Let's See Some Softoppers
Discussion in 'Tonneau Covers, Caps and Shells' started by tcBob, May 13, 2013.
  1. Nov 14, 2017 at 5:54 PM
    #2641
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Some crooks aren't that smart. Like busting a window on an unlocked car door to get in.
    Khrolar and koditten[QUOTED] like this.
  2. Nov 14, 2017 at 6:05 PM
    #2642
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    This is true.
  3. Nov 14, 2017 at 6:20 PM
    #2643
    chiago
    chiago Well-Known Member
    Chad
    NJ
    2001 Reg Cab Stepside 4x4
    true... but they still get in.... !!! i personally dont leave anything of worth in the bed... all camping gear, tools, etc gets put into lockable boxes and attached to the ubolts with cable and lock... can they still get into it, sure... but it would take special tools, a lot more time, and make a lot more noise... It will however keep the opportunistic prick from grabbing anything and making a quick or quiet get away....
    koditten likes this.
  4. Nov 14, 2017 at 7:03 PM
    #2644
    koditten
    Kirk
    Central Michigan
    My best investment:
    When parking in a remote location and I know the truck will be unattended for an extended amount of time, I post a game camera in an inconspicuous location.
    So far no issues will the truck being harassed.
    As for security of the soft topper, I don't give it a thought. My previous hard caps were easy to break in to as well.
    It's not good to leave valuables in the bed of any truck.
    jjsul likes this.
  5. Nov 22, 2017 at 4:53 PM
    #2645
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    I'm looking at getting a softopper,
    I have 1 question for now.
    For the flap on the cabin side, how does it secure? I currently have a husky tool box fastened to the front bed rail. Is this gonna be an issue?
    Here is a pic of a similar tool box
  6. Nov 22, 2017 at 4:55 PM
    #2646
    koditten
    Kirk
    Central Michigan
    I doesn't. It just hangs between the cab and the box. The flap on the inside of the box is attached to the box with 3 snaps.
  7. Nov 22, 2017 at 5:03 PM
    #2647
    tacitos
    16 TRDORDCLBJBL
    So how do you attach the snaps to the inside of the box? Do you have to drill in snaps to the bed? What would happen if I didn't have the inside flap secured?
  8. Nov 22, 2017 at 5:07 PM
    #2648
    koditten
    Kirk
    Central Michigan
    I actually tried it. The ST comes with 3 snaps that have sheet metal screws attached. You drive these into the front of the bed. I didn't want to put holes in my bed, so I tried it without attaching the flaps. The front of the ST flopped around and made lots of wind noise. I ended up having no choice and installing the snaps. I don't notice it anymore and I've got over installing the snaps.
  9. Nov 22, 2017 at 5:15 PM
    #2649
    chiago
    Chad
    NJ
    You dont have to attach the front flap with snaps or velcro... . I dont like drilling into my truck and the velcro glue quickly came undone in the summer heat... so i just leave it hanging in place... Ive had my topper for 3-4yrs now and have never had a problem...
  10. Nov 22, 2017 at 5:16 PM
    #2650
    tacitos
    16 TRDORDCLBJBL
    That's interesting, their website says "No need to drill into truck".. kind of misleading.
    So it seems that the front bed rail is now somewhat useless.
  11. Nov 22, 2017 at 5:16 PM
    #2651
    tacitos
    16 TRDORDCLBJBL
    Your response is completely different from @koditten
  12. Nov 22, 2017 at 5:20 PM
    #2652
    koditten
    Kirk
    Central Michigan
    The only thing I can offer is my ST is on my Tundra. I don't know if aerodynamics are different and causing us to have different results. All I know is I didn't want install the snaps, but had no choice.
  13. Nov 22, 2017 at 5:22 PM
    #2653
    chiago
    Chad
    NJ
    Yeah, i just read that.... I dont know what to tell you ... thats my experience and i often run with the sides rolled up... all i can tell you is try it without... if it flops and makes noise try making some adjustments or put the snaps in.... if not, dont worry about it... i think if you have that box secured with a ratchet strap or whatever it would pinch the flap against the truck and youd be fine...
    Edit - maybe i dont have issues because of the stepside rear... the cab is bigger than the bed and probably moves the air past that front flap.. just a thought
  14. Nov 22, 2017 at 5:23 PM
    #2654
    tacitos
    16 TRDORDCLBJBL
    aerodynamics could be different on a Tundra. Thanks for the input.
  15. Nov 22, 2017 at 5:25 PM
    #2655
    tacitos
    16 TRDORDCLBJBL
    I don't want to ratchet strap the box, I have it bolted into the bed rail for security. But if what your saying is correct, it could be fine just hanging there. Thanks for the info.
  16. Nov 22, 2017 at 5:27 PM
    #2656
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Wonder if you could add a brass grommet to each side of the inner flappy and bungee it down to the bottom front corners of the bed?
    Elkhart, tacitos and koditten like this.
  17. Nov 22, 2017 at 5:43 PM
    #2657
    tacitos
    16 TRDORDCLBJBL
    Or like this
  18. Nov 22, 2017 at 5:45 PM
    #2658
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Or like that! :thumbsup:
  19. Nov 22, 2017 at 5:56 PM
    #2659
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Its that way on my Tacoma too. The flap blows into the bed, air flows through the topper, and because it has to go somewhere so it goes out the back. Not good.
  20. Nov 22, 2017 at 5:58 PM
    #2660
    tacitos
    16 TRDORDCLBJBL
