Let's See Some Softoppers
Discussion in 'Tonneau Covers, Caps and Shells' started by tcBob, May 13, 2013.
  1. Oct 16, 2018 at 10:18 AM
    #3741
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Anytime backup camera mod and heated side mirrors works for me. I'm thinking of getting a solid panel for the back with no window for cold weather use so I don't have to worry about damage.
    fmrjeep[QUOTED] likes this.
  2. Oct 16, 2018 at 10:28 AM
    #3742
    fmrjeep
    fmrjeep Well-Known Member
    Northern Utah
    2018 Inferno Tacoma SR5 DCSB
    Black Softtopper Coverking Seat Covers
    That might be the way to go. It is funny because I'm pretty sure I wouldn't have any issues with the solid back window but several years ago was pulled over for not having a drefrosted rear window.
  3. Oct 16, 2018 at 6:02 PM
    #3743
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    You could create an insulating panel out of Reflectix that you can attach to the roll up buckles above the rear window and tuck under the flap below, that would give the vinyl window a bit of thermal protection (very minimal at best), and to keep frost from settling on the surface. Remove it before you drive.
    At home, you can hang a 40W-60W incandescent work light inside the canopy that would give off just enough heat to keep the interior of the bed above freezing.
  4. Oct 20, 2018 at 12:11 PM
    #3744
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    20181020_114705.jpg 20181020_110746.jpg 20181020_110644.jpg Here's mine,just finished installing this morning . Haven't worked out the creases yet .
  5. Oct 21, 2018 at 11:24 AM
    #3745
    Ben_B_Rad
    Ben_B_Rad Active Member
    2017 DCLB Off Road
    Super easy to install
    bulalo likes this.
  6. Oct 22, 2018 at 12:09 PM
    #3746
    Robjob
    Robjob Active Member
    2017 TRDORQS
    Needs a little adjustment yet but went on easy enough
    medicfung, Thunder Fist and bulalo like this.
  7. Oct 24, 2018 at 12:27 AM
    #3747
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Modded my softopper yesterday. Added some 4’ x 6’ silver insulation foam from homedepot under the roof of the topper sandwiched between the top tubes . It took care of the in your face/ head radiant heat when I’m inside the truck bed when the truck is parked under the sun . Makes a Huge difference . Will update with pics in am.
  8. Oct 24, 2018 at 9:27 AM
    #3748
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Heres the pic
  9. Oct 26, 2018 at 10:34 AM
    #3749
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    One more reason why I love this topper!
    AFfmWRk3_w8EsCvkNQFWgNu1Blce-opeEJvg1vY0_f0e1f53fdf67041f4754302c92e9ce552af3f2b2.jpg
  10. Oct 31, 2018 at 9:15 AM
    #3750
    IowaQuicksand
    IowaQuicksand Well-Known Member
    Iowa
    18 Quicksand DCSB OR 6MT
    Thinking of purchasing and curious what everybody does with them at a car wash?
  11. Oct 31, 2018 at 9:30 AM
    #3751
    dilbert
    dilbert AI Member
    PNW
    I take it through the touch free carwash with no issues.
    doublethebass likes this.
  12. Oct 31, 2018 at 9:52 AM
    #3752
    IowaQuicksand
    Iowa
    I didn't know if it would soak your bed or anything
  13. Oct 31, 2018 at 9:59 AM
    #3753
    dilbert
    dilbert AI Member
    PNW
    Maybe a drip or two down the bed sides. It usually stays dry.
  14. Oct 31, 2018 at 10:14 AM
    #3754
    IowaQuicksand
    Iowa
    Awesome
  15. Oct 31, 2018 at 10:31 AM
    #3755
    tn111
    tn111 Well-Known Member
    2018 TRD Sport 4x4 MT
    Where are you all ordering your softoppers from? Directly through them? This is the only place I’ve been able to find them
  16. Oct 31, 2018 at 10:34 AM
    #3756
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    Yup. I don't believe they have any distributors
    tn111[QUOTED] likes this.
  17. Oct 31, 2018 at 12:22 PM
    #3757
    fmrjeep
    Northern Utah
    If you seam seal it you shouldn't have too much trouble. I get water in around some of the bed openings, but not much through the softopper.
  18. Oct 31, 2018 at 12:46 PM
    #3758
    tn111
    Got it. Kind of what I figured. Thanks!
    90yota[QUOTED] likes this.
  19. Oct 31, 2018 at 5:16 PM
    #3759
    RickyTaco77
    RickyTaco77 Well-Known Member
    Steven
    Gastonia, NC
    2016 TRD Off Road 4x4/ 1995 4runner 4x4
    If you want to put you roof top tent under your topper then these bars are made for that. $325.00 plus shipping.
    mcharfauros and koditten like this.
  20. Oct 31, 2018 at 5:17 PM
    #3760
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Awesome! You are gonna be busy.
