Let's play "how screwed am I?"
Discussion in '1st Gen. Tacomas (1995-2004)' started by Calion, Feb 27, 2019.
  1. Feb 27, 2019 at 6:19 PM
    Calion
    Calion [OP] Well-Known Member
    2002 Black Tacoma SR5 4x4
    Came used with brush guard, winch and bed cover.
    So my Taco has been sitting for the last two months while I waited on the weather to cooperate so I could finish some repairs. So repairs are now done, and I tried to start it. It turned over at first, then stopped. I thought, "well, maybe it's the battery" and tried again. Then the starter motor turned, but the engine didn't move. I tried one more time—and the engine made a horrible grinding noise.
    Rather worried, I checked the oil—full. Then I realized that it had gotten quite cold during the last two months and checked the antifreeze—which was very low. Indeed I couldn't see any. So I filled the radiator and overflow tank, which took less than ½ gallon all told.
    Does anyone have any idea what might be going on here, and whether I should try to start it again? I had no engine troubles prior to this.
  2. Feb 27, 2019 at 6:20 PM
    Mateo74
    Mateo74 Well-Known Member
    Matthew
    NWI
    16' Tacoma Sr5 Blazing blue pearl
    What kind of repairs?
    cruxofthebisquit likes this.
  3. Feb 27, 2019 at 6:22 PM
    eon_blue
    Azusa, CA
    What kind of repairs did you make to it? Was the antifreeze low before you parked it for awhile?
    Low coolant isnt good, in the sense that coolant doesn't just disappear or burn off...it's either leaking out (best case scenario) or there's a bigger problem at hand like a blown headgasket. But with it being that low I'd think you have a leak somewhere
  4. Feb 27, 2019 at 6:24 PM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    I’d try boosting it especially if it hasn’t run for a while, battery could be dead.
    Sweet duster btw!
  5. Feb 27, 2019 at 6:51 PM
    Calion
    Ball joint and inner tie rod end.
  6. Feb 27, 2019 at 6:53 PM
    Calion
    Yes, the coolant was low before. I'm not sure how low, but it wasn't nonexistent. I'm not sure where it's going, or how fast it's leaving. But the horrible grinding noise is what worries me.
  7. Feb 27, 2019 at 6:59 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Grinding as in flywheel gears stripping on the starter, or grinding internally in the engine?
    wilcam47, elmontemike and US Marine like this.
  8. Feb 27, 2019 at 7:02 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    If you heard a loud metallic sound like a loud audible clank while attempting to start it and the motor isnt turning over then the engine is locked up
    If you're hearing a loud grinding sound from the starter that's a definite clue that you've got a bad starter or worn flywheel
    wilcam47 likes this.
  9. Feb 27, 2019 at 7:04 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Charge the battery and try again before worrying.
    I'm betting it will start just fine.
    Wulf likes this.
  10. Feb 27, 2019 at 7:07 PM
    elmontemike
    elmontemike Well-Known Member
    This would be my guess also
  11. Feb 27, 2019 at 7:12 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
  12. Feb 27, 2019 at 7:29 PM
    Calion
    It's not the battery. It felt like it broke through some obstacle when the engine made the awful noise.
    Thanks! It's my favorite thing!
  13. Feb 27, 2019 at 7:46 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Maybe some oil down the spark plug holes. Let it soak and try to turn it over by hand. Maybe rings just corroded to cylinder walls? Hoping for something simple. If the cylinder was full of coolant then it could of bent a rod?
  14. Feb 27, 2019 at 8:17 PM
    Calion
    The engine. It's definitely not the starter spinning.
  15. Feb 27, 2019 at 8:20 PM
    Calion
    No. It turned, just with a grumbly grinding noise. I suppose I had better try it again.
    US Marine[QUOTED] likes this.
  16. Feb 27, 2019 at 8:25 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Just to be safe and make sure you don't have coolant in one or more cylinders, I'd pull all the spark plugs before you try to crank it over again.
    02-5Lug and US Marine like this.
  17. Feb 27, 2019 at 8:26 PM
    MyWyfsRnnr
    MyWyfsRnnr Well-Known Member
    Citrus Heights
    2018 4Runner TRD
    Prinsu full rack, 3" OME, 275/75/17 KO2, Anytime Backup, BudBuilt Skids & Sliders, Wet Okole covers, Tint front, Silverstar Headlights, black taillights, LED Backup lights, LED interior Lights
    Where are you located? It is really hard to diagnose over the net. Can you post a vid etc that shows the issue etc.
  18. Feb 27, 2019 at 8:26 PM
    SR-71A
    Zack
    Southern Maine
    Cranking an engine with any non compresible fluid in the cylinders is no bueno
    Jeffch and US Marine like this.
  19. Feb 27, 2019 at 8:53 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Grinding noise? You sure it's not the starter/flywheel? When one wears down, it won't engage fully and often grind during starts. Dealt with this problem on a Jeep many moons ago.
    Wulf likes this.
  20. Feb 27, 2019 at 8:57 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    As others have mentioned if you do have water or coolant in a cylinder it doesn't take much to hydraulic a cylinder . A engine can't compress this without major damage such as a bent connecting rod and even damage to a ring land on a piston
    I've even seen it kick a rod out the block !!
    My suggestion even suggested by @SR-71A is to pull the plugs and crank the engine over . If you do see water squirting out that's a bad sign
    SR-71A likes this.
