Let's See Some Softoppers
Discussion in 'Tonneau Covers, Caps and Shells' started by tcBob, May 13, 2013.
  1. Nov 29, 2020 at 12:04 PM
    #5801
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    are your mounting bars on the bed sides equal lengths back from the cab? If one is further back that would explain why only one corner might show this.
    doublethebass likes this.
  2. Nov 29, 2020 at 12:08 PM
    #5802
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    It almost looks like your driver side front might be too tight compared to the passenger side. When I am re-adjusting mine after removing it I pull both down tight until the topper is not tight then slowly let them all up until it tightens.
  3. Nov 29, 2020 at 12:11 PM
    #5803
    MNTTRD
    MNTTRD Well-Known Member
    Shane
    Waterford, VA
    2021 Tacoma TRD Pro Lunar Rock MT
    They are def identical. This is the first thing I checked along with the rail distances from the inside of the cab.
  4. Nov 29, 2020 at 12:13 PM
    #5804
    MNTTRD
    Shane
    Waterford, VA
    I will try that. The tops is also brand new and maybe will work itself out over time. The wrinkle goes away if i pull up on the top corner near the cab.
  5. Nov 29, 2020 at 12:16 PM
    #5805
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    Yeah from the factory it should be fairly tight and will loosen over time but shouldn't have a wrinkle like that in it. I would assume one corner is not all the way loose enough to pick up that little bit of slack causing the wrinkle.
    Also your eyes may deceive you into thinking one side is higher with the taco lean. My truck leans pretty good and it throws off my eyes every time as to what "looks level" which is why I go to the pull it till the topper is loose then back them out till its tight and leave it.
  6. Nov 30, 2020 at 2:06 PM
    #5806
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    Finally got mine on. Just in time to get me through the winter months.
    Stoic_BV, rlx02, CCWTaco and 5 others like this.
  7. Dec 1, 2020 at 8:40 AM
    #5807
    TravElliott
    TravElliott Well-Known Member
    Trav
    2015 Tacoma TRD
    Hey yall, new to the thread. Found a soft topper for pretty cheap locally. Looking for some solutions to the RTT since its currently mounted above the bed. I would need larger/taller rack bars. any suggestions
  8. Dec 1, 2020 at 8:49 AM
    #5808
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    There are a few companies that make racks specifically designed to go over a softopper. Mobtown offroad is one of them.
    https://mobtownoffroad.com/product/2005-2020-toyota-tacoma-softopper-bed-rack/
    NateJ, HandOfGod, essjay and 3 others like this.
  9. Dec 1, 2020 at 8:53 AM
    #5809
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  10. Dec 6, 2020 at 5:08 AM
    #5810
    WeDoPullups
    WeDoPullups Well-Known Member
    2020 TRD 4x4
    Molle racks, will they still mount on the inside with a softopper?
  11. Dec 6, 2020 at 6:31 AM
    #5811
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I'm about to find out. I don't see why they wouldn't as they hang below the rail and you can move the clamps wherever you need to
  12. Dec 6, 2020 at 6:44 AM
    #5812
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Only thing I can think of is the topper frame right below the swivel point, is what would prevent a molle panel from being mounted. I would check how far away the molle panel is mounted and how far away the topper below the swivel is from the bed.
  13. Dec 6, 2020 at 6:59 PM
    #5813
    Ncpi007
    Ncpi007 Well-Known Member
    Charlotte, NC
    2018 Tacoma TRD Off-Road
  14. Dec 6, 2020 at 7:06 PM
    #5814
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No. There was one thread linked in here a few weeks ago from March and that’s it. I already mentioned that was when the rack was rolled out and it was growing pains. They’ve sent out plenty of racks since then with no issues. Don’t say “really bad reviews” unless you can back that up.
    Lead times are on par with most everyone else too.
  15. Dec 6, 2020 at 7:09 PM
    #5815
    Ncpi007
    Charlotte, NC
    Okay, one thread with several people having issues. Sorry. Glad they worked the issues out.
  16. Dec 6, 2020 at 7:20 PM
    #5816
    Clayfri77
    Clayfri77 Well-Known Member
    05 Tacoma TRD-Off Road
    Hi everyone! What model of soft topper do you think is best for an 05 Tacoma? Should I get a 2nd gen one or a 3rd generation with a 2nd gen tailgate bar? Doesn't the 3rd gen fit better? What is everyone's thoughts
  17. Dec 6, 2020 at 11:18 PM
    #5817
    TACOROSSO
    TACOROSSO Well-Known Member
    2017 SR 4x4 5spd
    they just make one softopper for trucks 2005+. you’re likely comparing the older version to the current design, which was updated a few years ago.
    and AFAIK the rear panel hardware is only different for the 3rd gen trucks with a 5’ bed, everything else has the straight bar.
  18. Dec 7, 2020 at 1:49 AM
    #5818
    WeDoPullups
    2020 TRD 4x4
    Keep us updated friend
  19. Dec 7, 2020 at 7:26 AM
    #5819
    Clayfri77
    Oh ok Tacorosso! That was what I was wondering thank you..
  20. Dec 8, 2020 at 8:27 AM
    #5820
    EastVan
    EastVan Well-Known Member
    BC, Canada
    '21 TRD Sport DCSB 6MT Voodoo Blue
    How are people attaching and dealing with magnets. I assume glue them onto the velcro strip on the cover? And then do you put anything on the magnet to avoid scratching paint on the tailgate? Ordered my topper his morning!
    thanks!
    Edit: I guess something like this?
    WestCoastBestCoast Broke For Now Build
