Lets see some 3'' Lifts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OB.BAJA, Jul 24, 2009.
  1. Jul 24, 2009 at 2:35 AM
    OB.BAJA
    OB.BAJA [OP] Well-Known Member
    Obed
    SoCal
    Hi guys im thinking about purchasing a leveling kit very soon for my 06 taco but just wanted to have an idea of how the kit will look once on..thanks..
  2. Jul 24, 2009 at 2:45 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    I will play............
  3. Jul 24, 2009 at 2:47 AM
    OB.BAJA
    Obed
    SoCal
    dam nice
  4. Jul 24, 2009 at 2:53 AM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    technically, a leveling kit is not a 3" lift but hey who cares. here's my 3" lift...
  5. Jul 24, 2009 at 3:11 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    same here
  6. Jul 24, 2009 at 5:57 AM
    kasey200
    kasey200 Well-Known Member
    south dakota
    07 TRD Dboubl Cab Longbed
    3" toytec, 285 BFG AT's
    Here's a couple shots of mine
  7. Jul 24, 2009 at 6:20 AM
    dirthawker1313
    dirthawker1313 Well-Known Member
    now are any of these trucks with just the leveling kit? and technically whats the difference between a 3" lift and a 3" leveling kit?
  8. Jul 24, 2009 at 6:48 AM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    3" toytec ultimate
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  9. Jul 24, 2009 at 8:14 AM
    jonny
    jonny Betty White Edition Heep ZJ
    meh...
    i will also play
  10. Jul 24, 2009 at 8:17 AM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    08 prerunner TRDsport DoubleCab
    Tinted windows, toytec ultimate 3inch lift- front c/o rear aal, 18" black rockstar rims, 275/70/18 toyo opencountry mt's, BLUE dome light, 6000k H4 HID bixenon, kenwood kvt-514 headunit,black badges, satoshi grill :] sold it and now have a wrangler....
    correct my if im wrong, but a leveling kit is normaly just an inch or 2 in the FRONT to LEVEL out the sag in the front compaired to the back,
  11. Jul 24, 2009 at 8:19 AM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
  12. Jul 24, 2009 at 8:23 AM
    jonny
    they come in 3" lift as well.
    i have the hbs 3" spacer lift. some angles have the socal lean, some look level.. (stock rear susp) w/285's
  13. Jul 24, 2009 at 8:40 AM
    brian
    Elizabeth City, NC
    my kit is nothing more than a leveling kit as well. Its spacers, but 3" in the front, and .25" AAL in back.
  14. Jul 24, 2009 at 8:44 AM
    James08
    James08 Well-Known Member
    James
    Gig Harbor, WA
    2023 TRD PRO
    I'm just finishing up the $1,000 worth of stuff to make my truck look the way I want, and I said I would be done for a while. Every time I see a taco with the 3' kit and 33' tires on it I know it won't be long before I'm dishing out another $2k to buy the Toytec Ultimate and a set of 33's.
  15. Jul 24, 2009 at 8:46 AM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    Here is mine when I had the bigger lift on. It's close to 3" using DR coilovers up front and Deaver 10 leaf springs in the rear with DR resi shocks. Tires are BFG AT.
  16. Jul 24, 2009 at 8:48 AM
    jonny
    was reading your build thread..
    black grill surround will top it off!
    looks good so far man
  17. Jul 24, 2009 at 8:49 AM
    jonny
    color matched mirrors and rear bumper would look sweeeet . can't wait to colot match mine :(
    looks good though!
  18. Jul 24, 2009 at 9:03 AM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    Thanks! You're truck is sweet. Keep up the good work. I've thought about adding the black vinyl strip on my front bumper too and a Satoshi grill. Looks good.
  19. Jul 24, 2009 at 9:07 AM
    jonny
    you sooo should man!
    would look awesome!
  20. Jul 24, 2009 at 9:11 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Better pictures to come later.
