Let's see those Alu-cab setups
Discussion in '3rd Gen. Tacomas (2016-2023)' started by turbosmitty, Jul 28, 2018.
  1. Aug 10, 2023 at 7:09 AM
    #901
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    This looks great!
    I'm hoping to get mine in a week or two. I still need to order some replacement side bed rail caps since I have the OEM tonneau cover and mine are cut. I'll run some butyl? tape to try and seal it up a bit too.
    Did you install it yourself or pay someone? I'm looking to get one of these T plug and play deals for the brake lights. https://fbchs.square.site/product/t...true&sa=false&sbp=false&q=false&category_id=7
    Did you use one? I'm not sure if the regular one is needed or the one with the parking light.
    Does the third brake light on the cab shine into the cap at all?
    Road Bull[QUOTED] likes this.
  2. Aug 10, 2023 at 7:10 AM
    #902
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    This is what I did and it is the way. Rexing M2
    Road Bull likes this.
  3. Aug 10, 2023 at 10:05 AM
    #903
    Road Bull
    Road Bull Well-Known Member
    WA
    2022 Tacoma TRD OR; 2002 4Runner
    Thanks man. It takes a little getting used to losing some vision makes you really pay attention to the points of reference that you DO have. I will have to look into the rear view mirror back up camera. I mean... It could be worse. I could have a swing out tire carrier blocking the rest of my window and back-up camera. I'd have to get one with "the force" real quick like, if I had one of those.
    Nice! You will dig it. Sealing the tops of the bed rail is pretty easy. I found some good information here on the GFC forums. https://forum.gofastcampers.com/t/help-with-preparing-3rd-gen-taco-for-gfc-install/3476/15
    I like the rubber water proofing tape better than some of the other tape options. If you cut a small starter hole the rubber will have the ability to close back in around the post tab once installed. I can't imagine the metal style tape has the same elastic qualities.
    This is how I did mine. https://www.tacomaworld.com/threads/lets-see-those-alu-cab-setups.560930/page-43#post-28866608
    I had mine installed because I live in WA and ordered through MULE in OR. They are not open on the weekend, and I didn't have anyone to assist during the work week. I would have preferred to try to install myself, but it wasn't in the cards. I don't notice the brake light shining into the cab that much, so if it does, it's not distracting enough for me to notice. I think my cap comes with some simple quick disconnects on both sides of the canopy that feed the hi-mount brake light as well as the three internal manual lights that come standard. So between those lights and the OEM bed lights, there's a good amount of lighting options to cover your needs. Some have added even more LED lights to the roof.
    mrtonyd[QUOTED] likes this.
  4. Aug 11, 2023 at 8:48 PM
    #904
    Gunnisoncamping
    Gunnisoncamping Member
    Doug
    2023 TRD off-road
    I got mine installed today at Juniper Overland in Denver. IMG_4434.jpgIMG_4435.jpg
  5. Aug 11, 2023 at 9:16 PM
    #905
    mrtonyd
    Tony
    Colorado
    Oh man! Can I ask how your whole experience was? I ordered through them in June and am hoping to get it this month.
  6. Aug 12, 2023 at 7:03 AM
    #906
    Gunnisoncamping
    Doug
    2023 TRD off-road
    It was a great experience. They were very nice folks, it took them about 2.5 hours. I had ordered lock covers from Mule Expeditions, I left the lock covers on the front seat of my truck. They installed the lock covers without me asking them. They have all sorts of cool goodies you’ll want to waste money on in there showroom.
  7. Aug 12, 2023 at 1:43 PM
    #907
    WVLungbuster
    WVLungbuster Active Member
    2014 Reg Cab
    Can you open the back of the contours from the inside, what about fit and finish is it pretty water tight also?
  8. Aug 12, 2023 at 2:35 PM
    #908
    HarlessMcLaneJones
    HarlessMcLaneJones Member
    2012 - 6Speed - 3 inch lift - Tacoma
    ARE Bed Cap (1G3) 3” Rough Country Leveling Kit 255/80/17 on Steelies Swapped out stock grille for “Toyota” Grille
    Loving the look!
    I was considering the same thing for mine. I don’t even have an updated spare yet!
    I’m running comparably spec’d wheels, but pizza cutter style. Did you have to do a cab mount chop?
  9. Aug 12, 2023 at 2:55 PM
    #909
    TacoTrigger16
    TacoTrigger16 Well-Known Member
    Central Valley California
    2022 TRD OR 4x4 DCSB Super White
    Armor: RCI Plated 20 Degree Sliders RCI Full Skid Plates Steel RCI Fuel Skid RCI Rear Diff Skid SNS Designs ABS Guards Front Bumper: C4 Overlander with Full Hoops C4 Front Bumper Frame Support Brackets Bed: Total Chaos Bed Stiffeners Cali Raised Bed Light Kit Toyota Bed Mat Alu-Cab Contour Canopy Blue Sea 5025ST Fuse Block Blue Sea 4363 Switch Panel Victory 4x4 Front Bed Molle Panel Mountain Hatch Tailgate Table 3.0 Fire Extinguisher Shovel Axe Fatmax Extreme Lighting and Electrical: PowerTrays Essentially BantamX Spod Bantam X w/ Touchscreen Baja Designs 30” S8 Light Bar Driving Combo Baja Design Squadron Sport Diving Combo Baja Design Squadron SAE Fleece All Lights On Engine: K&N Drop In Air Filter Mishimoto Intake Hose Toyota Air Accelerator Toyota TRD Oil Cap Toyota TRD Radiator Cap ECGS Bushing SDHQ Terminal Kit Fumoto Engine Oil Drain Valve AC Drain Mod Exterior: De-Badged Black Tacoma Tailgate Letters Heritage Badge In Black/Grey/White AVS Rain Guards AVS Aeroskin Hood Protector Lftd Customs Taco Sauce Gas Cap Holder Tacoma License Plate Frame Black Sylvania License Plate LED Lights R4T Bumper Caps Meso Customs Headlight Trim Plate Meso Customs V5 Ultimate Turn Signals SDHQ Ditch Light Mount Rago Fab Antenna Mount Interior: Desert Does It Seat Jackers & MMP K&N In Cabin Air Filter Matte Black Steering Wheel Emblem Meso Customs Red Push To Start Meso Customs Vent Rings SW Meso Customs Climate Control Rings SW Meso Customs Interior Chrome Delete SW Meso Custom Minimalist Key Fob V2 SW Meso Customs Extended Fuse Cover AJT Designs Door Handle Covers Z Precisions Cup Holder Midland MXT275VP4 Yodaverse Interior LED Kit Yodaverse Center Console Organizer TacoMods Radio Knobs w/ Backlighting Headrest Paracord Grab Handles SOG Rapid Rescue Dongar Technology Mirror Adapter Garmin Dash Cam Mini 2 Baby Toyoda Square Center Console Insert WeatherTech FloorLiner HP Grey Expedition Essentials 3TPAM Ram Mount Accessories GoGettaGrip Shifter Knob Magnetic Mic Patches Suspension Lift: DuroBumps Front Bump Stops Icon Billet UCA’s Delta Joint All-Pro Sway Bar End Links Marlin Crawler HD LCA Frame Brace Bison Offroad Cam Stop Kit Total Chaos Cam Tab Gussets Total Chaos Cab Mount Chop Plates Total Chaos Spindle Gussets W/ Sway Bar Accutune Fox 2.5 DSC Front Shocks Accutune Fox Tundra 2.5 DSC Rear Shocks Accutune 2.5” Bump Stop & U Bolt Flip Deavers U402 Stage 1 Yota Mafia Rear Extended Brake Lines 24” ARB Carrier Bearing Drop Kit FK29 Archive Garage Hammer Hangers Archive Garage 3.6 Shackles Archive Garage High Clearance Cross Tube Wheels and Tires: SCS F5 16x8 -25 Offset 3.5 BS Gunmetal Mickey Thompson Baja Boss M/T 285/75R16 Gorilla M12x1.5 Lug Nuts ET Liftd Customs Leashed Valve Stem Caps Winch: Warn VR Evo 10-S Warn Wireless Hub Factor 55 1” Fairlead Factor 55 Rope Guard Factor 55 UltraHook Gray Tandem Offroad Control Box Mount LambTek Innovation Switch Bracket Kit Blue Sea Switch Recovery: Factory 55 HitchLink 2.0 Warn Epic Shackle x2 ARB Tree Saver 16’ Special Thanks to: Sibi Built for the lift installation. Tiny Rig Co for the Alu-Cab and installation. Accutune for the Fox Shocks with Adventure Tune. Baja Designs for lighting. C4 Fab for the front bumper. RCI for sliders and skids.
    I have not found a way stock. However, I have found these.
    https://www.canopylocks.com.au/alu-cab.html
  10. Aug 12, 2023 at 11:03 PM
    #910
    Road Bull
    WA
    Yeah. My full size spare is hanging in my bed, laying down like a hobo. For now...
    I anticipated larger 33/34" tires when I got my Tacoma. It was one of the first mods that I did, because I knew it would require some planning. I think the 285/75/17 is a nice compromise as far as tire size that gives you good over height, but isn't crazy wide. That helps. I would think 295/70/17 might be harder to fit due to overall width.
    My CMC is fairly aggressive and I have heat-gunned the wheel well liner out of the way. That's it so far. I need to see what if anything still rubs when it's flexed out. So far, I have yet to hear it. I think the SCS 17x8.5 -10mm offset wheels help a bit too. Although that spec isn't too common, I like where it sits. It takes this size tire right up to the edge of the wheel flares. I plan on doing the 5-wheel rotations. I am excited to see how these Toyo AT3's do this winter. It's been a while since I've had an 3-peak AT tire for winter driving.
  11. Aug 15, 2023 at 10:01 AM
    #911
    mrtonyd
    Tony
    Colorado
    bummer day.
    called juniper and sounds like my contour won't be in until septemeber or october... They aren't sure if its shipped or not but definitely isn't state side yet.
    Looks like I have to order some bars to go over my tonneau cover for my Oregon trip in Sept.
    Oh well
  12. Aug 15, 2023 at 3:37 PM
    #912
    christsay
    christsay Well-Known Member
    chris
    Austin, TX / Santa Fe, NM
    2021 Army Green DCLB TRD 4x4
    JB Grand Raid Evo XXL mounted on an Alu-Cab. 5.29 gears.
  13. Aug 15, 2023 at 9:57 PM
    #913
    Relyk711
    Relyk711 Well-Known Member
    Kyler
    Santa Cruz
    2018 TRD Pro Black - 1999 Pre-Runner Black
    Alucab Canopy Camper BAMF HC Dual Swingout Rear bumper BAMF Sliders Westcott 1.5" TRD pro lift Icon RXT option3 leaf pack Rago HD Shackles & Hangars BFG KO2 285/75/16 CBI T3 Aluminum front bumper Warn EVO 10S Total Chaos Bed stiffeners Home built Aluminum HDPE bed platform.
    Questions for the guys with 5ft beds and canopy campers... Im looking at one used and wondering how much I'll need to change my current setup.
    1. Do you have bed stiffeners or did you need to remove them? Mine from total chaos bolt into the metal rear upright supports and onto the bed mount on the bottom. There is still a couple inches before the tailgate but seeing those fitment panels makes me question if I'll have to remove them.
    2. If I do have to remove them, I currently have a platform that spans the whole bed. It kind of sits in snuggly. Will I have to trim/remove that?
  14. Aug 15, 2023 at 9:59 PM
    #914
    tacoterry33
    tacoterry33 Well-Known Member
    Terry
    Grants Pass, OR
    Army Green 2021 Tacoma Off-Road Dbl Cab
    Bilstein 6112 Fuel Rebel 6 Wheels 285/65r18 Toyo AT3 Tires TRD Skid Plate Borla Exhaust
    I have total chaos bed stiffeners with my canopy, but just have the canopy, not the canopy with camper.
    TacoTrigger16 likes this.
  15. Aug 16, 2023 at 6:54 AM
    #915
    MR E30
    Michael
    I have bed stiffeners installed with my canopy camper. You will be able to work them in there (or leave them as they are, I installed mine after setting my CC on my truck bed).
    Where does the platform sit? Wheel well height? Is it one large, flat piece? If it is one large piece then you either need to set it in there before you install the CC, or you need to modify it to be two (or more) pieces. The rear door is large, but not 'an entire 4'x5' piece of ply' large.
    Relyk711[QUOTED] likes this.
  16. Aug 16, 2023 at 7:13 AM
    #916
    Relyk711
    Kyler
    Santa Cruz
    It's modular, 7 pieces with 3 support racks. Good to know about the stiffeners, thank you. The support pieces are 20"x36"x8" and the platform pieces are roughly 30"x20"
    Road Bull and MR E30[QUOTED] like this.
  17. Aug 16, 2023 at 7:30 AM
    #917
    MR E30
    Michael
    You will have no problem working those through the rear door, and the height above the bed floor will not be an issue with the CC.
  18. Aug 16, 2023 at 10:30 AM
    #918
    Wackyhacky
    Wackyhacky A Well Known Troublemaker
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    I had the TC stiffeners on my truck before I went with the Canopy Camper and was told I could remove them. The rear bulkhead assembly is essentially one big bed stiffener so they are not necessary with the CC. Once again, this is for the campers, not the caps.
    MJTH likes this.
  19. Aug 16, 2023 at 10:44 AM
    #919
    MR E30
    Michael
    I agree with this, but I still added bed stiffeners. Color me overly cautious I guess.
  20. Aug 16, 2023 at 11:04 AM
    #920
    Relyk711
    Kyler
    Santa Cruz
    I would prefer leaving them if possible as well. It looks like the bottom plate uses the inner bolt hole that the TC bolt into. I finally found some install documentation,
    It looks like the fill panels bolt outward of the stiffeners so I can probably remove them and lengthen the vertical bolt holes a tad. (The thickness of the bottom plate). At the very least I'll need to remove them for install. Thanks for the quick replies guys.
    MR E30[QUOTED] likes this.
