Let's See Some Softoppers
Discussion in 'Tonneau Covers, Caps and Shells' started by tcBob, May 13, 2013.
  1. Jul 19, 2017 at 12:22 PM
    #2361
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    That bunching is not nor male as far as I know. Mine doesn't look like that.
  2. Jul 19, 2017 at 12:48 PM
    #2362
    BDub
    BDub Well-Known Member
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
    Is it pushed to far forward? Loosen the front straps a bit to raise the top. Tighten the rear to make up for it. Not sure how much it will adjust.
  3. Jul 19, 2017 at 8:36 PM
    #2363
    BrutalityBob
    BrutalityBob Well-Known Member
    Soft taco supreme
  4. Jul 19, 2017 at 10:25 PM
    #2364
    JARStacoma
    JARStacoma Well-Known Member
    Alaska
    17' inferno TRD OR MT
    Was curious about seam seal on outside as well. I have leaking on front and rear seams and I coated the inside with Seam seal. However I see daylight through some pin holes from seams on inside. Thought about running some sealant on outside of seam. Might be light clear, cream color?
  5. Jul 19, 2017 at 10:29 PM
    #2365
    Khrolar
    Khrolar Well-Known Member
    Vancouver Island
    4 door 2017 trd off-road,
    None... :(
    I put it on the outside of mine, mostly around the clips. It discolored the canvas sightly. But not nearly enough that it is noticed, by Myself or others. Plus it stopped all leaks!
  6. Jul 19, 2017 at 11:56 PM
    #2366
    JARStacoma
    Alaska
    Awesome. I would think the seal on the outside would be more effective over the long run. I will probably do both either way. It's pretty wet up here in coastal Ak.
  7. Jul 20, 2017 at 5:03 AM
    #2367
    BDub
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
    I had to apply a couple liberal coats to the front and rear. No issues now.
  8. Jul 20, 2017 at 7:17 AM
    #2368
    MN_Taco
    MN_Taco Member
    KD
    Minnesota
    2017 TRD Sport Access 4x4 MGM
    I heard back from Bob at softopper and he said not to put it on the outside because it will discolor the canvas. The exception is around the buckles.
    It's been raining here every day and I'm noticing that the inside front top rail area is where a lot of water is getting in. I'm going to reseal again this weekend with a brush instead if the applicator and see if that helps.
  9. Jul 20, 2017 at 2:41 PM
    #2369
    JARStacoma
    Alaska
    Yah. Maybe I'll just reapply with a brush super heavy along front and rear seams. I had a hard time getting under the flaps where the seams come together. Maybe that's where I went wrong. Really don't want any water back there.
  10. Jul 21, 2017 at 11:43 AM
    #2370
    Lumberjackcoma
    Lumberjackcoma Well-Known Member
    Scott
    unknown
    Recently picked up this Softopper, came off a Frontier, however couldn't pass on this deal.
    slamson00, ruffridha9, jjsul and 4 others like this.
  11. Jul 25, 2017 at 10:22 AM
    #2371
    flinky
    flinky Well-Known Member
    2017 Black Tacoma TRD Sport
    BUILD -Window tint back windows -Clear Tint front to reduce heat -Method NV's Matte Black 16" (reduced from stock 17") -Pro grille - Prinsu Roof Rack - 40" Light Bar Cut Out - Prinsu Top Rack - ARE canopy (windoor, sliding window, roof rack) - Prinsu Load panels - Baja Designs Sport Fog lights - 2 tepui awnings LIFT -BFG K02's 265/75/R16 -2" lift 2.0 Fox Coil Overs -2.5" lift 2.0 Fox w/ resi (mounted high/ shock stone guard) -Added extra leaf
    What kind of soft top is this?
  12. Jul 25, 2017 at 11:12 AM
    #2372
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Soft Topper brand.
  13. Jul 26, 2017 at 10:53 AM
    #2373
    MN_Taco
    MN_Taco Member
    KD
    Minnesota
    After another rain last night I located the leaking source. I have water coming in between the front of the bed and sides where there is a gap that the canvas sits over but doesn't seal. We've been getting intense rain and wind and it's enough to get more water than I'd like in the bed.
    Has anyone used extra weather stripping in that area?
    Also, update on the bunched rear window. I removed the window and velcroed it up higher and it sits much better.
  14. Jul 26, 2017 at 6:04 PM
    #2374
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    I had some leakage there and applied some clear silicone. Haven't had another major rain to test it out
    RLW-503ENG likes this.
  15. Jul 27, 2017 at 3:03 PM
    #2375
    BoilerUp
    BoilerUp Well-Known Member
    2004 V6 Double Cab TRD PreRunner
  16. Aug 5, 2017 at 4:06 PM
    #2376
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    You can definitely use weatherstripping like an adhesive foam for sliding doors. I don't get any water intrusion from the area you're talking about - it may be possible that you have adjusted the front window TOO high?
    Lumberjackcoma likes this.
  17. Aug 6, 2017 at 7:53 PM
    #2377
    econwatch
    econwatch Well-Known Member
    Utardia/Kanook Eh
    Naranja 7545
    Softoppers are the best - impervious to cow poop!
  18. Aug 7, 2017 at 10:16 PM
    #2378
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    What's the story here?
  19. Aug 7, 2017 at 10:19 PM
    #2379
    koditten
    Kirk
    Central Michigan
    A cow ran into the truck and shit itself when it realized how awesome Tacoma's are...Duh.:rofl::rofl:
  20. Aug 8, 2017 at 10:50 AM
    #2380
    Spare Parts
    Southern Maine
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    jjsul likes this.
