Let the fun begin
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Unchained 5150, Jun 27, 2021.
  1. Sep 23, 2021 at 12:06 PM
    #1241
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    I'm reading that bigger tires, or super aggressive tires are ok to use them, so maybe for the cooper pros they should be good. Rick, if I get the machines before you get your Cooper Pros, I can use the beads if you want.
    For any SL rated tires, or any lighter ones I'll be sticking to the adhesive weights.
  2. Sep 23, 2021 at 12:07 PM
    #1242
    JustJon
    JustJon Well-Known Member
    MI
    18 DCSB OR
    If I stop buying gun stuff, maybe I can afford truck stuff..
    Bridge4 and Soul Surfer like this.
  3. Sep 23, 2021 at 12:13 PM
    #1243
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Rick - Why you want to ditch the carplay? That was quick!
    If you have the stock head unit then it does not. It rolled out in the 2020s. However, it's cable-only, so to use it you have to plug in. This dangly bit is a third party bodge that makes it work wireless, so you can route the wires elsewhere and tuck that box away and not have cables in theory.
  4. Sep 23, 2021 at 12:23 PM
    #1244
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Welcome
  5. Sep 23, 2021 at 12:27 PM
    #1245
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Six on the stickkkkkkkk :burnrubber:
  6. Sep 23, 2021 at 12:32 PM
    #1246
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I used DynaBeads on my motorcycle for many years. The tire companies changed mold release compounds during that time. With the new mold release, it would cause the beads to gather up into big balls that would throw the balance way off. Note that balance beads are said to be 0.040in diameter ceramic bead blasting media. Super cheap if bought in that form.
    My first solution was to waste time cleaning the carcass before mounting. It would take two cleanings to do the job. Not bad for two motorcycle tires, but not great either.
    After that, I just started using Slime to balance. Same result, but it takes more fluid to do the deed. There is still some clean up needed when swapping tires but takes no time to do. For a time, I was using antifreeze (doesn't corrode) as an experiment on my one, very-hard-to-balance sidecar bike (tube tires). I ended up transitioning to Slime there also.
    The other method that I have felt, but not used, is high quality AirSoft pellets. Baby bottom smooth, like the other options.
    I was thinking of mounting my own tires on the Taco and using one of those methods, but the TMPS sensors always puts me off. I like the system and don't want to potentially ruin it with either Slime or impact damage with beads / pellets. But after swapping my spare for matching diameters, it showed that my mounting tools need an upgrade. It is also much more work to break the inner beads.
    It is phenomenal how these dynamic methods work though, esp the faster that you go. Had my bike up to 130 fully loaded with camping gear. It was excellent.
    Soul Surfer and BudFriendguy like this.
  7. Sep 23, 2021 at 2:36 PM
    #1247
    Unchained 5150
    Rick
    Auburn Ma
  8. Sep 23, 2021 at 2:40 PM
    #1248
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    When you mentioned "boom" did the engine blow up, or was that a figure of speech? :eek:
  9. Sep 23, 2021 at 2:50 PM
    #1249
    Unchained 5150
    Rick
    Auburn Ma
    Funny hopefully letting the exhaust cool down enough and putting that on :D
  10. Sep 23, 2021 at 3:28 PM
    #1250
    Venom
    Kevin
    Massachusetts
    This must be exhausting work. :rofl:
    AllTacosFloat and Soul Surfer like this.
  11. Sep 23, 2021 at 4:31 PM
    #1251
    Unchained 5150
    Rick
    Auburn Ma
    What a difference in sound wow
    Soul Surfer likes this.
  12. Sep 23, 2021 at 4:55 PM
    #1252
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    Nice. It gets a little better too after you rack up some miles oh her :burnrubber:
  13. Sep 24, 2021 at 3:52 AM
    #1253
    Unchained 5150
    Rick
    Auburn Ma
    Meeeeeeeeeeeeeeeee likey very much.
    Soul Surfer and Venom like this.
  14. Sep 24, 2021 at 5:05 AM
    #1254
    Venom
    Kevin
    Massachusetts
    To bad you couldn't post a video with sound to compare the before and after sound.
  15. Sep 24, 2021 at 5:06 AM
    #1255
    Unchained 5150
    Rick
    Auburn Ma
    Yeah but I know it's different
  16. Sep 24, 2021 at 5:10 AM
    #1256
    Venom
    Kevin
    Massachusetts
    Is there a sound different with the windows closed in the cabin?
    It's going to get louder as the exhaust break in or as it age. One New England winter it will be louder.
  17. Sep 24, 2021 at 5:15 AM
    #1257
    Unchained 5150
    Rick
    Auburn Ma
    Works for me.
  18. Sep 24, 2021 at 5:23 AM
    #1258
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Bet you'll like it even more on the way home tomorrow
    :burnrubber:
    GarlicFarts likes this.
  19. Sep 24, 2021 at 5:24 AM
    #1259
    Unchained 5150
    Rick
    Auburn Ma
  20. Sep 24, 2021 at 5:43 AM
    #1260
    Unchained 5150
    Rick
    Auburn Ma
    Okay so MOD List to date.
    TRD Pro Led Headlights.
    MESO Stage 1 Tails with updated VLED's
    Black Softopper
    Full Size 2021 TRD Sport Wheel
    TRD Pro Exhaust
    TRD Cold Air Intake.
    TRD Pro Grille
    TRD Gray Ball 6 Speed Shift Knob
    Husky Weatherbeater Front and Rear Mats.
    TRD Pro Tail Lights.
    Carlinkit2 Wireless Carplay Adapter
    Toyota LED OEM Fog Lights
    Toyota Bed Mat.
    Interior VLED Kit
    Garmin front and rear Dash Cams
    Homelink Mirror with Compass/Auto Dim
    Taco Garage DMM.
    More to come...................................
