Let's See Some Softoppers
Discussion in 'Tonneau Covers, Caps and Shells' started by tcBob, May 13, 2013.
  1. Jul 12, 2022 at 8:46 PM
    #7241
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    I was using the same ones for close to six months, but they rotted away. Broke down and bought a couple of stainless steel hose clamps. They don't look anywhere near as cool, but they're definitely not going to rot.
    CAG Gonzo likes this.
  2. Jul 12, 2022 at 9:46 PM
    #7242
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Good idea. One of mine rotted in this damn desert heat and I noticed its absence since the bar slides once more.
    jackn7[QUOTED] likes this.
  3. Jul 20, 2022 at 10:52 AM
    #7243
    E-Paz 732NJ
    E-Paz 732NJ Well-Known Member
    Eric
    NJ
    2015 Tacoma TRD-OR
    whats the best way to clean the back window?
  4. Jul 20, 2022 at 11:12 AM
    #7244
    hxp05560
    hxp05560 Well-Known Member
    2009 TRD Off-Road
    TRD Pro Wheels - Duratracs Black Softopper
    I use windex and a paper towel as needed. Power wash it with the rest of the truck when I go to the car wash.
    jackn7 likes this.
  5. Jul 20, 2022 at 3:11 PM
    #7245
    Brex69
    Brex69 Well-Known Member
    2023 Lunar Rock DC LB Off Road
    One thing that kind of bugged me about having a Softopper was losing the bed rail as a way to mount/store tools, the tops arms and clamps block off most of the rail so I used a piece of unistrut and spaced it away from the arms and clamps.
    Now I have a place to mount my shovel, axe and other stuff.
    jackn7 and doublethebass like this.
  6. Jul 20, 2022 at 4:06 PM
    #7246
    powder1134
    powder1134 Well-Known Member
    2014 Tacoma TRD Off Road
    Good idea! I used a couple spacers to push my mount out beyond the clamps.
    For lighter things I made these clamp on mounts out of pvc. They snap right onto the softopper bars, and if I need them more secure I'll wrap a couple zip ties around them making them semi permanent. 20210128_120928.jpg 20210128_120353.jpg
  7. Jul 20, 2022 at 4:11 PM
    #7247
    Brex69
    Mounting to the bars is a good idea for light stuff, gunna order more Quick Fists now
    jackn7 and powder1134[QUOTED] like this.
  8. Jul 20, 2022 at 4:19 PM
    #7248
    powder1134
    They work great for the dead space on the ceiling. That's when I use the zip ties and everything stays put.
  9. Jul 20, 2022 at 5:12 PM
    #7249
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Do you guys recommend a certain fan to use while sleeping? Just got back from a trip and it was hot in there. Didn't have my mosquito net to drape over the soft topper, and there was a ton of bugs outside. Needed some air circulation inside
  10. Jul 20, 2022 at 5:32 PM
    #7250
    powder1134
    I use one of those goofy rechargeable neck fans i got off Amazon. It lives in the cargo net on the ceiling. Has 3 speeds, lights up, and the 2 little fans are on flexible arms so super flexible.
    https://www.amazon.com/dp/B07VHP682L
    Not the fanciest of set ups but it does the trick. I've also put it above/ behind my buddy heater to move the heat around.
    jackn7 and TartanEagle like this.
  11. Jul 21, 2022 at 12:39 PM
    #7251
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    This is a pretty cool idea! Hope you don't mind me borrowing that one.
  12. Jul 21, 2022 at 12:40 PM
    #7252
    powder1134
    It's all yours. That's what this forum is all about.
    TartanEagle and jackn7[QUOTED] like this.
  13. Jul 21, 2022 at 6:11 PM
    #7253
    monty186
    monty186 Member
    How do you clean the softopper window closest to the cab?
  14. Jul 21, 2022 at 10:05 PM
    #7254
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    To be quite honest I've never touched it. I'm sure sure there are plenty of guys on here who have, but other than giving it a good spray with a pressure washer I've never felt the need to. Now that rear window, oof what a pain! Can't keep that thing clean to save my life.
  15. Jul 22, 2022 at 9:46 AM
    #7255
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    With a washcloth / sponge.
    My arm will reach halfway across. I get it from one side and then the other. Both the cab glass and the topper vinyl. If your topper is adjusted so that the gap is too narrow, try a stick (w/ a brush or a rag on it). Same with the towel (arm or stick). Piece of cake.
  16. Jul 23, 2022 at 1:45 AM
    #7256
    45thparalleln
    45thparalleln Well-Known Member
    PNW
    '04 3RZFE / '99 5VZFE
    Just stumbled upon this, i like the flat top rack. What is the total weight?
  17. Jul 25, 2022 at 2:42 PM
    #7257
    Bholm
    Bholm Well-Known Member
    B
    2017 Silver Tacoma SR5
    i believe its about 60lbs and i think is rated up to 400lbs of added weight
  18. Jul 29, 2022 at 7:57 AM
    #7258
    RobotTheDog
    RobotTheDog Well-Known Member
    AZ
    21 TRD OR DCSB CEMENT
    All encompassing layer of dust
    Short bed problemzzz. After much procrastination, finally getting the extension together. Pvc frame (secured into my TC bed stiffeners) some similar color canvas sourced on Amazon, zipper, velcro, and fabric glue. Opening is small, will modify later. Sides of extension are okay, will rework. Honestly I'll probably just throw my mosquito net over the frame to keep ventilation. Found out the canvas is rain proof, it was pouring when I was working on it lol. But now I can actually totally lay down in the bed.
  19. Jul 29, 2022 at 11:47 AM
    #7259
    powder1134
    Nice. I like the zippered door.
    RobotTheDog[QUOTED] likes this.
  20. Aug 16, 2022 at 1:44 PM
    #7260
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    From Yucca Valley up to Big Bear a few weeks ago
    Softopper was great. It was hot back there and I forgot my mosquito net. At that point, I wish I had window screens like a hardshell. Bugs were everywhere.
    Also... This is the Slumberjack awning. It works great. But I was left wanting something easier to setup like a freestanding 270degree awning (for quick rest breaks in the middle of the day). But the only way to make that happen with a softopper is with bed bars over the shell. Bummer
