Let's see those Alu-cab setups
Discussion in '3rd Gen. Tacomas (2016-2023)' started by turbosmitty, Jul 28, 2018.
  1. May 28, 2024 at 10:43 AM
    #1241
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Great setup. Might you share the source of that camlock fitting for your water tank?
  2. May 28, 2024 at 12:10 PM
    #1242
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    is there an even amount of bed rail exposed on both sides and do you have stiffeners in?
    I noticed on mine there is less bed rail visible near the tailgate than the cab. I'm wondering if its because i have bed stiffeners in to make the back a true 90 degrees or if the bed is actually supposed to be flared out a little.
  3. May 28, 2024 at 12:28 PM
    #1243
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Anyone have a good silicone adhesive they like to use that is semi-permanent but ultimately removeable without making a huge mess?
    I have a few things mounted with 3m tape to the roof of my Alu Cab, but it's starting to get into the low 90's in Charlotte, and the 3m tape is failing.
  4. May 29, 2024 at 7:05 AM
    #1244
    Relyk711
    Relyk711 Well-Known Member
    Kyler
    Santa Cruz
    2018 TRD Pro Black - 1999 Pre-Runner Black
    Alucab Canopy Camper BAMF HC Dual Swingout Rear bumper BAMF Sliders Westcott 1.5" TRD pro lift Icon RXT option3 leaf pack Rago HD Shackles & Hangars BFG KO2 285/75/16 CBI T3 Aluminum front bumper Warn EVO 10S Total Chaos Bed stiffeners Home built Aluminum HDPE bed platform.
    The bed is flared a little. I think about 1" between bulkhead and tailgate. It's not huge but it is noticeable when everything else is square.
    mrtonyd[QUOTED] likes this.
  5. May 29, 2024 at 8:22 AM
    #1245
    SlippRott
    SlippRott Well-Known Member
    22 Silver OR
    Planning...suspension, front slimline bumper, winch, full skids, 2" lift, SCS Ray 10's, Pizza cutters, Power Tray, Switch-Pro, Alu-Cab Contour Canopy.
    I have bed stiffeners installed also (actually just did it before putting on the Alu-Cab) and it is slightly different from front to back but not terrible. I will try to take some pictures later and share so we can compare.
  6. May 29, 2024 at 10:28 AM
    #1246
    snakemetz
    snakemetz Member
    Jake
    2018 Tacoma Sr5
    Anybody know of a way to adjust the gas struts on the alu cab canopy to stop at a particular position? I have an awning above the door and would like it to stop sooner if possible
  7. May 29, 2024 at 1:04 PM
    #1247
    mrtonyd
    Tony
    Colorado
    these are my bed rails. its not a huge difference, just something i noticed
    https://imgur.com/a/QXMc5iI
  8. May 29, 2024 at 1:05 PM
    #1248
    mrtonyd
    Tony
    Colorado
    i think its either replace the struts, or move it to one of the three holes on the doors.
    MR E30 likes this.
  9. May 29, 2024 at 5:27 PM
    #1249
    SlippRott
    22 Silver OR
    Here is mine
  10. May 31, 2024 at 6:33 AM
    #1250
    jayandersen5
    jayandersen5 Well-Known Member
    Jay
    South Carolina
    2017 TRD Pro
    OTT Tuned Yukon 5.29s 35x12.50r17 Yokohama MTs RRW RR7-H Wheels Dobinsons MRRs RRW hybrid front bumper ATH rear swing out high clearance bumper Alucab Explorer Canopy iKamper skycamp 2.0 Diode Dynamics SS3 (x4) and SSC2 SOS Sliders C4 full skids Smittybilt X20 Gen3 10k winch Prinsu Cabrack Expedition Essentials 3TPAM Caliraised 40" light bar ExtremeLED 30" light bar Total Chaos spindle/cam tab gussets and bed stiffeners Switch Pro SP9100 Power Tray
    Has anyone replaced the gas struts for the side doors on an explorer canopy? Wanting to get some shorter struts so the doors don't swing up as high into the tent/awning.
  11. Jun 6, 2024 at 8:27 AM
    #1251
    wazepd
    wazepd Waze Map Editor
    NJ / NY
    2022 Tacoma TRD Off Road
    Commercial Pilot
    Good news for me, someone cancelled their order and I was able to pick up the Contour a week after placing the order
    Bad news - install was a PITA... I used up all the shims just on 4 corners, don't even have enough to shim up the middle mounts
    And the mounts closest to cab had to even be shimmed from the side because my bed and rail were too far in??? I have bed stiffeners and never carried probably more than 200lbs in the bed, not sure what happened - should I contact Alu Cab for more shims?
    I followed their 2016 Contour install pdf, had to completely exclude the spacers for the bed rail because they wouldn't line up with the mounts attached to the cap itself, the hardware given wasn't the same as their install guide (no button head hex hole M8 or spring washers)
    [​IMG] [​IMG]
    MGMDesertTaco likes this.
  12. Jun 6, 2024 at 8:52 AM
    #1252
    mrtonyd
    Tony
    Colorado
    i didnt install mine myself, but think the corners near the cab have more shims than the ones by my tailgate. not sure if the company compressed the back more or what, but the shell looks closer to the bed back there.
    edit*: some pics
    https://imgur.com/a/IcrKbI9
  13. Jun 7, 2024 at 9:26 AM
    #1253
    wazepd
    NJ / NY
    Commercial Pilot
    so here’s what my corner mounts look like by the cab, I had to shim between the rail and mount to get the bolt to line up vertically, only for the front corners…
    Had to go pickup some 5/16 fender washers to shim the middle mounts since I ran out of the provided shims, install pdf is from 2016 so wish they updated it the current parts they give
  14. Jul 5, 2024 at 2:39 PM
    #1254
    Aspiringhobo
    Aspiringhobo Member
    ‘23 Taco TRD O/R with that Alu-Can Canopy
    Does this qualify?
  15. Jul 8, 2024 at 8:47 AM
    #1255
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    You bet it does. Looks great. What are the plans?
  16. Jul 8, 2024 at 9:03 AM
    #1256
    Aspiringhobo
    Aspiringhobo Member
    First things first, seal all the damn leaks! Bed seal leaks, rivets on the wall leaks, I’m swimming.
    I have solar and a fridge already setup, just building a small 2020 frames cabinet to hold the battery and some gear.
    RiverMando and MR E30[QUOTED] like this.
  17. Jul 8, 2024 at 9:03 AM
    #1257
    Fullsendcf
    Fullsendcf Well-Known Member
    Craig
    SF - Bay Area
    '18 Cement TRD OR
    Starting to dial it in
  18. Jul 8, 2024 at 9:05 AM
    #1258
    MR E30
    Michael
  19. Jul 13, 2024 at 2:15 PM
    #1259
    G-Dudeman
    G-Dudeman Member
    2024 6’ Tacoma
    I have a 8' ARB awning I just purchased. I wanted to be able to take it off and put it back on by myself. How hard is it to get on and off?
    https://ok4wd.com/arb-awning-with-light-arb814411/
  20. Jul 13, 2024 at 3:27 PM
    #1260
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Taking it off, I was able to do it myself. Putting it back on was a little more difficult because of how the bolts slide into the load bar. Wasn’t terrible but I just couldn’t get it lined up alone.
    G-Dudeman[QUOTED] likes this.
