Let's See Some Softoppers
Discussion in 'Tonneau Covers, Caps and Shells' started by tcBob, May 13, 2013.
  1. Nov 21, 2019 at 10:53 AM
    #4921
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Yes, you can buy a screen for the rear.
  2. Nov 21, 2019 at 10:54 AM
    #4922
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Good to see you where able to answer your own questions. As long as the topper is still in good or better condition, I’d say that price is quite fair. Never hurts to haggle, but even at asking price your in good shape.
    disconnected[QUOTED] likes this.
  3. Nov 21, 2019 at 1:40 PM
    #4923
    LukaszK
    LukaszK Well-Known Member
    Lukasz
    Elmwood Park, NJ
    2020 Tacoma DCSB Cement Grey
    Question for all current Softopper owners. Has anyone successfully replaced the buckles on the Softopper itself? If so, what buckles did you use and how did you go about it?
    I know that sea to summit buckles work but was curious if there are any other options.
  4. Nov 21, 2019 at 3:54 PM
    #4924
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Has anyone with a long bed softopper noticed this? The metal pin holding the frame together in the middle is trying to poke through the canvas. Im not concerned with how it looks, but more concerned about it potentially wearing a hole in the canvas over time. Curous if this is normal? I also have a softopper on my short bed taco, and it doesnt have this issue, only on the long bed. Just got the long bed topper recently and am just wondering if this is normal? its on both sides
    heres the pin with the side rolled up. Can even see where its been rubbing
    disconnected likes this.
  5. Nov 23, 2019 at 4:53 PM
    #4925
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    I need to replace one of mine. I think ST sells replacement buckles for 2 bucks I think.
    Edit - found the like https://www.softopper.com/accessories-parts/replacement-parts/replacement-buckle-set
    LukaszK[QUOTED] likes this.
  6. Nov 23, 2019 at 6:20 PM
    #4926
    LukaszK
    Lukasz
    Elmwood Park, NJ
    Wow thank you so much! What’s funny is I spoke to a Softopper rep months ago about them having replacement ones and I actually sent them a link to those exact buckles lol I couldn’t buy them because the minimum order was 2000 pieces so I wonder if he passed along the idea to anyone over there. Regardless this is perfect ordering now!
  7. Nov 24, 2019 at 7:26 AM
    #4927
    slowlane
    AZ
    16 double cab MGM
    Mine is about three years old and does the same thing. No sign of tearing or ripping.
    You can put a small strip of duct tape over the rivet. That should give it a little more protection.
    BassAckwards[QUOTED] likes this.
  8. Nov 24, 2019 at 1:32 PM
    #4928
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Thinking about getting one for my truck, but I've got a few questions:
    (1) Is the Softopper waterproof or "just" water resistant? Any issues with condensation and/or the straps getting soaked?
    (2) How often are you re-sealing the seams? Once per year?
    (3) How's the heat inside the bed on a 90+ degree day with the black topper?
    (4) How's the durability on the front/rear vinyl windows? Do they need to be replaced relatively often, or are they relatively long-lasting?
    (5) Is it possible to "stack" the windows so that you can run the mesh window under the vinyl window? Or is it just one or the other?
    jre32 likes this.
  9. Nov 24, 2019 at 2:28 PM
    #4929
    slowlane
    AZ
    16 double cab MGM
    @essjay hope this helps.
    (1) Is the Softopper waterproof or "just" water resistant? Any issues with condensation and/or the straps getting soaked? - good luck getting it water proof. Water resistant is more appropriate. I've seen some people try to weather proof some of the openings, dont know how well its worked. I've washed the truck at a coin pressure wash place and did not notice alot of water in the bed.
    (2) How often are you re-sealing the seams? Once per year? I think the guy I bought it from did it once. I've never done it. But in az we dont get alot of rain.
    (3) How's the heat inside the bed on a 90+ degree day with the black topper? - it can get pretty toasty in the topper. I've seen some people put reflective windshield cover type material to help bring temps down.
    (4) How's the durability on the front/rear vinyl windows? Do they need to be replaced relatively often, or are they relatively long-lasting? - I think if you live in cold climate the windows can crack. Mine is three ish years old. It's still very clear.
    (5) Is it possible to "stack" the windows so that you can run the mesh window under the vinyl window? Or is it just one or the other - I dont think you can stack the mesh aand window flaps. It zips on the side so you can only have one on.
  10. Nov 24, 2019 at 2:29 PM
    #4930
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    1. The actual material is water proof. Its the same as a boat top. It breathes enough that you don't have to worry about condensation. The water can get in the corners and such depending on how you set it. If you can see light. Then water can come that way. Its very adjustable to get it where you want it though.
    2. Re-sealing. Once a year is a good bet. Mine is 3yrs old and I haven't re sealed. But I do need to, small drops at the stitching in heavy South Florida rains.
    3. The heat inside is well, hot. The biggest change was when I added that flexible insulation on the top. Between the frame and top material. Drops the inside temp A LOT. Plus its flexible and folds up with top as needed.
    4. Durability. Very. Just as advised dont try to roll or fold when its very cold out.
    5. No, cannot stack. One or the other. Window and mesh is sewn into whole panel.
  11. Nov 24, 2019 at 2:37 PM
    #4931
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    I did the 3rd brake like mod today too.
    Here's a pic of that and my insulation.
    hxqgeNCRt4_KovcMZxWWn0LBGfH5IP4HNNn8AF6f_033ee32ea921ae7e8ca628ca10be015f842079a4.jpg
    YFmyYhkJjtL2FXEoxEBHLFCQ3_5ERqVGlqUYaPzg_8ad24e55809075b19ac07cca621098e42f175c2f.jpg
    uploadadventure and slowlane like this.
  12. Nov 24, 2019 at 8:43 PM
    #4932
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Looked through quite a few posts, and didn't see any tan softtoppers on a silver 2nd gen. Anyone got pictures? I'm trying to decide between black and tan....
  13. Nov 25, 2019 at 7:55 PM
    #4933
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
  14. Nov 25, 2019 at 10:02 PM
    #4934
    _just.kev
    _just.kev Well-Known Member
    19 Tacoma OR DCSB
    Is there like 2nd gen or something of these?
    I found one, but the rear lid/panel seems like it’s shorter.
    looky here
    Vs
    this.
    Is it that it may be tucked in or maybe the position is off?
    this one also seems to sit up higher by the cabin. as if it’s a 2nd gen Tacoma version.
    I, personally, like how it looks with the longer panel. especially if it were to rain.
    Onwarrds likes this.
  15. Nov 26, 2019 at 2:04 PM
    #4935
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    2nd Gens to sit different on the 3rd gens. They will be taller on the 3rd. Since the 3rd has taller sides from the factory, the 2nd gen is already built taller. Which can pull the rear flap off the 3rd in the rear.
    But if the 2nd gen one is cheap enough, then it might be a good deal?!?
    _just.kev likes this.
  16. Nov 26, 2019 at 7:08 PM
    #4936
    2ndGenOffRoad
    2ndGenOffRoad Well-Known Member
    Los Angeles, CA
    '14 SBDC OffRoad 4x4 '84 4Runner 22RE
    Schmell Fab Sliders ATH Fab Rear Bumper Icon Stage 3 Suspension Front Runner Outfitters Roof Rack Softopper Bed Cover 285/70/17 KM3's on T4R Pro Wheels
    Does anyone have the link for the rubber stoppers you can put on the rear flap pole to keep it from sliding when it's rolled up. I know it was on here, but I've searched many pages and cant find it.
  17. Nov 26, 2019 at 7:14 PM
    #4937
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Rubber stopper? I remember seeing a few used hose clamps or something of the sorts. Found a mention. Rubber grommets put on.
  18. Nov 26, 2019 at 7:20 PM
    #4938
    2ndGenOffRoad
    Los Angeles, CA
    BassAckwards likes this.
  19. Nov 26, 2019 at 8:27 PM
    #4939
    _just.kev
    19 Tacoma OR DCSB
    Thanks for the reply, but I do understand that. I’m just curious about the rear “flap”. The first picture I posted seems to be too short and doesnt extend like the one in second picture.
    I’m beginning to think they just tucked it into the bed. I’ve read more than a few have tucked in that flap for whatever reason, instead of having it out. But even in those pictures, it didn’t look like that.
  20. Nov 26, 2019 at 9:05 PM
    #4940
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Doesnt look tucked. Looks like a 2nd gen on a 3rd gen. There's probably a pic or two of that setup somewhere in this thread.
