Let the fun begin
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Unchained 5150, Jun 27, 2021.
  1. Oct 29, 2021 at 3:16 PM
    #1761
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  2. Oct 29, 2021 at 3:16 PM
    #1762
    Unchained 5150
    Rick
    Auburn Ma
    Hmmmmmmm probably a good idea
    crashngiggles likes this.
  3. Oct 29, 2021 at 3:18 PM
    #1763
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Ya gotta loosen the LCAs to swing them down for the R and R on the struts anyway.....which means you need to mark your alignment before hand.
    Basically you're half way there to begin with.
    :notsure:
  4. Oct 29, 2021 at 3:19 PM
    #1764
    Unchained 5150
    Rick
    Auburn Ma
    Marking alignment what will that do since I'll need a new one anyway
  5. Oct 29, 2021 at 3:20 PM
    #1765
    Plain Jane Taco
    USA
    Oh....didn't realize you were replacing your LCAs.
    Edit....misunderstood ya. Marking the alignment will get you back to where you were to begin with
  6. Oct 29, 2021 at 3:21 PM
    #1766
    Unchained 5150
    Rick
    Auburn Ma
    No I am not but adding a lift won't I need a new alignment Bill?
  7. Oct 29, 2021 at 3:24 PM
    #1767
    Plain Jane Taco
    USA
    If you marked everything prior to it and you were not lifting....then no. But lifting can tweak things....especially toe and camber. So yes.
    I would still mark them so you aren't completely in left field though when it all goes back together
  8. Oct 29, 2021 at 3:28 PM
    #1768
    Unchained 5150
    Rick
    Auburn Ma
    @crashngiggles @tacobell007 @Taco01863 you all hear that?
    AllTacosFloat and crashngiggles like this.
  9. Oct 29, 2021 at 4:06 PM
    #1769
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
  10. Oct 29, 2021 at 4:07 PM
    #1770
    crashngiggles
    Jared
  11. Oct 29, 2021 at 4:15 PM
    #1771
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
  12. Oct 29, 2021 at 4:18 PM
    #1772
    Plain Jane Taco
    USA
    Your regular alignment guy gonna square it up for you?
  13. Oct 29, 2021 at 4:23 PM
    #1773
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
  14. Oct 29, 2021 at 5:03 PM
    #1774
    Unchained 5150
    Rick
    Auburn Ma
    Yes but I meant at least marking them so it’s not that bad of I ride around for a week
  15. Oct 29, 2021 at 8:26 PM
    #1775
    tacobell007
    Drew
    Western MA
    Wont need to mark them if you dont loosen them
    AllTacosFloat likes this.
  16. Oct 30, 2021 at 5:02 AM
    #1776
    Unchained 5150
    Rick
    Auburn Ma
    If we are putting the anti seize on them so they don’t seize up we’ll have to take them out right?
  17. Oct 30, 2021 at 5:07 AM
    #1777
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Good morning Rick and crew!
  18. Oct 30, 2021 at 5:09 AM
    #1778
    Venom
    Kevin
    Massachusetts
    Can a measurement of the left to right tires help to put the alignment close to where it was?
  19. Oct 30, 2021 at 5:19 AM
    #1779
    Unchained 5150
    Rick
    Auburn Ma
    No, by adding 2.5 inches of lift up front. And adding new UCA’s the geometry is changed to much.
    Venom[QUOTED] likes this.
  20. Oct 30, 2021 at 5:20 AM
    #1780
    AllTacosFloat
    Boston ish
    Mornin Unchained n Crew :hattip:
    tclavell and gregzz like this.
