Let's See Some Softoppers
Discussion in 'Tonneau Covers, Caps and Shells' started by tcBob, May 13, 2013.
  1. Jul 11, 2019 at 8:21 PM
    #4541
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    Random thought.. could you connect into the trailer light ports?
  2. Jul 11, 2019 at 8:29 PM
    #4542
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Mines about like that. I can fold it in like that.
  3. Jul 11, 2019 at 8:29 PM
    #4543
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    ^interesting in dry season
  4. Jul 13, 2019 at 7:12 AM
    #4544
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    My OCD got the best of me. Went in took out the positaps. Went and soldered it instead.
    mcharfauros and Jeffvt0508 like this.
  5. Jul 15, 2019 at 7:57 PM
    #4545
    2ndGenOffRoad
    2ndGenOffRoad Well-Known Member
    Los Angeles, CA
    '14 SBDC OffRoad 4x4 '84 4Runner 22RE
    Schmell Fab Sliders ATH Fab Rear Bumper Icon Stage 3 Suspension Front Runner Outfitters Roof Rack Softopper Bed Cover 285/70/17 KM3's on T4R Pro Wheels
    I like this, mine is flapping in the wind and it drives me crazy.
    Anyone else have this problem?
    mcharfauros likes this.
  6. Jul 15, 2019 at 8:34 PM
    #4546
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Magnets. I used flexible strip magnet combined with Velcro. The adhesive failed in the heat from last week but i reused them both with 3m double sided tape. No more flapping
  7. Jul 15, 2019 at 8:35 PM
    #4547
    2ndGenOffRoad
    Los Angeles, CA
    Just got enough pages back, and saw all the posts, Heading to the hardware store.
    I also need to pick up a straight pole for my 2nd gen, my softopper currently has the bent pole for the 3rd gen.
  8. Jul 15, 2019 at 8:43 PM
    #4548
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
  9. Jul 15, 2019 at 8:43 PM
    #4549
    GHOST SHIP
    GHOST
    I might have enough aluminum tube left over from my fix. I can check tomorrow but if you’re coming by this weekend I can hook you up.
  10. Jul 15, 2019 at 9:13 PM
    #4550
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
  11. Jul 15, 2019 at 9:18 PM
    #4551
    2ndGenOffRoad
    Los Angeles, CA
    Ok, sweet man. I want to try and use the 3rd gen retainer brackets. Figured cut a piece of tubing and shove the 3rd gen connector tips into the it. I'll hold off till I come over this weekend
  12. Jul 15, 2019 at 9:42 PM
    #4552
    GHOST SHIP
    GHOST
    That’s exactly what I did. Work fine.
  13. Jul 18, 2019 at 7:44 AM
    #4553
    Jeffvt0508
    Jeff
    Anderson, SC
    One last and final question when you soldered into your tail light wires how or what method did you use to waterproof that??
  14. Jul 18, 2019 at 8:10 AM
    #4554
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Marine grade heat shrink tubing. It has an adhesive inside that makes it very water resistant.
    RangerComa likes this.
  15. Jul 18, 2019 at 8:33 AM
    #4555
    Jeffvt0508
    Jeff
    Anderson, SC
    Im soldering into my factory wires so I won't be able to slide heat shrink onto that wire
  16. Jul 18, 2019 at 12:24 PM
    #4556
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What I’ve done in the past for a situation like this is cut the wire you’re trying to tap into, slide the heat shrink on, and resolder it. Then solder a second time to get the new wire tapped into it. Sure you could maybe solder it all at once but I found it’s easier this way.
  17. Jul 18, 2019 at 6:20 PM
    #4557
    slowlane
    AZ
    16 double cab MGM
    No worries man. I used shrink wrap and temporarily its wrapped in electrical tape. I'm going to redo it with tessa tape.
  18. Jul 18, 2019 at 6:57 PM
    #4558
    slowlane
    AZ
    16 double cab MGM
    Not sure if its waterproof enough. Let's hope so....:annoyed:
  19. Jul 18, 2019 at 7:04 PM
    #4559
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
  20. Jul 19, 2019 at 10:45 AM
    #4560
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    Can I join the party?
    From the looks of others, I think mine might be too far forward?
    BigEasy, Siebermd, BloodyTaco and 6 others like this.
