Let's see if I got this right...
Discussion in 'Suspension' started by sante55, Jun 30, 2011.
  1. Jun 30, 2011 at 9:25 PM
    sante55
    sante55 [OP] Member
    Jeremy
    PreRunner TRD Sport
    De-badged Blacked Out Front Emblem Stubby Antenna
    Hello TW...learned so much searching the forums...So, I have a 2011 TRD Sport Doublecab Prerunner...Hopefully, I got this right...I have narrowed down my lift set-up to the following:
    Camburg Spindles
    Camburg UCA 1.25" Uniball
    Toytec Coilovers (uses Bilstein 5100)
    Bilstein 5100 for the Rear Shocks
    Deaver Custom Leaf Spring Pack (Luckily, I live near Deaver's Shop)
    I'm planning to run 17x9 wheels (haven't shopped these yet) with 285/70R17 Goodyear Duratrac's.
    I would like the truck level...not diggin' the bro lean or rake...so here's a couple of scenarios:
    1) I figure if the Front 5100's are set at .85" (which would put me close to a 5" lift w/ the spindles)...then I could go with a custom Deaver Leaf Spring Pack that lifts the rear 3" or so...and I'm pretty sure the 5100's would work in the rear...and gives me a pretty level set-up...Yes/No?
    2) Next scenario...If the Front 5100's are set to 1.75" (which would put me close to a 6" lift w/ the spindles)...how high should I go in the rear to level the truck...and would the 5100's work in the rear with this set up...Suggestions?
    So...what do you think?
  2. Jun 30, 2011 at 9:36 PM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    :rofl:
  3. Jun 30, 2011 at 9:37 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Adjustable 5100s do not work for the rear suspension, at all.
  4. Jun 30, 2011 at 9:47 PM
    sante55
    sante55 [OP] Member
    Jeremy
    PreRunner TRD Sport
    Thanks for the info...I was planning to go with the non-adjustable 5100's recommended for the rear.
  5. Jun 30, 2011 at 9:51 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    The 5100s in the rear might be to short and limit your axle articulation in the droop department if you go more than +2-3" in the back.
    As for the calculations to get our lean/level correct, my Taco came stock at about +2" higher in the rear, so basically any lift I do, while wanting it to be level, needs to be about 2" more in the front. Not sure about the Prerunner tho, might naturally have less rake due to less weight in the front.
    Are you going to work on it yourself or have a shop do it?
  6. Jun 30, 2011 at 10:09 PM
    sante55
    sante55 [OP] Member
    Jeremy
    PreRunner TRD Sport
    Well, thats the golden question for me...the install seems easy...just time consuming...but because Camburg is local to me I may have them install the lift...right now the priority is getting all the parts staged so I can install everything one weekend or load it up and take it to a shop...depends if I can get some extra shifts at work to pay for the install...I'll be able to get a better idea on the rear lift; first, when I decide how high to go in the front and second, when I talk to Deaver and see what they recommend for the rear...but I hear ya on the 5100's in the rear...thanks for the info...much appreciated!!!
  7. Jun 30, 2011 at 10:10 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    5110s or 5125s in the rear.
  8. Jun 30, 2011 at 10:20 PM
    sante55
    sante55 [OP] Member
    Jeremy
    PreRunner TRD Sport
    I haven't seen any Bilstein 5110's...but I'm with you on the 5125's...I'll probably go the 5125's in the rear if I set the 5100's in the front to 1.75"...thanks for suggestion!!!
