I don't offroad and my truck is my daily pavement princess so the block doesn't bother me. It came with the factory TRD lift kit
    Fast1 likes this.
  3. Mar 26, 2023 at 9:06 PM
    #6283
    rileytaco99
    rileytaco99 Well-Known Member
    Riley
    Orlando, FL
    2023 Tacoma SR5 v6
    I’m sorry I meant is lift block better than AAL
  4. Mar 26, 2023 at 10:18 PM
    #6284
    Integerdy
    Eric
    So-Lame, Oregon
    Blocks are cheap. Not good for heavy loads or offroading. Aal is generally a better more expensive option for most ppl.
    I didn't want the rake look,, I like my truck looking level.
  5. Mar 27, 2023 at 6:32 AM
    #6285
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Keep in mind that not all AALs are the same with end results like ride, amount of lift, sag over time, noise during suspension movement and articulation limitations. Angled shims can be added for vibration reduction.
    Small blocks (less than 1 1/4") also are available that offer a slight degree of angle change to minimize vibrations with ride height changes. Blocks do not offer much improvement for significant bed load but retain OEM ride characteristics when not loaded.
    TuesdayTaco76 likes this.
  6. Mar 27, 2023 at 9:03 AM
    #6286
    rileytaco99
    Riley
    Orlando, FL
    2023 Tacoma SR5 v6
    What's the tire and lift set up?
  7. Mar 27, 2023 at 7:59 PM
    #6287
    bonnfabrication
    bonnfabrication Well-Known Member
    Brandon
    Bremerton
    2018 Tacoma TRD OR DCSB 4x4
    Dobinsons HD MRR lift SCS F5 wheels BFG K02s front bumper, custom roof rack
    Freshly washed and detailed. Probably means it’s gonna rain soon. A580F37F-C566-45B0-92CC-73438AA6B586.jpgE55F7439-061E-45A1-8C6F-395BBD4B3A2C.jpgC6FD7F0A-676D-4051-AF5A-78BE810340D0.jpg
  8. Mar 27, 2023 at 8:05 PM
    #6288
    rileytaco99
    Riley
    Orlando, FL
    2023 Tacoma SR5 v6
    I don’t plan to load my bed unless moving or helping a friend move. With 5100s set at 1.75 at the front, will a 1” block suffice?
  9. Mar 28, 2023 at 1:33 PM
    #6289
    Fast1
    Minneapolis, MN
    I have an AC cab with ~1.75" lift in front with Bilstein 6112s (set at max height for AC cab) and 1 1/4", 1 degree taper block paired with Bilstein 5160s with a Leer topper. I have ~ 1/2 to 3/4" height difference between front and back, with the back being higher measured from ground to fender well. I run 265/75-16 Michelin Tires.
    Block I used and which measured 1 1/4" and has the 1 degree taper. Change out is easy since the pin is in the block and doesn't require the pin in the spring pack to be changed. upload_2023-3-28_15-48-22.jpg
  10. Mar 28, 2023 at 5:58 PM
    #6290
    O'DOYLE RULES
    O'DOYLE RULES Active Member
    Brendan
    NH
    2023 Tacoma SR5 BLACK
    0 offset?
  11. Mar 28, 2023 at 6:09 PM
    #6291
    TuesdayTaco76
    TuesdayTaco76 Well-Known Member
    Moochacho
    California… thanks for leaving
    23 Tacoma TRD OR SB CB (chrome bumper✊)
    Still all in my head… but I’m keeping the chrome bumper!
    Howdy peoples… anyone Silver tacos out there running the reissue TRD FJ bead locks? Any of the three colors? Thinking since they are making them again they could be a solid look on Celestial Silver. I think this still goes with this thread because it hopefully will produce some pics of silver tacos. Thanks again.
  12. Mar 29, 2023 at 11:51 PM
    #6292
    JaxBeachTaco
    JaxBeachTaco New Member
    Finally took the build off road and hit some gnarly bricks today. Had to drop it into 4Lo, got stuck but the lockers saved the day! Made it out okay fortunately. Might cruise back and set up camp here for the night, hopefully the forest service won’t mind. Yeehaw.
  13. Mar 31, 2023 at 9:40 AM
    #6293
    rileytaco99
    Riley
    Orlando, FL
    2023 Tacoma SR5 v6
    What tires are these?
  14. Mar 31, 2023 at 9:42 AM
    #6294
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
  15. Mar 31, 2023 at 2:18 PM
    #6295
    Fast1
    Minneapolis, MN
    correct me if I'm wrong but they appear to be stock tires
  16. Apr 4, 2023 at 3:36 PM
    #6296
    AzChino520
    AzChino520 Well-Known Member
    2017 TRD Off-road Silver Sky
    6112 Bilstein’s, 5160 Bilstein’s
    Finally settled with some Method’s
    Riegs, grogie, -Rorschach- and 2 others like this.
  17. Apr 5, 2023 at 7:21 PM
    #6297
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
  18. Apr 8, 2023 at 1:45 PM
    #6298
    17silvrtrdsport
    17silvrtrdsport New Member
    Trent
    2017 Silver Tacoma TRD Sport
    Raised bumper letters Blacked out emblems LED interior lights
    got the wheels finally installed on Wednesday and just put on the pro grill. Next step leveling kit probably will go with 5100s front back. Wrapped the 4runner semas in 265/70/17 wildpeak at3s
    Riegs and -Rorschach- like this.
  19. Apr 8, 2023 at 3:00 PM
    #6299
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
  20. Apr 9, 2023 at 4:04 AM
    #6300
    Cap’n Flamingo
    Cap’n Flamingo Well-Known Member
