Let's see them wheels with negative offset
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ZYBORG, Jan 9, 2018.
  1. Sep 11, 2018 at 6:52 AM
    #141
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    Only -10MM but it’s almost right at where I want them. I’d like them to stick out a little more.
    Word on the street is SCS allegedly is coming out with the Ray10’s in -38MM soon:spy:
  2. Oct 18, 2018 at 5:18 PM
    #142
    evoxtaco
    evoxtaco Well-Known Member
    Salinas, California
    2018 Tacoma Off Road
    King Lift, TC Upper Arms, MESO lights, SCS Wheels.
    I plan on doing a King lift with 17x9 -38 wheels paired with 33’s. How much will I rub and will I have to do a lot of cutting? 90% daily driven and very light off roading.
    PNWTacoma likes this.
  3. Oct 18, 2018 at 5:33 PM
    #143
    bigShawn
    bigShawn Active Member
    Shawn
    16x10 -25. 295/75/16
  4. Oct 18, 2018 at 5:35 PM
    #144
    sy272004
    sy272004 Well-Known Member
    West Chester
    15 TRD V6 4x4 DC
    3" lift. 33" tires. Headlight Retro, intake, exhaust
    TSAVO likes this.
  5. Oct 18, 2018 at 9:06 PM
    #145
    TSAVO
    TSAVO Well-Known Member
    Tempe, AZ
    2018 TRD OR
    18x9 -12 Method NV BFFB24FA-41ED-4F01-8895-E7DF611BE234.jpg9B1AFA62-BB14-4A13-9A83-64C58C778877.jpg
  6. Oct 19, 2018 at 7:26 AM
    #146
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    SCS RAY10 16x8 -12
    Duratracs 265/75r16
    BobcatSR, Masonkv and lewcanis like this.
  7. Oct 19, 2018 at 7:08 PM
    #147
    WalkinTaco
    WalkinTaco Well-Known Member
    2018 TRD OR M/T
    Can't decide if I like the front or the rear better...
    What is that grill? looks sweet
    Arrieta578 likes this.
  8. Oct 19, 2018 at 7:34 PM
    #148
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    Hopefully you got this fixed already but if not hopefully this info helps. When you lift the front end your going to lose caster. When you get to far into the negative caster your steering becomes more sensitive and wants to wander at higher speeds along with bump steer ect. These trucks tend to like a caster of 2.+ and will feel much more stable. That's why most people have to run aftermarket UCAs. My caster is somewhere around +3.7 I believe. When I was on stock UCAs I would get some wander on the highway. Hope this helps
    Ravnikar610[QUOTED] likes this.
  9. Oct 20, 2018 at 2:45 AM
    #149
    Ravnikar610
    Ravnikar610 Well-Known Member
    Minnesota
    2016 OR DCSB
    Thanks for the reply. Im note sure where my caster is at anymore but I know I asked them to max it out on my JBA ucas. I'm pretty my tie rod ends are what's wrong. Will be getting it sorted out within a couple weeks.
    mosquitoTaco[QUOTED] likes this.
  10. Oct 20, 2018 at 10:22 AM
    #150
    Yotaholic
    Yotaholic Well-Known Member
    Oahu, HI
    2017 DCSB Sport 4x4 MT
    What wheels are those? Looks great!
  11. Oct 20, 2018 at 12:25 PM
    #151
    bigShawn
    Shawn
    They are an old centerline wheel. Not sure if they are still made. I picked them up used and had them powder coated.
    Yotaholic[QUOTED] and su.b.rat like this.
  12. Oct 20, 2018 at 12:41 PM
    #152
    ZYBORG
    ZYBORG [OP] Let's roll...
    TX / S. FL
    3G TRD OR
    I like them too. Not 100 on the sparkles but I do like the design and offset. Any more shots?
  13. Oct 20, 2018 at 12:52 PM
    #153
    bigShawn
    Shawn
    They actually look black 90% of the time. The light has to hit them just right to see the effect. It’s pretty funny seeing people break their neck when they notice it.
  14. Oct 20, 2018 at 3:48 PM
    #154
    DaMaDo
    DaMaDo Well-Known Member
    Northern AL
    2018 White TRD Pro
    Here's Black Rhino Arsenal 17x9.5 -18 offset (4.5bs) with 285/70R17 Wildpeaks
  15. Oct 22, 2018 at 12:09 PM
    #155
    ctmedic
    ctmedic Well-Known Member
    2018 TRD OR DCSB
    Are you rocking a softtopper under there?
  16. Oct 22, 2018 at 12:28 PM
    #156
    mudcheck
    mudcheck Well-Known Member
    2016 DCLB TRD OR
    Procomp 7069's ,16x8 -12, 265-75-16 inch toyo MT's.
    OffroadToy, justin23, wowc8 and 14 others like this.
  17. Oct 22, 2018 at 5:07 PM
    #157
    DaMaDo
    Northern AL
    2018 White TRD Pro
    Yes I am, fits easily
  18. Oct 22, 2018 at 7:03 PM
    #158
    joestacos
    joestacos Ice cold rice water
    that1tacoguy
    CenCal
    17 Tacoma TRD Off Road
    Pro Driver inside
    What brand wheel?
  19. Oct 22, 2018 at 11:10 PM
    #159
    bigShawn
    Shawn
    Centerline. It’s an old wheel. Don’t think they still make them.
    joestacos[QUOTED] likes this.
  20. Mar 7, 2019 at 10:14 AM
    #160
    Tac11
    Tac11 Well-Known Member
    Luis
    2011 white Tacoma sport TRD
    3" Front lift OME/5100 set at 0, 1/4 spacer on driver side CMC, BFG 285's, SCS ray 10’s -38 offset 1 inch rear block N-Fab steps Bumper Cali Raised LED light bar Cali Raised LED fog lights After market exhaust, and muffler tip Redline hood struts Tacoma Bed-liner mat Tailgate lock Tinted windows 20% HID headlights Short antenna Clazzio Seat covers Joying head unit
    Wassup peeps! I got 285/70/17 BFG tires on my stock sport rims. I’m ready for some wheels. I want a wide tire look so it can have a meaty look. What offset is recommended. Or does that. Or dictate the width and it’s more on the rims size?
