Let's see those Alu-cab setups
Discussion in '3rd Gen. Tacomas (2016-2023)' started by turbosmitty, Jul 28, 2018.
  1. May 8, 2023 at 10:52 AM
    #801
    nvnv
    nvnv Stop geotagging
    Connor
    2016 Tacoma TRD OFF ROAD
    Nice job. The AluCab load bars are pretty much just 1x3 T slot bars. How much do you think you have into your load bar setup?
  2. May 12, 2023 at 3:45 AM
    #802
    FooManChu
    FooManChu Well-Known Member
    2020 Cement TRD OR DCSB
    That setup came in right around the same price as the larger Alucab bars. Think I got it all setup (hardware included) for under $400 cad.
  3. May 12, 2023 at 5:01 PM
    #803
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    ricphoto likes this.
  4. May 13, 2023 at 6:09 AM
    #804
    Gunnisoncamping
    Gunnisoncamping Member
    Doug
    2023 TRD off-road
    I didn’t, but my arrival time did get pushed back to September.
  5. May 17, 2023 at 4:33 AM
    #805
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Just got my contour canopy. I love it. My only gripe is that the hex bolts were nearly impossible to get into the slotted channels. I ended up tapping them in with a screw driver and hammer to get them to slide into the channel. Was sweating the whole time thinking I was going to mess up a brand new cap. I believe this was due to overspray from the powdercoating gumming up the channels. The powdercoat itself is top notch.
    Also the instructions included were clearly not made for the contour. They show pictures of hardware that is totally different than what they gave me. I was able to figure it out, but it turned what should have been no more than an hour install into over two hours.
    I was also able to put it into position by myself. Wasn't easy, I got under it, squat walked it up onto a chair, and then up to my tailgate and shuffled it into place. Sketchy for sure, but doable.
    All in all though, I'm very impressed with the quality. Still need to run the wiring.
    Edit: Also the guys and gals at OK4WD are seriously awesome people. Super helpful and just as stoked as I was about the cap. They helped me load the giant box that it comes in into the bed, and it made the two hour drive back no problems. We even did a t-shirt swap between my company and theirs! Can't recommend them enough.
    Edit 2: also if anyone is curious if a prinsu cap rack will work with the canopy...it absolutely won't. The prinsu rack would be way too narrow for the feet to mount to the alu cab.
  6. May 17, 2023 at 2:41 PM
    #806
    TacoTrigger16
    TacoTrigger16 Well-Known Member
    Central Valley California
    2022 TRD OR 4x4 DCSB Super White
    Armor: RCI Plated 20 Degree Sliders RCI Full Skid Plates Steel RCI Fuel Skid RCI Rear Diff Skid SNS Designs ABS Guards Front Bumper: C4 Overlander with Full Hoops C4 Front Bumper Frame Support Brackets Bed: Total Chaos Bed Stiffeners Cali Raised Bed Light Kit Toyota Bed Mat Alu-Cab Contour Canopy Blue Sea 5025ST Fuse Block Blue Sea 4363 Switch Panel Victory 4x4 Front Bed Molle Panel Mountain Hatch Tailgate Table 3.0 Fire Extinguisher Shovel Axe Fatmax Extreme Lighting and Electrical: PowerTrays Essentially BantamX Spod Bantam X w/ Touchscreen Baja Designs 30” S8 Light Bar Driving Combo Baja Design Squadron Sport Diving Combo Baja Design Squadron SAE Fleece All Lights On Engine: K&N Drop In Air Filter Mishimoto Intake Hose Toyota Air Accelerator Toyota TRD Oil Cap Toyota TRD Radiator Cap ECGS Bushing SDHQ Terminal Kit Fumoto Engine Oil Drain Valve AC Drain Mod Exterior: De-Badged Black Tacoma Tailgate Letters Heritage Badge In Black/Grey/White AVS Rain Guards AVS Aeroskin Hood Protector Lftd Customs Taco Sauce Gas Cap Holder Tacoma License Plate Frame Black Sylvania License Plate LED Lights R4T Bumper Caps Meso Customs Headlight Trim Plate Meso Customs V5 Ultimate Turn Signals SDHQ Ditch Light Mount Rago Fab Antenna Mount Interior: Desert Does It Seat Jackers & MMP K&N In Cabin Air Filter Matte Black Steering Wheel Emblem Meso Customs Red Push To Start Meso Customs Vent Rings SW Meso Customs Climate Control Rings SW Meso Customs Interior Chrome Delete SW Meso Custom Minimalist Key Fob V2 SW Meso Customs Extended Fuse Cover AJT Designs Door Handle Covers Z Precisions Cup Holder Midland MXT275VP4 Yodaverse Interior LED Kit Yodaverse Center Console Organizer TacoMods Radio Knobs w/ Backlighting Headrest Paracord Grab Handles SOG Rapid Rescue Dongar Technology Mirror Adapter Garmin Dash Cam Mini 2 Baby Toyoda Square Center Console Insert WeatherTech FloorLiner HP Grey Expedition Essentials 3TPAM Ram Mount Accessories GoGettaGrip Shifter Knob Magnetic Mic Patches Suspension Lift: DuroBumps Front Bump Stops Icon Billet UCA’s Delta Joint All-Pro Sway Bar End Links Marlin Crawler HD LCA Frame Brace Bison Offroad Cam Stop Kit Total Chaos Cam Tab Gussets Total Chaos Cab Mount Chop Plates Total Chaos Spindle Gussets W/ Sway Bar Accutune Fox 2.5 DSC Front Shocks Accutune Fox Tundra 2.5 DSC Rear Shocks Accutune 2.5” Bump Stop & U Bolt Flip Deavers U402 Stage 1 Yota Mafia Rear Extended Brake Lines 24” ARB Carrier Bearing Drop Kit FK29 Archive Garage Hammer Hangers Archive Garage 3.6 Shackles Archive Garage High Clearance Cross Tube Wheels and Tires: SCS F5 16x8 -25 Offset 3.5 BS Gunmetal Mickey Thompson Baja Boss M/T 285/75R16 Gorilla M12x1.5 Lug Nuts ET Liftd Customs Leashed Valve Stem Caps Winch: Warn VR Evo 10-S Warn Wireless Hub Factor 55 1” Fairlead Factor 55 Rope Guard Factor 55 UltraHook Gray Tandem Offroad Control Box Mount LambTek Innovation Switch Bracket Kit Blue Sea Switch Recovery: Factory 55 HitchLink 2.0 Warn Epic Shackle x2 ARB Tree Saver 16’ Special Thanks to: Sibi Built for the lift installation. Tiny Rig Co for the Alu-Cab and installation. Accutune for the Fox Shocks with Adventure Tune. Baja Designs for lighting. C4 Fab for the front bumper. RCI for sliders and skids.
    I had the same issue with the M8 bolts. I took a Dremel to one side till they just slide in. I agree it is the over spray. Your rig looks really good!
    TS4x4[QUOTED] likes this.
  7. May 17, 2023 at 6:23 PM
    #807
    Road Bull
    Road Bull Well-Known Member
    WA
    2022 Tacoma TRD OR; 2002 4Runner
    Nice man! I am supposed to pick mine up on Tuesday. I prepped the top of my bedrails this week to help mitigate water and dust intrusion. I went with no windows on the sides. Is that the version you went with?
    Also, What bed stiffeners are you running and do they interfere with the canopy at all?
  8. May 17, 2023 at 7:56 PM
    #808
    TacoTrigger16
    I’m running Total Chaos Bed Stiffeners without issue.
    Road Bull[QUOTED] likes this.
  9. May 17, 2023 at 10:50 PM
    #809
    TacoZmtn
    TacoZmtn Well-Known Member
    2022 TRD Off Road LB
    OTT-6112’s~5160’s rxt's~ShmellFab Sliders
    Has anyone had experience with a Leer 180 or 100 with windoors vs an Alucab on a long bed? Overall experience/thoughts? My main point of interest is the head room height... it almost looks like the alucab is right between a leer 180 and leer 100? I couldn't figure it out with all these measurements online... I was leaning toward a 180 to use it as a camper to sleep in... The more I look at the alucab.. the more I keep looking at it lol. Thanks, cheers
  10. May 18, 2023 at 3:40 AM
    #810
    TS4x4
    2018 TRD Offroad
    I appreciate it! I'm already loving the enclosed bed space.
    Yeah, this is the no window version. And I didn't know this going in, but the bottom of the cap has heavy duty rubber tubing attached to it to help it seal. Think like a door seal but thicker. I doubt there will be any water getting through it.
    These are cali raised bed stiffeners and nope, no interference.
    First impressions are a 10/10. You're gonna love the cap!
  11. May 18, 2023 at 12:15 PM
    #811
    TS4x4
    2018 TRD Offroad
    Adding some reference pictures to answer questions that I had when initially buying the Contour. It sits right in line with the angles of the cab. It does stick up about 3in above the roof line. The no window version still has the cool indented sides where the window would be.
    Also I don't believe it's any hotter without the windows. If anything it may be cooler since you get less sun shining in.
    20230518_151045.jpg 20230518_151033.jpg 20230518_151026.jpg 20230518_151014.jpg
  12. May 18, 2023 at 4:20 PM
    #812
    TacoTrigger16
    What brand roof rack are you running on your cab?
  13. May 18, 2023 at 5:05 PM
    #813
    TS4x4
    2018 TRD Offroad
    Prinsu
    TacoTrigger16[QUOTED] likes this.
  14. May 18, 2023 at 5:19 PM
    #814
    Road Bull
    WA
    Great pics! That's some boxy sexiness right there. I dig it a lot. Looking forward to getting mine next week even more now. I am glad I went with the no side window option.
    MR E30 and TS4x4[QUOTED] like this.
  15. May 20, 2023 at 6:29 PM
    #815
    Burrrr
    Burrrr Well-Known Member
    KY
    2017 DCSB TRD Sport
    All modifications below: FUNCTIONAL: LINE-X Undercoating Alu-Cab Contour Canopy ICON Stage 3 Suspension Kit (Tubular UCA) Prinsu Cab Rack Prinsu Top Rack (Mounted to Contour Canopy) Prinsu Rack 44" Side Rail WeatherTech DigitalFit Floor Liners (Front and Rear) Victory 4x4 Armrest Interior Molle Panel (VTCCIMP-3G-PC) Cali Raised Bed Molle System (Rear Panels; Both Sides) Vantrue N4 Pro 3-Channel Dash Camera (Hardwired) WHEELS/TIRES: SCS BR6 17x9" -38mm Nitto Ridge Grappler LT285/70R17 C 116/113Q LIGHTING: Diode Dynamics SS3 Max (Yellow SAE) Fog Lights Diode Dynamics Stage Series 30" Stealth Light Bar Kit (White; Driving Optic) Diode Dynamics SL2 Pro High Beam LED Lights Diode Dynamics 921 XPR LED Reverse Lights Diode Dynamics HP5 LED Map Light (x2) Diode Dynamics SMF2 LED Vanity Light (x4) Baja Designs LED Dome Light RovrLab Baja Designs Flush LED Dome Light Conversion AUDIO: Receiver/DSP: Sony XAV-9500ES Speakers (Powered by JL Audio JD400/4): Kicker Tweeters (Subaru Part # H631SFJ101) Kicker 46CSC6934 (Front Doors) Kicker 46CSC674 (Rear Doors) Subwoofer (Powered by JL Audio J2 500.1): JL Audio SB-T-TACDCG3/10TW3 (Stealthbox)
    Following up (finally): To put the Prinsu top rack on the Alu-Cab Canopy Contour, you will need at least two pairs of Leer mounting feet, assuming you're not going to fabricate something yourself. A couple of quick pictures just from the garage, if anyone needs a better/closer look let me know.
  16. May 20, 2023 at 7:14 PM
    #816
    TS4x4
    2018 TRD Offroad
    I was going to attempt the same thing and then thought the better of it. I don't love how the feet aren't in a direct line with the load bars to the channel in order to support the mass, and the feet are bolted at an angle to the channel. I feel like with enough weight that the torque on the channels could eventually shear the bolts right through them. Obviously it also depends on how much weight you have up there too. Couple of fishing rods, no problem. RTT, awning, and some people, and I think this could fail.
    I'm no structural engineer though, so correct me if I'm wrong.
  17. May 21, 2023 at 1:28 PM
    #817
    Burrrr
    KY
    2017 DCSB TRD Sport
    I completely agree. I don't love that these are positioned offset from the tracks. I think what I'm going to do is pick up another pair of the Leer mounting feet on the next 20% off sale and then place those in the center between the two existing pairs - mainly just to further distribute the load and relieve some strain. If I plan on putting a RTT or something heavy up there, I will likely just take the rack off and mount it right to the tracks when possible. In doing so, I'd also benefit by it being lower profile. Now that the brackets are all lined up, it's actually going to be pretty easy to add or remove the cap rack. So for the relatively light stuff, I think this will hold up just fine.
    Either way, I wanted to share the results because I know when I initially called Prinsu AND Alu-Cab, nobody was able to tell me with confidence whether I would need the Leer mounting feet to get this installed properly. So hopefully I can spare someone else from having to do the extra homework.
    By the way, did you get your cap yet? I saw in a different post that you were expecting it in April.
  18. May 21, 2023 at 1:59 PM
    #818
    TS4x4
    2018 TRD Offroad
    Gotcha, yeah that makes sense.
    Yes I did! Just picked it up last week. I sold the prinsu cap rack that I had and just went with their load bars. Super stoked on the setup.
    The black against the tan on your rig looks great btw.
  19. May 21, 2023 at 3:31 PM
    #819
    Burrrr
    KY
    2017 DCSB TRD Sport
    Hell yeah dawg, what do you think of their load bars? I was also on the fence about going that route. Looking forward to seeing some pics if you decide to post em on here
    And thanks! I appreciate that!
  20. May 21, 2023 at 4:13 PM
    #820
    TS4x4
    2018 TRD Offroad
    Honestly with a RTT I'll get the same functionality as I would have with the prinsu. The load bars have slotted channels to bolt things down to them. They're super heavy duty. I'll share some pictures of the setup when I get a chance.
