Lets see how much this will cost!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldentaco03, Jun 29, 2015.
  1. Jun 29, 2015 at 5:49 AM
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    I'm taking my 03 Xtra Cab to my family mechanic for the first time (since I bought it a few months ago). Just a normal check up and tune up, it will be the first time he will have looked at it. I gave him a list of things to look at and fix if he thought they were that bad: rough starting, low idle, tire alignment (pass side), ball joints, etc.. We will see how this turns out and if there are any serious problems that will warrant big bucks. I will let you guys know in a day or two what the damage is. In the mean time does anyone have info on that ball joint recall, because I know my lowers are bad.
  2. Jun 29, 2015 at 6:23 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Are we supposed to offer guesses?
    Price is Right rules?
    Ill bid $1, Bob.
  3. Jun 29, 2015 at 8:49 AM
    goldentaco03
    Liam
    NJ
    Not too bad $110 for a tune up (plugs, wires, battery, manifold cleaning, throttle body cleaning, and a bunch of other shit).....butttt inner and outer tie rod ends for $330 and a new hub bearing assembly for the one side.
  4. Jun 29, 2015 at 8:55 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Actually, If you aren't doing it yourself, the price is pretty good.
  5. Jun 29, 2015 at 1:19 PM
    goldentaco03
    Liam
    NJ
    That was his estimate we will see what it actually costs ;)
  6. Jun 29, 2015 at 1:19 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    agreed, those prices are very fair and a good deal as long as its all genuine oem replacement parts being used, what ever you do, don't let them use aftermarket stuff
  7. Jun 29, 2015 at 2:10 PM
    goldentaco03
    Liam
    NJ
    I have no idea if it's OEM or not. It a foreign auto repair place specializing in Japanese and European "imports". My family has used them for years and not had any real problems. Basically they're not out to get me.
  8. Jun 29, 2015 at 2:41 PM
    Indy
    Indy Master of all I survey.
    I put a set of no name ball joints on my f150. 1 year later got to do it again :laugh:
    Most of the time I buy whatever is at the parts store, never had an issue besides the ball joints. And I think I go them off of ebay.
  9. Jun 30, 2015 at 6:06 PM
    keakar
    karl
    louisiana
    well I suggest you tell them you only want to use all Toyota oem dealer parts only, it may add another $200-$250 to the bill but it is more then worth it for the quality and long life of the parts and then it will be good for another 15 years instead of needing more work again to replace the same parts in 2 or 3 years
  10. Jul 5, 2015 at 9:17 AM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Definitely go with OEM ball joints. I got a set of Moogs for mine cause I couldnt afford OEM at the time. Going to have to be replacing my uppers soon
  11. Jul 5, 2015 at 9:46 AM
    goldentaco03
    Liam
    NJ
    Well the total came to around $430 with a full tune up, ball joints, and something with the hub bearing. The tune up helped a lot, I regained a lot of torque (especially low end) and it idles better. We'll see how the ball joints hold up.
