Let's see those Alu-cab setups
Discussion in '3rd Gen. Tacomas (2016-2023)' started by turbosmitty, Jul 28, 2018.
  1. Dec 24, 2021 at 11:43 AM
    #321
    YellowSnow
    YellowSnow Chasing Pink Taco
    San Diego
    19 TRDOR
    KING/YOKOHAMA/RLD/RRW/RCI/BAJA/ROOFNEST
    Sounds obviously like the installation was dicked up.
  2. Dec 24, 2021 at 12:33 PM
    #322
    Jayhat
    Jayhat Well-Known Member
    definitely seal all the standard Toyota bed leaky spots. There are huge gaps where the front and bed sides meet, at the top. The compartment near the back on the side of the bed has a hole in it. Any drain holes.
    check rivets and any wire holes (brake light), might need a smear of silicone.
    Bassshreddin[QUOTED] likes this.
  3. Dec 24, 2021 at 12:46 PM
    #323
    Bassshreddin
    Bassshreddin Well-Known Member
    Wes
    2019 Tacoma trd off-road
    RLD canopy, icon stage 1 lift.
    Thanks, the company sealed a substantial amount of the front corners and the floor itself. Hence the standing water. I left from LA and drove to SLO Wed and there was a steady rain since I left. When I got there and opened the back it was about a half inch of water in the bed. Upon further inspection there was visible leaks around the likely corners up front, but also several leaks on the camper itself. Tried rtv to help stop the leaks with minimal success.
    Frustrated as this will be the second of two camp trips I've had to cancel now.
  4. Dec 24, 2021 at 12:57 PM
    #324
    MJTH
    MJTH PretenderLander
    Joe
    Colorado-Westslopebestslope
    19 OR- Land Yacht, w/ fireplace
    I had leaks at first. Every single one was the result of a poor install(east coast installer, DM if you want details) None of it was poor quality on alucab side.
    I decided to seal it up on my own. Took about 4 hours and 6 tubes of caulk. Tacoma has alot of spots that need to be sealed, many of which aren't easy to spot.
    Alucab and most of their distributors are great people. I've had a good experience reaching out to them on the two minor issues I've had.
  5. Dec 24, 2021 at 1:40 PM
    #325
    Jayhat
    I drove from SLC back to WA last week with my new explorer shell on. It was also pretty wet back in the bed when I got home. I did not try to seal anything up yet. Though it’s rained when it’s been sitting in the driveway and hasn’t seemed to get wet. Mine is definitely much more wet when driving.
  6. Dec 25, 2021 at 7:18 AM
    #326
    Bassshreddin
    Wes
    First off, merry Christmas, second, thanks for the advice. I watched a short video displaying all of the areas that can be prone to leaks and was astonished.
    I had my other top off for nearly a week and should have sealed the bed alone. That being said, the installer was nothing but apologetic and said to set up a time as soon as I get back from the holidays.
    I assume most of the issues, from what I can tell, are definitely from the front of the bed or the side rails.
    But the camper itself did have several areas of leakage.
    What type of sealant did you use? I had some general clear caulk and another rtv for the time being, but it was still raining and hard to keep areas dry. Hoping this week will be different, but unlikely lol.
  7. Dec 25, 2021 at 6:06 PM
    #327
    MJTH
    Joe
    Mixture of black silicone caulk, 3M window weld, and some 1/2" backer rod(like a flexible solid rubber rod)
    Took me a couple times. Seal up, find a new place, seal up again
  8. Dec 27, 2021 at 5:19 AM
    #328
    Siebermd
    Siebermd It’s all about the journey
    Virginia Beach
    2016 TRD Off Road
    Alu-Cab canopy Camper, Dobinson's Suspension
    Just curious if anyone has ever entertained the idea of opening up a Pass-Thru to the rear window of the truck? Then you could actually utilize the trucks heat via a remote start. Of course it would require some clever sealing between cab and camper, a tire inner tube perhaps.
    Borealis likes this.
  9. Dec 27, 2021 at 6:47 AM
    #329
    mitt22
    mitt22 Well-Known Member
    Anyone have first hand knowledge of the silver Alu-cab canopy (topper, not tent) versions? How close is it to a silver tacoma color? Any good pictures? Google search failed on good silver toppers.
  10. Dec 31, 2021 at 5:42 PM
    #330
    MJTH
    Joe
    Awesome
    Unforgiven69[QUOTED] likes this.
  11. Jan 1, 2022 at 8:35 PM
    #331
    Jayhat
    For those with the alu cab explorer shell (or those with similar internal channels), what fasteners do you use for the inside channels? Either some type of captive nut (for bolting up in to) or bolt head (to hang down and bolt onto)? I think m8 hex bolts are supposed to fit but I have a hell of a time time getting any of the ones I have to slide in. Even ones I can get to work in one channel are a pain in another. I’m wondering if some non-US spec bolt works better? Maybe it’s the black coating making them really tight? Smaller bolts? Any particular size T-nut or extrusion type nut work well?
  12. Jan 2, 2022 at 7:57 AM
    #332
    Jayhat
    Yeah I was laying in the bed yesterday trying with gloves and grabbing the bolt with pliers. Probably 90% of the ones I tried I could not get to work. It was also 10 degrees and I was just too cold and frustrated to try anymore.
    I did have a pack of these I had bought to try in my roof rack extrusions. They slid in easily, definitely not as snug as a m8, but they don’t spin around in the track.
    DCT Tee Bolt Set – 20 Pack 1-3/4in T Bolts for Woodworking, T Track Bolts Jig Bolts, 1/4in 20 Thread T Bolt https://www.amazon.com/dp/B07JQB18N1?_encoding=UTF8
  13. Jan 2, 2022 at 9:06 AM
    #333
    sdwf
    sdwf Well-Known Member
    2016 Tacoma Sport 4x4 DCSB
    I wonder if these would work? https://www.frontrunneroutfitters.com/en/us/front-runner-stainless-steel-tie-down-rings.html
  14. Jan 2, 2022 at 9:27 AM
    #334
    Jayhat
  15. Jan 2, 2022 at 9:41 AM
    #335
    Jayhat
    according to alu cab, though in my experience it’s not this cut and dry. I’m thinking the power coating is on really thick or something. I’ll probably try to grind down the heads of a few bolts and keep a bag of them aside for mounting.
    “Based on the extraordinarily stable construction of the Aluminium profiles, additions such as cabinets, shelves or mounting rails can be secured directly onto the frame. For this reason, the lower longitudinal frame member, front-lower transverse member, and the roof transverse members are all made of Aluminium profiles with integrated nut slots. Therefore, commercially available hex bolts (8mm) can be used. The vehicle brackets are also screwed to these rails.
    The cargo rails on the roof do not need special screws or T-nuts. Here, standard M8 flatbolts with square head (DIN 603) should be used. In both cases, a stable connection can be achieved by using lock nut screws (DIN 985).”
    Siebermd likes this.
  16. Jan 3, 2022 at 3:37 PM
    #336
    fullripbrian
    fullripbrian Well-Known Member
    Seattle sucks now.
    2017 SR Utility
    The interior channels have been fussy on my explorer canopy.
    The correct bolt size is M8, 13mm across the flats of the head.
    The powder coat builds up in the channel interior causing blockages and interference. I’ve used chisels, picks, and files to clean mine up. I haven’t been able to clear every obstruction but I’ve made good headway.
    Most, if not all of the channels have recesses at both ends and the middle. I’m usually able to slide a bolt in from one end of the other to make whatever location work.
    it’s a pretty neat system. Alu-Cab could stand to improve QA on this.
    Jayhat likes this.
  17. Jan 3, 2022 at 10:05 PM
    #337
    Jayhat
    I should just rough up a bolt, force it in, and drag it through each track several times with a pair of pliers.
  18. Jan 6, 2022 at 12:22 AM
    #338
    marshmellowninja
    marshmellowninja Active Member
    2020 TRD OR DCSB
    Hey Basss, did you get your leaks resolved? Been looking at picking one up from what I think is probably the same shop. Thanks!
  19. Jan 6, 2022 at 12:26 PM
    #339
    Bassshreddin
    Wes
    They are working on getting me worked into the schedule. Went out last week, no rain so no issues. But Daniel has been pretty cool about everything. Once they get me in they will go through the entire camper and truck bed, power wash it, and see where the leaks are and fix accordingly. Other than that the thing as amazing and Tiny Rig has been nothing but helpful though the entire process. IMG_4356.jpg
    dlo13 and Siebermd like this.
  20. Jan 6, 2022 at 4:58 PM
    #340
    marshmellowninja
    2020 TRD OR DCSB
    Sweet! That’s what I was hoping to hear.
    Thanks for the response man!
    dlo13 likes this.
