Let's See Some Softoppers
Discussion in 'Tonneau Covers, Caps and Shells' started by tcBob, May 13, 2013.
  1. Apr 12, 2021 at 7:35 AM
    #6181
    str8edgMTBMXer
    str8edgMTBMXer Well-Known Member
    Central Ohio
    2021 SR5 DCLB; midnight black metallic
    I have a black 2021 SR5 DCLB, and am thinking that the tan might actually look the best. I don't want black b/c of the additional heat factor as mentioned.
    anyone have pics of black truck, tan covers?
    Siebermd likes this.
  2. Apr 12, 2021 at 8:22 AM
    #6182
    BigEasy
    BigEasy Well-Known Member
    Rob
    PNW
    2020 Tacoma TRD/OR DCLB
    Nada
    Mine is on order... So more to be revealed... Will definitely update once received and installed
  3. Apr 12, 2021 at 8:26 AM
    #6183
    BigEasy
    Rob
    PNW
    Nada
    Here is an image from search for "black Tacoma tan softopper"...
  4. Apr 12, 2021 at 9:19 AM
    #6184
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    I have a 4X Innovations hi lift bracket in the bed rail and I can fold open and close the topper, there’s just enough room. You gotta make sure the hi lift is moved far enough forward to clear the topper frame when it folds.
    https://www.4xinnovations.com/2005--2021-Tacoma-Hi-Lift-Bed-Mounts_p_41.html
    A60F5F34-E46A-41E0-8BE8-45F9DE2F9719.jpg FA2DE798-C0AF-4843-9E01-161A574AD548.jpg
  5. Apr 12, 2021 at 9:37 AM
    #6185
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
  6. Apr 12, 2021 at 9:40 AM
    #6186
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    Here's mine
    E-Paz 732NJ, 4x4spiegel and BigEasy like this.
  7. Apr 12, 2021 at 12:59 PM
    #6187
    Dr3wcifer
    Dr3wcifer Well-Known Member
    2020 TRD OR Manual
    Okay, so a while ago I said I was going to build a skirt out of matching material to the topper... Well, with zero skills and nearly no understanding of sewing, here's the progress so far...
    The general design - super artistic, I know. The end design actually covers the whole tailgate to make sure there's no water that can get in.
    So then I decided to draft up a really professional design.
    And yesterday I patterned it out and did the initial cut. This morning I did the adhesives to create good, strong edges. I'm getting ready to sew and add webbing loops for mounting, and add the rest of the velcro to interface with the existing softopper.
    The lead ingots are for putting weight on the adhesives to ensure a good bond across the edges before sewing to get the final setup.
    gilligoon, D-FENS, abacall and 10 others like this.
  8. Apr 12, 2021 at 1:23 PM
    #6188
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    I have the tan. I chose it for both the looks on Barcelona Red and to better reflect the sunshine. I also added a layer of thermo-reflective bubble insulation between the canvas and the frame tubes in the ceiling. I left it long in the rear so it can also come down and shade the rear window when parked. It stays rolled up and out of the way when driving.
    I'll have to get a better photo of the insulation itself, but maybe you can just see it at the top of the rear window in this photo:
    Edit: Nope, can't see it. Didn't know until I posted it up. I'll try to snag a better one later...
  9. Apr 12, 2021 at 4:43 PM
    #6189
    str8edgMTBMXer
    Central Ohio
    awesome!! that does not look bad...
    how is it in the summer? I have seen a few others with the insulation in it as well...
    BigEasy[QUOTED] likes this.
  10. Apr 12, 2021 at 6:19 PM
    #6190
    Dr3wcifer
    2020 TRD OR Manual
    Progress? It needs some refinement to take out a bit of slack, and I need to build the webbing tie downs to secure it all, but it's getting there.
    Urkle86, D-FENS, E-Paz 732NJ and 12 others like this.
  11. Apr 12, 2021 at 6:58 PM
    #6191
    powder1134
    powder1134 Well-Known Member
    2014 Tacoma TRD Off Road
    :popcorn::popcorn:
  12. Apr 13, 2021 at 3:37 PM
    #6192
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Anybody use a roadhouse tarp with the softopper? Really thinking about getting one of those
    D-FENS and BigEasy like this.
  13. Apr 13, 2021 at 3:52 PM
    #6193
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I did the same thing. Do you find it's cooler in the summer in addition to warmer in the winter?
  14. Apr 13, 2021 at 5:45 PM
    #6194
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    My tan is much cooler. But the insulation helps a ton.
  15. Apr 13, 2021 at 6:03 PM
    #6195
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
  16. Apr 13, 2021 at 6:34 PM
    #6196
    kas2828
    kas2828 Well-Known Member
    Austin
    Arizona
    2020 TRD Off-road 4x4 DCLB
    Thank you for responding. I figured it would be good but wanted to check before trying.
  17. Apr 13, 2021 at 8:08 PM
    #6197
    str8edgMTBMXer
    Central Ohio
    sweet!! with the matching dirt too...love it
    I think I am sold on the black and tan...
    BigEasy and essjay[QUOTED] like this.
  18. Apr 14, 2021 at 9:34 AM
    #6198
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    What is the best method to secure the front flap? My understanding is that the supplied velcro is no bueno. Are most drilling in snap screws?
    BigEasy likes this.
  19. Apr 14, 2021 at 9:41 AM
    #6199
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    I drilled in 2 snap screws (didnt place the center 3rd snap screw) Only issue I have had is when I got a crazy hard cross wind exactly perfect the middle flipped inside the bed. I think that's only happened like once though. It was raining that drive so I just pulled over at the next exit and reached through the back window and pulled it back into place. Didn't have an issue after that. the two snaps are easy to reach when taking the topper off and on and I dont have to worry about reaching the center one.
  20. Apr 14, 2021 at 10:21 AM
    #6200
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Yup (at least I did, anyways)
