Let’s see your rattle can jobs!
Discussion in 'Guns & Hunting' started by LiveFast, Apr 16, 2019.
  1. Apr 26, 2020 at 7:15 AM
    Thompson486
    Thompson486 Well-Known Member
    Sherwood Park, AB
    2022 AC Off-Road Blue Crush
    That’s a sweet paint job!
    Nam Tiger stripe is the best camo.
    jeff b and klavender1[QUOTED] like this.
  2. Apr 29, 2020 at 10:05 AM
    Jllahman
    Jllahman Well-Known Member
    Jordan
    Northern Kentucky
    2008 Rugged Trail
    What kind of paint is everyone using for this? I've been thinking about it but don't want to spend the money on cerakote.
  3. Apr 29, 2020 at 10:27 AM
    Thompson486
    Sherwood Park, AB
    Krylon Ultra Flat or Aervo Industries. (There’a a couple other brands that are similar to Krylon as well)
    Aervo has the most color selection.
  4. Apr 29, 2020 at 10:32 AM
    Jllahman
    Jordan
    Northern Kentucky
    2008 Rugged Trail
    Do you worry about high temp paint at all? I would leave the barrel black, so no paint on that.
  5. Apr 29, 2020 at 10:37 AM
    Thompson486
    Sherwood Park, AB
    I don’t worry about high temp paint.
    Paint on the barrel and gas block will hold up fine, only part that probably wouldn’t is a muzzle deice if you plan on using it with a suppressor.
  6. Apr 29, 2020 at 10:39 AM
    Jllahman
    Jordan
    Northern Kentucky
    2008 Rugged Trail
    Sounds good. What kind of prep work do you do? Brake parts cleaner to remove any oil?
  7. Apr 29, 2020 at 10:55 AM
    Thompson486
    Sherwood Park, AB
    I usually just wipe it down and do it.
    I don’t like using brake cleaner on my rifles.
    I’ll let it dry for 5-15 minutes between colors or coats and then let it dry for at least 24hrs.
  8. Apr 29, 2020 at 11:02 AM
    Jllahman
    Jordan
    Northern Kentucky
    2008 Rugged Trail
    Sounds good, thanks! Now to decide on a color/pattern.
    Thompson486 likes this.
  9. Apr 29, 2020 at 11:04 AM
    Thompson486
    Sherwood Park, AB
    That’s the fun part!
    Jllahman likes this.
  10. Apr 29, 2020 at 6:18 PM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    I plan to use the Krylon Camo stuff, IIRC that's what Cleckner used and it seems to work well for the task.
  11. May 8, 2020 at 5:30 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    The less work you put into it, the better it looks:thumbsup: my new workhorse
    Alby22, Doc Samson, JustJon and 2 others like this.
  12. May 8, 2020 at 5:59 PM
    sittingbull
    sittingbull Well-Known Member
    I like the flag
  13. May 25, 2020 at 6:21 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    I taped over what I didn’t want painted, like the safety and any moving parts
  14. Jun 14, 2020 at 6:35 PM
    Lawdwaz
    Lawdwaz Active Member
    WNY
    2020 DCLB TRD OR
    Not a rifle but a shotgun, Beneli SBE I purchased in 1999 or 2000. Until a few years ago it was a blued receiver and nice wood stock and forend. Then I rattle canned it........lol
    Oh and quite a few gobblers have fallen to it.
  15. Jun 14, 2020 at 7:11 PM
    #35
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    Ugh!! I need to do this. My AR is just straight black and begging for some color
  16. Jun 14, 2020 at 7:22 PM
    #36
    Thompson486
    Sherwood Park, AB
    DOOOO IT!
    suaveflooder[QUOTED] likes this.
  17. Jun 17, 2020 at 10:44 AM
    #37
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Hmmm. I think i want mine desert camo
    Alby22 likes this.
  18. Jun 18, 2020 at 2:32 PM
    #38
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Tape anything you don't want painted but honestly, I just paint everything but the glass and a small strip around the optic adjustment and I close the dust cover if it has one or put a piece of tape over an exposed bolt (no, I don't bother to remove them). Blast it with whatever degreaser you like, I use non-chlorinted brake cleaner, then heat it with a heat gun enough to drive off any residual moisture and warm it up then paint away. The first gun I ever painted I was careful and either disassembled or taped off parts but after that, meh, it's just a tool. If I were Cerakoting on a gun I was concerned about the looks of then I'd be more careful but for a hunting or plinking gun that's going to get used, have at it. Unless you really, really goop it on heavy, everything on an AR will function just fine after a coating of spray paint. There is zero reason to worry about spraying the muzzle attachment unless you're attaching as suppressor and I've never had an issue with spray paint on a barrel or gas block even after a mag dump or two; if I owned a machine gun and shot it a lot on full auto then I'd want a high temp paint. I spray over the selector switch then flip it for the next coat, never an issue. Leaving the plastic parts like the grip or buttstock black just looks goofy (and seems to make it stand out more) when the rest of the gun is sprayed. Yeah, it'll wear with use and it'll probably blend in better to a point then just spray it again.
    Duracoat is fairly easy to use but like Cerkote, you definitely don't want to breath it. It's more durable than spray paint but not as durable as Cerkote. I bought a $15 Harbor Freight hobby sprayer figuring the stuff might ruin it- nope, just clean it up afterwards and almost ten years later that cheap spray gun still works.
    Doc Samson and jeff b[QUOTED] like this.
  19. Jun 26, 2020 at 9:22 AM
    #39
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    About to spray my rifle down. Once my optic mount and bev block arrive to do the final assembly, it's getting an OD base with some brown striping.
    Ever used acetone as a degreaser? I've got some brake cleaner and acetone at home, curious how things like optic o-rings hold up to them.
  20. Jun 26, 2020 at 9:58 AM
    #40
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    Why not just use 90% rubbing alcohol?
