Let's See Some Softoppers
Discussion in 'Tonneau Covers, Caps and Shells' started by tcBob, May 13, 2013.
  1. Apr 24, 2017 at 12:09 PM
    #2081
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    For you guys who have added lighting or even a 3rd brake light to your toppers, how are you running your wiring?
    I plan on adding some LED lighting to my Supertop. I plan on tying it into the same circuit as the bed rail lighting. The wiring is not the issue, keeping it neat and OCD acceptable is.
    I run my topper about half the year, so there needs to be a plug to disconnect the upper LED lighting harness from the bed rail lighting harness.
    I HATE the idea of just having/leaving the plug dangle inside the bed. I LOVE the idea of adding some sort of bulkhead where I can unplug the harness from when I take the topper off.
    I thought about using something as simple as a 12v socket (cigarette lighter) and plug since the LEDS draw such low current. I just dislike the idea a big plug sticking out when the lights are plugged in. Ive looked at mil spec style bulkheads, but they seem over kill for a simple 2 wire harness.
    Is anyone else as OCD as I am and figured out a solution to this?
    BHill_teq likes this.
  2. Apr 24, 2017 at 1:24 PM
    #2082
    Khrolar
    Khrolar Well-Known Member
    Vancouver Island
    4 door 2017 trd off-road,
    None... :(
    I used a trailer harness as the plug on mine. But I'm not entirely happy with it.
    What about a USB port mounted into the bedwall, with custom usb cables?
    steveo27[QUOTED] likes this.
  3. Apr 24, 2017 at 1:37 PM
    #2083
    steveo27
    Pittsburgh
    That may be worth exploring.
    Another though I had was a 3.5mm jack.
  4. Apr 24, 2017 at 1:41 PM
    #2084
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Using USB would get you more use out it. The headphone jack would limit you IMHO.
    The hardest part would be sealing the port up when not in use so the weather doesnt ruin it.
  5. Apr 24, 2017 at 2:09 PM
    #2085
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    BHill_teq and Chase8059[QUOTED] like this.
  6. Apr 28, 2017 at 9:56 AM
    #2086
    wyant
    wyant Well-Known Member
    Wyant
    2016 TRD off road DCLB
    Hey guys getting ready to order a soft topper and had a few questions. For those of you that use these to haul your dogs around... Does the black color get really hot inside? I'd like the tan color but it wont really look right with my quicksand truck, black will look best.
    Also can you run these with the sides partially clipped up as long as the back window is rolled up? Im concerned about ventilation for the dog on summer days. Can you achieve highway speeds with everything rolled up (safari mode)?
    Last, do you guys think the extra storage cover is worth it, or is it only worth it if you are going to have the top folded down for long periods of time. I don't think I will need the mesh window unless some of you dog owners think it really helps with ventilation.
    Thanks
  7. Apr 28, 2017 at 10:16 AM
    #2087
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    hot as hell. really fuggin hot
    you can do highway speeds with sides rolled up BUT you must do something extra to
    the 4 corner straps so they do not loosen
    the 4 corner straps are only to hold the softtopper in position when taking up and down,
    the buttoned sides are what actually holds the topper stable when on highway.
    the 4 corner straps are not able to remain tight
    with highway use if the sides are rolled up...you need to use some clamp device on them to keep them solid
    if you want to roll with sides up. I use long thin double-sided velcro strips [for cables] and choke them at the plastic clip so they stay tight
  8. Apr 28, 2017 at 10:25 AM
    #2088
    wyant
    Wyant
    I appreciate the information, that's good to know. I live in the PNW and its not crazy hot here only sometimes in the summer. Is it possible to run the topper kind of like this for extra ventilation? or will this just create a huge kite.upload_2017-4-28_10-24-57.jpg
  9. Apr 28, 2017 at 10:40 AM
    #2089
    Chase8059
    Chase
    ESVA
    Not sure how close you are to ordering but there is a GB set to begin in three days. There is a discount so you might want to head to the group buy section and check it out.
  10. Apr 28, 2017 at 10:41 AM
    #2090
    Chase8059
    Chase
    ESVA
    Got any pictures of how you set this up? This is the first I've seen someone mention this and it's one of the reasons I'm getting a softopper as it looks friggin awesome rolled up.
  11. Apr 28, 2017 at 11:19 AM
    #2091
    wyant
    Wyant
    Thanks man!!
  12. Apr 28, 2017 at 11:45 AM
    #2092
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Power pole connectors with a panel mount on the bed might work.
    https://powerwerx.com/panelpole-panel-mount-powerpole-housing
  13. Apr 28, 2017 at 12:30 PM
    #2093
    steveo27
    Pittsburgh
    Neat. Thanks for the link. I'll have to look into that a bit.
    dilbert likes this.
  14. Apr 28, 2017 at 1:32 PM
    #2094
    dilbert
    dilbert AI Member
    PNW
  15. Apr 28, 2017 at 1:35 PM
    #2095
    wyant
    Wyant
  16. Apr 28, 2017 at 1:44 PM
    #2096
    dilbert
    dilbert AI Member
    PNW
  17. Apr 29, 2017 at 5:32 AM
    #2097
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
  18. Apr 29, 2017 at 9:35 AM
    #2098
    BDub
    BDub Well-Known Member
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
    I just drove mine 80 mph for 7 hours through high winds and storms. No issues.
    Did he have a clamp fail?
  19. Apr 29, 2017 at 1:00 PM
    #2099
    slamson00
    slamson00 Well-Known Member
    Northern California
    2019 Tacoma TRD Off Road DCLB
    Yeah. I need to hear some more details on this. Have never heard of this happening before.
  20. Apr 29, 2017 at 1:34 PM
    #2100
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Just a guess but I suspect he either had it installed incorrectly or there was a freakishly strange wind event. Ive driven at 78 mph in fairly high winds and mine hasn't moved at all.
