Let's help diagnose my electric issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by sk8rjess, Jul 6, 2017.
  1. Oct 17, 2017 at 12:14 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Let research a few things
  2. Oct 17, 2017 at 12:22 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    page BE-45 of that file shows how to check the Rheostat/dimmer. Lets make sure that's good first.
  3. Oct 17, 2017 at 12:26 PM
    mechanicjon
    Jon
    Scottsdale Arizona
  4. Oct 17, 2017 at 12:31 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Yes because the diff lock switch is lighted also.
  5. Oct 17, 2017 at 1:25 PM
    sk8rjess
    sk8rjess [OP] IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
    Hmm I'll have to find a tester light. My diff was an add-in and I'm starting to question if i wired that right. I only had it illuminate while it was locked.
    I've ripped out almost anything that wasn't stock and labeled everything else. I'm almost back to normal I think.
    I did find this and I'm not entirely sure why. If i'm reading the FSM right its a TVIP ECU? Not even sure what that is. Notice the black and white cut.
  6. Oct 17, 2017 at 3:15 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    I think thats Toyotas alarm system option.
  7. Oct 17, 2017 at 4:16 PM
    Glamisman
    Glamisman Well-Known Member
    If it was me I would disconect or cut the White/Black wire from the rheostat(s) attach a test wire and ground that and see if the rheostat functions normally. If it does you know then the issue is on the ground side of the harness.
  8. Oct 17, 2017 at 6:28 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    This is a 3 wire electronic rheostat. It has to have a ground to function.
  9. Oct 17, 2017 at 10:42 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    The TVIP is a big black box behind the driver side foot panel. About the size of a VHS tape, maybe a tad smaller. Usually wrapped in brown foam.
  10. Oct 18, 2017 at 10:08 AM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    Good news, I think it is the rheostat. Didn't have a tester light so i grabbed one of the bulbs out of the corner lights and wired that up according to the diagram @mechanicjon provided. It didn't dim at all.
    @ThunderOne may be able to let me test his and vice versa since he's local.. wink wink hint hint :D
  11. Oct 18, 2017 at 10:16 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Is that with the burnt trace repaired?
  12. Oct 18, 2017 at 10:18 AM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    Yessur. I don't see any burnt components though, which is why i never really suspected it
  13. Oct 18, 2017 at 10:36 AM
    mechanicjon
    Jon
    Scottsdale Arizona
