Let's see them wheels with negative offset
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ZYBORG, Jan 9, 2018.
  1. Oct 1, 2021 at 4:10 PM
    #341
    Cossaktrd
    Cossaktrd Well-Known Member
    Paul
    2020 Tacoma trd off-road cement
    I had 17x9-12 offset with a 265/70/17 on stock suspension I ordered the rrh7 with a -25 will they rub will I be good without a cmc
  2. Nov 15, 2021 at 8:09 PM
    #342
    Taco de cement
    Taco de cement Well-Known Member
    Omar
    2021 trd off road
    What tires are those
  3. Jan 3, 2022 at 5:11 PM
    #343
    brtnstrns
    brtnstrns Well-Known Member
    Seattle
    2020 Voodoo Blue TRDOR DCSB
    Just got these in today. Can hopefully figure out a time to get them installed in the next couple weeks. Raceline 950b Gauge in 17x9, -12 offset. Just going to run them with my already existing 265/70r17 Falken Wildpeaks since they fit with my current 4Runner TRDOR wheels with 1.25in spacers with no rubbing (essentially a -15mm offset overall). They should look a little meatier on the 9 inch wide wheel relative to the 7.5 inch as well.
    Currently:
    AUDIBIMMERBENZ and MGMDesertTaco like this.
  4. Jan 4, 2022 at 6:01 PM
    #344
    Cossaktrd
    Paul
    Rrw 17x8.5 -12 offset 265/70/17 stock suspension
  5. Jan 4, 2022 at 7:50 PM
    #345
    justinm2431
    justinm2431 Well-Known Member
    19 TRD OR
    Love these wheels
    brtnstrns[QUOTED] likes this.
  6. Jan 4, 2022 at 7:53 PM
    #346
    brtnstrns
    Seattle
    I've yet to find any pictures of them in 17's on a Tacoma with a -12 offset (deeper concavity than the 0 offset ones that I have seen), so I'm excited to get them on and see how they look. Should be on Thursday evening.
  7. Jan 4, 2022 at 8:48 PM
    #347
    Sandman TRD
    Sandman TRD Well-Known Member
    Indy
    2018 Black DCSB TRD Off Road 4x4
    17x9 -25
    265/70/17 Wildpeak
  8. Jan 5, 2022 at 8:02 AM
    #348
    Czeleznick
    Czeleznick Well-Known Member
    Philadelphia Area
    2022 White OR DCSB
    Eibach Pro Stage 1, Bronze SCS F5’s on Falken Wildpeaks
    Love the look of this. Do you have any lift at all? If not do you have any rubbing with those wheels?
  9. Jan 5, 2022 at 8:12 AM
    #349
    Sandman TRD
    Indy
    I have Bilstein 6112s in the front on the 3/4 settings so just a little over an inch in front. Rear is stock leafs w/ 5160s so no lift in back. I do rub slightly on the black tab behind the rear of the front tires when turning in reverse. I could trim it easily enough but haven’t messed with it yet because its pretty mild and will be making some adjustments to my set up here soon. I do love the way this looks and drives currently, I keep telling myself not to mess w/ it!
    McPickle and Czeleznick[QUOTED] like this.
  10. Jan 5, 2022 at 9:09 PM
    #350
    JDPNW
    JDPNW Well-Known Member
    S. Oregon
    2021 DCSB TRD OR Cement KDMax-Pro
    Eibach 2.0,SPC UCA,ECGS,ATS 4/1 rear leaf,5.29
  11. Jan 6, 2022 at 2:39 PM
    #351
    maximum
    maximum Well-Known Member
    those are KO2 285/70R17 on 17X8.5 et-10. I now have Yokohama geolandar mt g003 295/70R17 on 17X9 et-38.
    Oleshka13, JDarbos, Jseda845 and 5 others like this.
  12. Jan 6, 2022 at 3:54 PM
    #352
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    This looks awesome.... ashame I'm unwilling to vere from my stock suspension/perform a CMC or else this is what I'd be doing..
  13. Jan 6, 2022 at 8:16 PM
    #353
    npego
    npego Well-Known Member
    2018 Quicksand TRD OFFROAD
    I have the SCS ray 10s with -38 offset 3inch lift, JBA upper control arms, and running 295 70 17 geolanders. I had to do an aggressive cab mount chop and modify the splash guards. That was “ok” for street use. Every now and then I’d get some rubbing. However, off-road was a different story. I had to trim a small part of the front fenders and fender flares. This year I’m def going to be cutting off the body mounts altogether and relocating aftermarket ones for more clearance.
    BadDriver11 likes this.
  14. Jan 15, 2022 at 5:07 PM
    #354
    trl1990561
    trl1990561 Well-Known Member
    Tyler
    Jupiter, FL
    2021 Lunar Rock Tacoma TRD Pro
    Prinsu Rack, 265/70/R17 KO2,RRW R7-H RCI Rock Sliders,RCI 18" Bed Rack, Decked System,Baja 40" Amber Roof Light bar, Baja Amber Ditch Lights,Baja Amber Fogs, ARB Twin Compressor, Switch Pro, Blaze Offroad Wiring
    Did you have to chop/cut?
  15. Jan 15, 2022 at 5:09 PM
    #355
    trl1990561
    Tyler
    Jupiter, FL
    More pictures? Different angles, exact tire size and rim im looking for? Did you have to cut/chop?
  16. Jan 15, 2022 at 5:29 PM
    #356
    Sandman TRD
    Indy
    Not with this tire size. Will be needed when I go to a 285/70.
  17. Jan 15, 2022 at 5:30 PM
    #357
    Montana_Actual
    Montana_Actual ;)
    Don't they eff with you in CA? CHP chillen, just waiting for you to drive by.
    I love the looks... but I hate the debris.
  18. Jan 27, 2022 at 5:25 PM
    #358
    brtnstrns
    Seattle
    Raceline Gauge 950b 17x9 with -12 offset. 265/70R17 tires and about a 2in lift all around thanks to some various Dobinson's components.
  19. Jan 27, 2022 at 5:59 PM
    #359
    wayne0
    wayne0 Well-Known Member
    King pin angle? Pickup trucks haven't had king pins for a very long time.
    9TRDTCO likes this.
  20. Jan 27, 2022 at 7:40 PM
    #360
    dezert.taco
    dezert.taco Well-Known Member
    Nate
    Northern Nevada
    2018 Tacoma
    35x12.5 on 17x9 -14 offset.
    Kefka, LEXICON and kas2828 like this.
