Let's See Some Softoppers
Discussion in 'Tonneau Covers, Caps and Shells' started by tcBob, May 13, 2013.
  1. May 16, 2023 at 7:07 PM
    #7621
    louie_g
    louie_g Member
    Southern California
    2023 TRD OR, 2002 SR5
    what’s up jack! I did, appreciate your and airmax’s advice. Finished putting it on a bit ago. IMG_1570.jpg
  2. May 17, 2023 at 12:31 PM
    #7622
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Looks good! Looks really good!!!!
    louie_g[QUOTED] likes this.
  3. May 17, 2023 at 5:20 PM
    #7623
    powder1134
    powder1134 Well-Known Member
    2014 Tacoma TRD Off Road
    So long softopper. You've treated me right for a while now, but it's time you make someone else happy. Truck looks so strange without it. Tomorrow, hard shell.
    Bars spoken for, but topper is still available for sale.
  4. May 17, 2023 at 9:33 PM
    #7624
    hxp05560
    hxp05560 Well-Known Member
    2009 TRD Off-Road
    TRD Pro Wheels - Duratracs Black Softopper
    The truck looks naked! I’m sure your shell will look good tho.
    powder1134[QUOTED] likes this.
  5. May 19, 2023 at 7:19 PM
    #7625
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    I'm in the third year with mine (ST)
    Two trips across country (camping all the way)
    We get winter in VT. I do the ski patrol gig, so drive to the mountain every day.
    No issues with the ST in winter!
    That said, I have a car park at home, and open the back CAREFULLY just to get ski gear out in winter. I would NOT roll up the rear window at -10f. But flipping it up slowly has caused no damage.
    We were just in Phoenix last week, Everything about the Soft Topper was more pliable.
  6. May 19, 2023 at 10:37 PM
    #7626
    WestCoastBestCoast
    WestCoastBestCoast Well-Known Member
    Wyn
    Portland, OR
    2005 SWB TRD 6MT 4x4
    I’m having trouble with the search function trying to find the DIY Softopper Tent (the one that zipped into the end of the topper) that a member made. Anybody have the link or thread readily accessible?
  7. May 20, 2023 at 12:06 PM
    #7627
    VTCAL
    2021 Sport
    Spray paint is an easy fix! Slide some wax paper under the clasp and spritz just enough to cover.
    powder1134 likes this.
  8. May 26, 2023 at 7:41 AM
    #7628
    Amocat15
    Amocat15 Well-Known Member
    Bucks County, PA
    2021 DCSB TRD OR
    I am also several years into ownership and I love my softtopper. I had it on my second gen and now my 3rd gen with a new tail flap to fit the curved tailgate. I have always taken it off in the winter because I was worried about the rear window getting brittle and cracking in the cold. Good to hear you havent had problems. It is so useful for hauling ski gear in the winter!
    dirtnsmores likes this.
  9. May 26, 2023 at 8:43 PM
    #7629
    VTCAL
    2021 Sport
    Wind came up that evening something fierce. The ground tent was flattened about 45 degrees. We slept in the truck under the Softopper.
    The night time stars were incredible!
    Perfectly calm in the morning.
    SE Colorado.
  10. May 28, 2023 at 6:09 PM
    #7630
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Hey guys kinda a strange question here. I ordered a whitewater raft. I don’t have a trailer nor a place to put one so I’ll be inflating and deflating the raft and transporting it in the bed. It’s gonna have an oar frame, which I’m planning to strap on top of the bed. Do you think it would bend/dent/damage the softopper rails that run on top of the bed rails if I did this?
    If you don’t know much about rafting, picture an aluminum frame slightly larger than our bed that weighs 80-100+ pounds, the weight would be distributed on both sides of the bed.
    I haven’t unpacked and installed my softopper hence why I’m asking.
  11. May 29, 2023 at 7:26 AM
    #7631
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    Frame is aluminum i think it will bend
    r2pinter and HighCountryTacoma like this.
  12. May 29, 2023 at 7:38 AM
    #7632
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Does it have to go across the bed? I mean, can it drop in on one side so it sticks up in the other? That way it wouldn’t really be sitting in the rails.
    HighCountryTacoma likes this.
  13. May 29, 2023 at 7:38 AM
    #7633
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    You could always just completely remove the softopper including the rails when transporting the raft. After the initial install it's surprisingly easy to quickly remove and install the whole assembly
    On my FasTop that I have I marked where the bolts go and frame sits so I could remove the whole assembly when my truck had to get body work done. Took less than 2 minutes to remove and maybe 5 minutes to reinstall.
    VTCAL, tacofish, jackn7 and 1 other person like this.
  14. May 29, 2023 at 8:39 AM
    #7634
    HighCountryTacoma
    Colorado
    This is definitely a possibility. The problem is I’m gonna have a bunch of other gear to load up as well, so in my mind I was hoping I could lay it across the top in order to look a bit less trash and to save space for the raft, coolers, dry box, oars, pfd’s etc. Thanks for the responses guys I figured this was the case, I’m gonna have to do some brainstorming or possibly just dismantle and reassemble the raft frame each trip, which seems like a pain. Or take the softopper off entirely which presents a new problem. If only I had a trailer and space for one! :annoyed:I’ll figure something out. Thanks again.
  15. May 29, 2023 at 10:46 AM
    #7635
    ssd2k2
    Keith
    Minnesota
    Or if you plan on rafting a lot these bars might be a worthwhile investment.
    https://heavymetaloffroad.com/produ...per-bed-bar-21-inch-pair-heavy-metal-off-road
    TartanEagle and tacofish like this.
  16. May 29, 2023 at 10:55 AM
    #7636
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    yes, I left my truck at the Denver airport for a week I winter. I came back to the back vinyl shattered like glass. still some frozen pieces of it in the bed that I snapped like cheap Tupperware
  17. May 31, 2023 at 10:53 PM
    #7637
    RedDemolisher
    RedDemolisher Well-Known Member
    Tucker
    Albuquerque, NM
    2012 Silver Tacoma Access Cab
    I changed my tonneau for a Softopper off Cragislist last week. It would have been really easy to install if I didn't insist on keeping some of my molle bed panels. Eventually I figured out what I needed to grind down and now it's working great.
    0525231745a.jpg 0526231741a_HDR.jpg 0526232306.jpg 0524231815a_HDR.jpg 0531232324a.jpg
    jackn7, Auuzzyy and r2pinter like this.
  18. Jun 1, 2023 at 3:49 PM
    #7638
    HighCountryTacoma
    Colorado
    So after having my Softopper sitting in my basement for around eight months I finally installed it yesterday. I rushed it a bit cause I had to get to work and it was also starting to rain. So today I went back out (in the rain again) and kind of did a re install just to make sure I got it right. Everything went pretty well but upon completion I noticed that on one of the square frames it’s kind of twisted or tweaked at the joint where the two pieces connect, it is not like this on the other side. The square tubes are sitting flush in the clamps however they seem to be angled slightly inward towards the bed. Is this normal? Here’s a pic
    Eveything looks normal and correct from the outside as far as I can tell.
    69mfmtacoma likes this.
  19. Jun 1, 2023 at 8:18 PM
    #7639
    hxp05560
    2009 TRD Off-Road
    That doesn’t quite look right to me. Both of my square tubing frames are pretty well aligned. The photo below is the worst looking one on my passenger side:
    I would double check the inner sleeve to make sure it isn’t twisted and verify that both clamps are properly seated in the cargo track.
  20. Jun 1, 2023 at 8:58 PM
    #7640
    HighCountryTacoma
    Colorado
    Yeah I'm gonna mess with it again tomorrow, something has gotta be off with my installation. That or improperly manufactured bars.
