Let's play "how screwed am I?"
Discussion in '1st Gen. Tacomas (1995-2004)' started by Calion, Feb 27, 2019.
  1. Feb 27, 2019 at 8:57 PM
    Calion
    Calion [OP] Well-Known Member
    2002 Black Tacoma SR5 4x4
    Came used with brush guard, winch and bed cover.
    US Marine likes this.
  2. Feb 27, 2019 at 8:59 PM
    Calion
    Well, heck. I wish I'd seen this before I tried again. This is the sort of info I was looking for.
  3. Feb 27, 2019 at 9:01 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
  4. Feb 27, 2019 at 9:10 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Pull the oil pan drain plug and if you had water fill a cylinder (s) you will see water come out prior to any oil as water is heavier !!!
  5. Feb 28, 2019 at 5:07 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Not turning over isnt a good sign unfortunately.
    I would pull the plugs and try to turn it over. See what comes out of the cylinders. With any luck your old starter and battery isnt strong enough to cause any internal damage, if the engine was actually hydraulically locked.
    And maybe drain the oil like @US Marine said. See what comes out of there too.
  6. Feb 28, 2019 at 3:32 PM
    Calion
    So it froze to death.
    I had it towed to my mechanic, and he got it started, but it's spitting coolant out of the tailpipe. Likely the head is cracked. He recommends a whole new (used) engine, because there's no telling how much more damage there is.
    Manfred and wilcam47 like this.
  7. Feb 28, 2019 at 3:41 PM
    eon_blue
    Azusa, CA
    Ouch, sorry to hear that
    tcjacado likes this.
  8. Feb 28, 2019 at 3:43 PM
    eon_blue
    Azusa, CA
    Has it ever overheated at some point over it's life? Not common to hear about this happening on a 3.4l, unless it overheated at some point
    Toyko Joe likes this.
  9. Feb 28, 2019 at 4:30 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
  10. Feb 28, 2019 at 4:58 PM
    SR-71A
    Zack
    Southern Maine
    Damn, that sucks. Improper mix of coolant and it literally froze, or just bad luck whit something else?
  11. Feb 28, 2019 at 5:14 PM
    Calion
    In its life? No idea. I've only owned it for about a year. No overheating issues since then, though the coolant was getting a bit low. I never added any, because I was still figuring out what I should add, and in the meantime we had 12°F nights. I guess the existing antifreeze wasn't up to the job.
  12. Feb 28, 2019 at 5:15 PM
    Calion
    Must be the former. I never added coolant to it; it had been getting low, but I didn't think it was urgent.
  13. Feb 28, 2019 at 5:16 PM
    Calion
    So—any thoughts? Advice? Is he right that I should get a new engine, or can I replace the head and test the rest?
    wilcam47 likes this.
  14. Feb 28, 2019 at 5:22 PM
    SR-71A
    Zack
    Southern Maine
    How mechanically inclined are you? If not so much, then how much are you willing to spend on this project?
    To answer your question directly, if nothing else is jacked up as the result of cranking with fluid in the cylinders, then theres no reason why that wont fix it
  15. Feb 28, 2019 at 6:01 PM
    #35
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    When you say "Can I" do you mean "Can he"?
    You're going to have to trust your mechanic or your own skills at some point.
    Running Board Man likes this.
  16. Feb 28, 2019 at 6:34 PM
    #36
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Depends whats actually cracked. Most times the pressure cracks the cylinder walls. could be the head but could be asking for more trouble. also if it compressed the liquid in the cylinder it could have bent a rod or even the crank...prob cost more to fix that engine than it would get a new "used" one.
    98tacoma27 likes this.
  17. Mar 1, 2019 at 6:25 AM
    #37
    Calion
    I'm willing to do the work if I can afford the tools, etc., and it's within reason for me to do, but the question is, how do I find out if there are other problems?
    I've turned into a half-decent shadetree mechanic out of financial necessity, but I've never delved into an engine before, so I don't know what I'm getting myself into.
  18. Mar 1, 2019 at 6:27 AM
    #38
    Calion
    It's not about skill, it's about what's possible (or reasonably feasible). My mechanic seems to think there's no real (economical?) way to find out if there's further damage, so we might as well get a new engine. Is that the case? Or is there another way?
  19. Mar 1, 2019 at 6:38 AM
    #39
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    Yank it out, totally strip it down, and inspect everything. That's about the ONLY way to be sure you can spot EVERYTHING that's wrong...or WILL go wrong in another couple of thousand miles...
  20. Mar 1, 2019 at 8:24 AM
    #40
    wilcam47
    Will
    Bourbon state
    yep exactly. Only way to see what happened is to take it out completely and take it all apart. If its something major such as bent rod it will show up as soon as you start it
    SR-71A likes this.
