Let's build a kit - Toolbox Essentials
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Faroutspacenut, May 13, 2020.
  1. May 13, 2020 at 9:58 AM
    Faroutspacenut
    Faroutspacenut [OP] Well-Known Member
    Southern California
    2020 DCLB TRD OR
    Hi TW,
    I'm starting on the fun task of outfitting my brand new TRD OR Double Cab, and I'll be assembling an on-board tool kit from scratch. I'd like your help in doing it.
    What are the essentials that every Tacoma should have on-board? My only requirement is that this tool bag/box/kit must fit behind the seat. Storage suggestions also welcome. I don't plan to do any serious rock crawling type of off-roading, but camping, dirt roads and trails for sure.
    Links appreciated but not essential.
  2. May 13, 2020 at 10:01 AM
    literallynothing
    literallynothing I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
    A socket set and a tool roll full of wrenches. Toss in a hammer, some pliers, vice grips, channel locks, crescent, some screw drivers. All of that should fit no problem. If you need more than that then you really messed up haha
  3. May 13, 2020 at 10:06 AM
    Spazum888
    Spazum888 Well-Known Member
    Spaz
    Orlando, FL
    2017 Taco TRD off-road 4x4
    Gloves, medical kit, yankum ropes, jumper cables...
  4. May 13, 2020 at 10:14 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I've been thinking about this too. I've been bringing a 75-100 lb toolbox with me when I get off the beaten path and it seems like overkill. I'm thinking to myself, "What might break that I can actually fix on the trail?" Unless I bring a set of spare parts I'm not going to be able to fix things like a busted CV joint.
    I went through a similar thing with my bicycle tools. I used to bring a bulky set of tools with me, but after a couple years of serious bicycling I settled on 2 spare tubes, tube patch kit, tire wrenches, a screwdriver to adjust a rear derailleur, and a phone to call for help.
    For the truck, at the very minimum I need enough wrenches to install/remove the various hi-lift jack accessories. I use it as a poor man's winch as well as a jack.
    On the dirt bike I bring a spark plug wrench and 2 spare spark plugs.
  5. May 13, 2020 at 10:40 AM
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    I think that, and a decent little tool kit like this https://www.tekton.com/3-8-in-dr-skt-and-r-sets-1-4-1-inch-6-24-mm?set-range=6-24-mm will get you through anything. Granted, I carry a space CV axle and socket But I beat the crap out of my taco lol.
    whatstcp[QUOTED] likes this.
  6. May 13, 2020 at 10:57 AM
    Big_Red_Taco
    Big_Red_Taco Well-Known Member
    SoCal
    Rad Red '08 DCSB TRD Off Road
    Mostly stock: AP rear plate bumper, CR D-Lights, 4600s
    May I also recommend, instead of jumper cables, a jump starter pack - I've got this one:
    NOCO Boost Plus GB40 1000 Amp 12-Volt UltraSafe Portable Lithium Car Battery Jump Starter Pack For Up To 6-Liter Gasoline And 3-Liter Diesel Engines
    https://www.amazon.com/NOCO-GB40-Ul...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
    Especially if you're camped miles from another vehicle and your battery poops out.
    Jamesr913, t.hornstra and Winch like this.
  7. May 13, 2020 at 11:01 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    A different jack - assuming you're above stock height.
  8. May 13, 2020 at 11:02 AM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    A fat credit card on your wallet, ftw. Lmao since you're always gonna be within tow truck reach.
    Green Jeans and whatstcp like this.
  9. May 13, 2020 at 11:03 AM
    s.e.charles
    s.e.charles Well-Known Member
    ever wonder why a metric socket set has an imperial drive wrench . . . . ?
    CJH9980 and pltommyo like this.
  10. May 13, 2020 at 11:06 AM
    gudujarlson
    Minnesota
    1000 amps? Surely they don’t mean amperes, ampere hours, or milliampere hours. What unit do they mean?
    EDIT: I’ve come to the conclusion that they mean milliampere hours. What else could it be? However, 1000 mAh is about the capacity of a AAA dry cell battery. Is that enough to start a truck? Apparently the answer is yes. Maybe I am missing something important.
  11. May 13, 2020 at 11:07 AM
    ToyoTaco25
    North Carolina
  12. May 13, 2020 at 11:07 AM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    I hate you right now. :annoyed:
  13. May 13, 2020 at 11:12 AM
    Chunk
    2016 DCSB OR
    Baby Ruth
    I carry one in addition to jumpers, don't think I'd have the balls to swap it out completely and hope!
  14. May 13, 2020 at 11:13 AM
    1999TacoMan
    1999TacoMan Well-Known Member
    Brian
    Fort Worth,Texas
    2019 Tacoma TRD OR 4x4 DCSB (Sold)
    This is what is inside my tool bag that I carry everyday:
    - Drill with bit kit
    - Electric screwdriver
    - Wire cutter/crimpers
    - Test light
    - Gloves
    - Small ratchet/socket set
    - Flashlight
    - Zip ties
    - Steel tap screws
    - Electrical Tape
    I'm sure I'm missing a few things but that is what I normally keep in that bag, which stays behind the driver seat.
  15. May 13, 2020 at 11:13 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    I’ve had good luck with em, bought a second and now have one in the truck and wife’s car
  16. May 13, 2020 at 11:17 AM
    Chunk
    2016 DCSB OR
    Baby Ruth
    I use it to start the riding mower mainly, but on trips, I charge it up and take it with. Haven't had to use it on the truck yet!
  17. May 13, 2020 at 11:21 AM
    Spare Parts
    Southern Maine
    Lol, that’s exactly why I got it at first. We take it camping and charge it via solar panel and at night charge phones or speaker. I have started our Outback with it. Now that one stays in the Outback. Got a bigger one for the truck, as the small one was not able to start a big van one summer, but in all fairness the jump pack wasn’t even half charged.
    Chunk[QUOTED] likes this.
  18. May 13, 2020 at 11:25 AM
    ericvega
    ericvega Well-Known Member
    Eric
    2019 MT TRD OR DCSB
    Magnusson Supercharger Kit RCI Skids C4Fab Sliders CBI BedRack Bilstein Bypass Shocks Icon RXT Leaf Pack
    It's a lithium pack, so it's not unthinkable that the battery itself *could* produce 1000 amps peak. Could the rest of the device handle it? Likely not. But it probably could manage most starters, given that they won't be drawing 1000A continuous- a few hundred for a short period of time at most.
  19. May 13, 2020 at 11:32 AM
    Spare Parts
    Southern Maine
    Doesn’t it also “fast” charge the battery as well?
  20. May 13, 2020 at 11:39 AM
    Big_Red_Taco
    SoCal
    I think it's just for starting - maybe a higher end model can fast charge, I don't know, but not this model.
