Let's see those Alu-cab setups
Discussion in '3rd Gen. Tacomas (2016-2023)' started by turbosmitty, Jul 28, 2018.
  1. Oct 27, 2022 at 4:40 PM
    #581
    Siebermd
    Siebermd It’s all about the journey
    Virginia Beach
    2016 TRD Off Road
    Alu-Cab canopy Camper, Dobinson's Suspension
    Best part of outfitting my truck with Packout gear. I can take everything out and replace the floor and put it all back together in under and hour.
    831909DC-D76B-452C-AD1D-0232A85C89B2.jpg A7AF30F3-8A73-4250-8EB9-80514B703425.jpg 619679FF-98D2-4CB6-89E0-874A198B4982.jpg
  2. Oct 27, 2022 at 6:34 PM
    #582
    Tac0Joe
    Tac0Joe Well-Known Member
    Joe
    2017 Double Cab TRD Off Road Quicksand
    Stupid question. Do most of you sleep head or feet towards the front of the truck?
  3. Oct 27, 2022 at 7:04 PM
    #583
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I would guess that most wedge tent people will sleep with their feet towards the wedge. I just have a canopy and a dac tent and sleep feet forwards so my sleeping bag can deal with the moisture instead of my pillow.
    greymachine, Peace1 and 71tattooguy like this.
  4. Oct 28, 2022 at 4:28 AM
    #584
    Siebermd
    Virginia Beach
    2016 TRD Off Road
    Really depends on the campsite parking situation. I always sleep with my head higher than the feet. If nice and level, I will always sleep feet to wedge.
    onequarteratatime likes this.
  5. Oct 31, 2022 at 2:47 PM
    #585
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    I always do feet to the wedge due to my height, but I always level the truck, or park it in a way that my head is up. 1-2 degrees is fine head to toe.
    I'll do some testing with the Dickinson this winter. With two people in my camper, completely uninsulated, we sleep in the nude with a cheap blanket on us when it is 40 degrees out. At 20 degrees we use a fleece blanket with a nicer down comforter on top.
    It's incredible how warm it stays in there with two bodies. I love it. The heater will just be the icing on the cake.
  6. Oct 31, 2022 at 3:52 PM
    #586
    Pete4x4
    Pete4x4 Well-Known Member
    Frankie
    NorCal
    2014 4x4
    6112/5160 Dakar HD
    Yeah they are the low profile. The place I bought the set up from didn’t tell me this was going to be an issue. So I need to buy the thicker bars. Anyone need slim bars? Want to trade?
  7. Nov 9, 2022 at 7:47 AM
    #587
    MR E30
    Michael
    I have a questions for those of you with the Dickinson P9000 Furnace in your campers.
    How is the heat output?
    I had the opportunity to use my furnace in ~25 degree weather last weekend. We ran it for the entire night on low, fan on medium-high.
    To be frank, I was not impressed at all. The chimney stack was HOT, so hot that it would immediately burn your hand if touched, on both the portion inside the camper and outside the camper. The top cap piece was also unbelievably hot, while the lower cap piece was of moderate temperature.
    None of that heat was transferred to any other part of the camper, thankfully. Also, placing your hand a mere 1 inch away from the pipe was easily doable, you couldn't even feel the heat of the pipe at that short distance.
    The air blowing inside the cabin from the furnace was, at best, warm.
    The inside of the camper was easily 30 degrees warmer than the outside, which is very nice.
    But this was with the furnace running constantly, which is not ideal for propane usage.
    Is this just how it is? I know its BTU's aren't super high, but the space it's heating is tiny. I was expecting being able to fire it up for an hour to get things toasty inside, and then cutting it off for the night. Reigniting it for a bit in the morning. This is how I have used Mr. Buddies in the past.
    I do need to purchase and swap in the orifice for use above sea level, so maybe that will make a huge difference? We were at 5,000 ft.
    Just stunned that the chimney pipes were unbelievably hot while the air being blown out of the furnace was lukewarm.
    Thanks for your input.
    Gabex35 and Siebermd like this.
  8. Nov 9, 2022 at 9:53 AM
    #588
    Siebermd
    Virginia Beach
    2016 TRD Off Road
    Im going to assume that the Altitude has something to do with it. Tho I can't speak from firsthand experience in the Sub 40 temps (yet). Having the heater running for 30 min or so, nicely warms up the space.
  9. Nov 9, 2022 at 3:17 PM
    #589
    MR E30
    Michael
    All right, I ran a test. Here is what I found:
    My truck is parked at 1,412 ft above sea level, according to Gaia.
    Test start time = 12:09 pm - Test end time = 1:09 pm
    *Temperature gathered by a $150 probe and scan tool
    Weather: Cloudy, no sunlight, light rain the entire time
    Outside ambient air temp at start = 62.5 degrees F
    Outside ambient air temp at finish = 62 degrees F
    The furnace was on low, with the fan on high. The sea level orifice (what it comes with) is currently installed.
    I checked the temperatures at 0 min, 20 min, 40 min, and 60 min. I checked the campers interior temperature, the temperature of the chimney section inside the camper, and the hot air coming out of the furnace.
    The camper was closed the entire time, with the tent closed. I had to open the back door to get inside each time, but I did it as quickly as I could.
    Camper air temperature (degrees F):
    0 min = 62.5
    20 min = 70
    40 min = 72
    60 min = 74
    Interior chimney pipe (degrees F):
    0 min = 70
    20 min = 134
    40 min = 160
    60 min = 165
    Furnace air output temperature (degrees F): The probe was placed in the flow of air for 20 seconds. Temperature data was collected at that point.
    0 min = 76
    20 min = 150
    40 min = 158.5
    60 min = 157
    The furnace door was 130 degrees F at the 60 min mark. My knuckles could only withstand the hot air from the furnace for 9 seconds before it became unbearable.
    So it seems like the air coming out of the furnace is plenty hot. It just isn't a massive volume.
    It seems like the furnace can add 10 degrees quickly, but then it has to combat warming up all of the stuff inside of the camper, so it only increases the air temperature mildly after that.
    I will run the same test on a colder day. I will also run it with a different orifice, once I acquire it and install it.
    Siebermd[QUOTED] likes this.
  10. Nov 14, 2022 at 4:08 AM
    #590
    Siebermd
    Virginia Beach
    2016 TRD Off Road
    Observe the extent of my cooking abilities. The Newport fireplace with a well placed spatula will warm pop tarts nicely.
    dlo13, Tazzmacd, Gabex35 and 5 others like this.
  11. Nov 17, 2022 at 3:54 AM
    #591
    Siebermd
    Virginia Beach
    2016 TRD Off Road
    Camped at the beach last night.
    Soilmapper and Wackyhacky like this.
  12. Nov 17, 2022 at 4:09 AM
    #592
    Siebermd
    Virginia Beach
    2016 TRD Off Road
  13. Nov 17, 2022 at 1:58 PM
    #593
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    New contour canopy has landed. Think I’m one of the first!
    Peace1, ETBA, Fixxxer and 12 others like this.
  14. Nov 18, 2022 at 6:13 AM
    #594
    mitt22
    mitt22 Well-Known Member
    Looks good. What's the initial impression? Where did you get it from?
  15. Nov 18, 2022 at 8:25 AM
    #595
    jeremy5000
    jeremy5000 Well-Known Member
    Philadelphia
    What are the differences from the contour vs the explorer if not opting for side windows?
  16. Nov 18, 2022 at 9:24 AM
    #596
    MGMoverland
    MGMoverland Well-Known Member
    Brad
    Golden, CO
    22 Tacoma TRD 4x4 Offroad
    Full RCI Armor/Sliders, Bilstein 6110/5160 w/Deaver stage 3 leaf pack, Method 703 titanium wheels, BFgoodrich KM3 265/70/16, BD Sport Amber fogs, OEM LED HL, Meso 1st stage Tail conversion, Anytime front camera, EE accessory dash mount, Alu-Cab Contour canopy, Alu-cab ammo box slide, Alu-cab fridge slide, Alu-cab large cupboard, Alu-cab gen 3 tent, Goose gear deck plate, ARB twin compressor w/DDI under seat mount, Yaesu FTM 400XDR ham radio, Snomaster 72 classic fridge freezer, Battleborn 100AH lithium house battery, Front Runner 17.7 gallon onboard water.
    Super Jealous right now. Waiting on mine. Was told some time late this month or early next month.
  17. Nov 18, 2022 at 9:33 AM
    #597
    Dtax
    Dtax Well-Known Member
    Massachusetts
    2017 Black Tacoma Sport
    Mods = N+1
    same here - super pumped!
    @aturk - great pics / POV - looks great and nice rig.
    aturk and Hudock08 like this.
  18. Nov 18, 2022 at 1:13 PM
    #598
    aturk
    Tony
    Charlotte, NC
    Not enough to warrant the price increase, especially if you can find a vendor selling explorer's cheap. But I wanted the windows so here we are.
    The roof is flat aluminum instead of diamond plate, there's a positive pressure vent to keep dust out. But Tacoma's have so many pieces in their bed system I don't think it's safe to assume you won't get dust/water in there.
    jeremy5000[QUOTED] likes this.
  19. Nov 18, 2022 at 1:14 PM
    #599
    aturk
    Tony
    Charlotte, NC
    Mike Johnson Adventure Outfitters in Hickory NC. If interested, call and ask for Ryan Bartlett. He's a guru of these Toyota trucks in general in the south east. He's done a fair amount of work to my truck this year as I've been largely off my feet due to ankle reconstruction surgery.
  20. Nov 19, 2022 at 10:36 AM
    #600
    Hudock08
    Hudock08 Active Member
    2021 Cement Tacoma TRD Sport
    Fox 2.5 Factory Race Series w/ Remote Reservoirs - F&R BF Goodrich 285/70/17 T/A KO2s on 4Runner TRD Pro Wheels - Alu-Cab Contour Canopy
    Well I hope you like it. I liked your photos so much, I finally put my order in. Haha any rain so far to test for leaks? The reason I picked this one over the smart cab, is that I’ve been hearing people get leaks in from the side windows.
