Let's See Some Softoppers
Discussion in 'Tonneau Covers, Caps and Shells' started by tcBob, May 13, 2013.
  1. Feb 9, 2020 at 9:04 PM
    #5041
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    I drive normally. Dont notice any issues. However, I am a short bed. You being long bed, get some extra clamps. In this thread there was a guy who's long bed decided to 'taco' itself up.
  2. Feb 9, 2020 at 10:34 PM
    #5042
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I recently built an exocage around my softtopper. It worked out good because the main braces go through the velcro window.
  3. Feb 10, 2020 at 3:48 AM
    #5043
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Uhhhh....that's pretty bad ass.
    deeezy[QUOTED] likes this.
  4. Feb 10, 2020 at 6:22 AM
    #5044
    32vsnake
    32vsnake Well-Known Member
    Mill Bay BC
    2019 TRD OffRoad AC M/T
    Any issues or concerns so far with the bestop?
  5. Feb 10, 2020 at 6:29 AM
    #5045
    TacomaMike25
    TacomaMike25 Well-Known Member
    2012 Tacoma SR5 4cyl 4x4
    2 inch lift, Level 8 Mk6 wheels 16x8 with a 275/85r16, Aftermarket fogs with yellow bulbs, AVS bug deflector, Weather Rain guards, secondary air filter delete. PIAA halogen bulbs
    i am that guy lol, I added two extra clamps and its been a year without issue besides some small cuts from road debris
  6. Feb 10, 2020 at 9:06 AM
    #5046
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Not really anything big. Ive had it on just for the winter now and the few things I have noticed are -
    -Putting it on in the cold is hard, the material doesnt stretch when cold... but this is expected
    -Heavy snowfall builds up between the rear of the cab and the front of the topped, you need a snow brush to pull it out otherwise it blocks the window, melts and turns into a big ice block that WILL break your window when the frame flexes.
    -After washing, the tailgate will freeze to the bar that seals the rear window area. You just need to open the tailgate after washing and let it dry off before closing it.
    -The zippers for the topper are designed pretty bad, there is a flap that covers the zippers, but the flap is too tight to get your hands in there to put the zipper together. This could of been fixed if they had used double sided zipper pulls so you could put them on from the inside
    Some of these things listed are also common on fiberglass toppers and softopper too.
    This summer I should be able to get a better opinion on it, but so far this thing has been great, the fit and finish is A+, if I was putting it up and down every other day, I would of considered the softopper because its easier to do, but since I dont plan to put it up and down that often, the solid fit of the bestop is much better than the softopper. Even when all the way down, the rails on the bestop are much better to look at than the chrome square tube that softopper used. Also when You have the sides and rear window removed for "safari" mode, the bestop looks much better as you are removing the sides completely instead of just rolling it up like the softopper.
    GQ7227 and 32vsnake[QUOTED] like this.
  7. Feb 10, 2020 at 10:43 AM
    #5047
    Ejpiv
    Ejpiv Member
    Montgomery County, MD
    2020 DCLB Off Road
    This has probably been asked, but how do you stop the leaks in the front corners of the bed? Seems to be the only place where water gets in on mine.
  8. Feb 10, 2020 at 10:48 AM
    #5048
    5nahalf
    Erik
    Minnesota
    Im not sure where it is, but someone 3d printed cap extensions that fill in the space in the header rail. But you can also do it with some rubber door seals.
  9. Feb 10, 2020 at 11:26 AM
    #5049
    slowlane
    AZ
    16 double cab MGM
    Preventing water from getting inside the bed with the softopper seems like an almost impossible task.
    Granted I live in Az so we dont get alot of rain, but I've washed the taco with the topper on and do not notice "alot" of water in the bed. Def not enough water to wear I have to try and drain it out.
    I wouldn't worry about water unless you live in very wet climate or you have important stuff in the bed.
  10. Feb 10, 2020 at 12:12 PM
    #5050
    mjs90
    mjs90 Well-Known Member
    Los Angeles
    ‘18 2.7 AC 4x4
    I camped during a heavy downpour in Yosemite last May and nothing got in. Driving through that it only got in and trickled a little in the front corners of the bed, but that went right under the bed mat
  11. Feb 10, 2020 at 12:57 PM
    #5051
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Where are you seeing that it sticks up over the cab? Mine doesn’t.
  12. Feb 10, 2020 at 1:10 PM
    #5052
    jjeffries4
    jjeffries4 Member
    Kyle
    2015 Tacoma-TRD Off-Road
    Is that the suggested "2nd Gen" top?
  13. Feb 10, 2020 at 1:11 PM
    #5053
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yep!
  14. Feb 10, 2020 at 5:54 PM
    #5054
    TacomaMike25
    When I installed mine I moved it closer towards the cab and made sure when it was on you could not see out of the corner where the velcro flaps are towards the front. Mine has been leak free.
    if you look at how the corner flaps are on mine you can see it overlaps the first snap a good bit. When you look inside your topper at the corner you should aim to have it so you cant see light outside. I adjusted mine a few times.
    RangerComa likes this.
  15. Feb 10, 2020 at 7:46 PM
    #5055
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Never had any issues. Been up to 90 with mine.
    GQ7227 likes this.
  16. Feb 11, 2020 at 5:28 AM
    #5056
    Ejpiv
    Ejpiv Member
    2020 DCLB Off Road
    Thanks, I'll give that a try.
  17. Feb 11, 2020 at 1:05 PM
    #5057
    N8tiveTaco21
    N8tiveTaco21 Well-Known Member
    Central Washington
    '10 TRD OR
    OME Dakar leaves, 886 springs, SPC UCAs, Softtopper, GFC Superlite, Caliraised Rock sliders, 4.56 regear w/ Eaton Elocker
    Just finished putting mine on! Digging the white/ tan combo.CE1653ED-24BA-4562-87E7-6DA69A02CCC8.jpg
    RangerComa and Sideways1 like this.
  18. Feb 12, 2020 at 10:01 AM
    #5058
    GQ7227
    GQ7227 mw survivor
    J A Y
    i must get me a softopper so can sleep in back and not get rained on!
  19. Feb 12, 2020 at 11:40 AM
    #5059
    uploadadventure
    Dixon, Mo
    There you go! Do it!
  20. Feb 12, 2020 at 11:46 AM
    #5060
    GQ7227
    GQ7227 mw survivor
    J A Y
    my tacoma is on a 'budget', the budget went WAY over last year
    and have a few things of concern looming on the horizon currently
