Let's see those Alu-cab setups
Discussion in '3rd Gen. Tacomas (2016-2023)' started by turbosmitty, Jul 28, 2018.
  1. Oct 11, 2024 at 10:01 AM
    #1301
    assist
    assist Roadside Assistance
    New Hampshire
    2022 Silver TRD S 4X4
    Can anyone who has a Contour Canopy with windows comment on if the passenger side window makes any difference in blindspot visibility? (a picture would be even better)
    Considering setting one up with no window on the driver side, to have a shelf/cubby for easy access to gear from the outside door, but having a window on the passenger side for better road visibility...
  2. Oct 11, 2024 at 10:02 AM
    #1302
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    does the cabinet cover the top rails or the side rails?
  3. Oct 11, 2024 at 10:10 AM
    #1303
    amudie
    amudie Veteran Member
    Andrew
    Pennsylvania
    2018 Tacoma TRD-OR DCLB
    AluCab Canopy SSO Slimline Hybrid Bumper w/ 10k winch and 20" Hiese light bar.
    VHB Tape is a good option if you don't want to drill.
  4. Oct 12, 2024 at 12:04 PM
    #1304
    TacoTrigger16
    TacoTrigger16 Well-Known Member
    Central Valley California
    2022 TRD OR 4x4 DCSB Super White
    Armor: RCI Plated 20 Degree Sliders RCI Full Skid Plates Steel RCI Fuel Skid RCI Rear Diff Skid SNS Designs ABS Guards Front Bumper: C4 Overlander with Full Hoops C4 Front Bumper Frame Support Brackets Bed: Total Chaos Bed Stiffeners Cali Raised Bed Light Kit Toyota Bed Mat Alu-Cab Contour Canopy Blue Sea 5025ST Fuse Block Blue Sea 4363 Switch Panel Victory 4x4 Front Bed Molle Panel Mountain Hatch Tailgate Table 3.0 Fire Extinguisher Shovel Axe Fatmax Extreme Lighting and Electrical: PowerTrays Essentially BantamX Spod Bantam X w/ Touchscreen Baja Designs 30” S8 Light Bar Driving Combo Baja Design Squadron Sport Diving Combo Baja Design Squadron SAE Fleece All Lights On Engine: K&N Drop In Air Filter Mishimoto Intake Hose Toyota Air Accelerator Toyota TRD Oil Cap Toyota TRD Radiator Cap ECGS Bushing SDHQ Terminal Kit Fumoto Engine Oil Drain Valve AC Drain Mod Exterior: De-Badged Black Tacoma Tailgate Letters Heritage Badge In Black/Grey/White AVS Rain Guards AVS Aeroskin Hood Protector Lftd Customs Taco Sauce Gas Cap Holder Tacoma License Plate Frame Black Sylvania License Plate LED Lights R4T Bumper Caps Meso Customs Headlight Trim Plate Meso Customs V5 Ultimate Turn Signals SDHQ Ditch Light Mount Rago Fab Antenna Mount Interior: Desert Does It Seat Jackers & MMP K&N In Cabin Air Filter Matte Black Steering Wheel Emblem Meso Customs Red Push To Start Meso Customs Vent Rings SW Meso Customs Climate Control Rings SW Meso Customs Interior Chrome Delete SW Meso Custom Minimalist Key Fob V2 SW Meso Customs Extended Fuse Cover AJT Designs Door Handle Covers Z Precisions Cup Holder Midland MXT275VP4 Yodaverse Interior LED Kit Yodaverse Center Console Organizer TacoMods Radio Knobs w/ Backlighting Headrest Paracord Grab Handles SOG Rapid Rescue Dongar Technology Mirror Adapter Garmin Dash Cam Mini 2 Baby Toyoda Square Center Console Insert WeatherTech FloorLiner HP Grey Expedition Essentials 3TPAM Ram Mount Accessories GoGettaGrip Shifter Knob Magnetic Mic Patches Suspension Lift: DuroBumps Front Bump Stops Icon Billet UCA’s Delta Joint All-Pro Sway Bar End Links Marlin Crawler HD LCA Frame Brace Bison Offroad Cam Stop Kit Total Chaos Cam Tab Gussets Total Chaos Cab Mount Chop Plates Total Chaos Spindle Gussets W/ Sway Bar Accutune Fox 2.5 DSC Front Shocks Accutune Fox Tundra 2.5 DSC Rear Shocks Accutune 2.5” Bump Stop & U Bolt Flip Deavers U402 Stage 1 Yota Mafia Rear Extended Brake Lines 24” ARB Carrier Bearing Drop Kit FK29 Archive Garage Hammer Hangers Archive Garage 3.6 Shackles Archive Garage High Clearance Cross Tube Wheels and Tires: SCS F5 16x8 -25 Offset 3.5 BS Gunmetal Mickey Thompson Baja Boss M/T 285/75R16 Gorilla M12x1.5 Lug Nuts ET Liftd Customs Leashed Valve Stem Caps Winch: Warn VR Evo 10-S Warn Wireless Hub Factor 55 1” Fairlead Factor 55 Rope Guard Factor 55 UltraHook Gray Tandem Offroad Control Box Mount LambTek Innovation Switch Bracket Kit Blue Sea Switch Recovery: Factory 55 HitchLink 2.0 Warn Epic Shackle x2 ARB Tree Saver 16’ Special Thanks to: Sibi Built for the lift installation. Tiny Rig Co for the Alu-Cab and installation. Accutune for the Fox Shocks with Adventure Tune. Baja Designs for lighting. C4 Fab for the front bumper. RCI for sliders and skids.
    There is no visibility from the drivers seat out those windows. Maybe if a simi truck was passing you but otherwise you can’t see out them. I use them mostly for air in the rear.
    MGMDesertTaco and assist[QUOTED] like this.
  5. Oct 12, 2024 at 12:49 PM
    #1305
    Road Bull
    Road Bull Well-Known Member
    WA
    2022 Tacoma TRD OR; 2002 4Runner
    I did a fair amount of research online and youtube when the Contour was fairly new. I remember coming across someone being honest about their rear window visibility and saying your really can't see much of anything out of those windows. I mean.. They will offer "slightly" more than no window, but that angle isn't great anyway. Maybe if you also got rid of your rear seat headrests? Perhaps? I like the look, less complicated with fewer failure points, and slightly more security from prying eyes. I think they both look good though.
  6. Oct 13, 2024 at 7:03 AM
    #1306
    Dtax
    Dtax Well-Known Member
    Massachusetts
    2017 Black Tacoma Sport
    Mods = N+1
    I have a wolf box review mirror on my bench for install - perhaps not the side view the question is referring to, but I cannot wait to get this installed. Plan to mount the rear camera on an alu cab cross bar i have mounted as far back as possible on the roof canopy rails.
    cant wait for this and food for thought for you all.
    Speaking of which anyone else mount up a wolf box set up?
    curious on cable length to get the camera mounted all the way back there?
    I have a few of their sizes and only want to run it once but don't want too much excess.
    appreciate any insights.
    TacoTrigger16[QUOTED] likes this.
  7. Oct 13, 2024 at 9:01 AM
    #1307
    305QSTRD
    305QSTRD Member
    Anyone here have a prinsu rack mounted to their Contour Canopy? If anyone could share their insight with pictures, it would be greatly appreciated, if even possible. Have tried searching everywhere with no luck.
    Burrrr and TacoTrigger16 like this.
  8. Oct 14, 2024 at 9:01 AM
    #1308
    assist
    New Hampshire
    Thanks guys, probably going to go with no side windows then and just keep it simple. Maybe I could pick up some side mirrors with a wider angle. The truck also has BSM so not too big of a deal
    Road Bull[QUOTED] likes this.
  9. Oct 14, 2024 at 3:03 PM
    #1309
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    SOLD
    I have a used Dickinson P9000 LPG fireplace and the GP Factor mounting kit, specific to the Alu-Cab Canopy Camper, for sale.
    The fireplace has ~250 hours of use on it, and is in excellent shape. It functions just as intended, and has no damage of issues. I am selling it because I am moving away from LPG in my camper and thus won't have any fuel to run this thing anymore.
    Since it was previously installed in my camper, I have already cut the exhaust pipe and modified and fitted the chimney cap per GP Factors instructions, which was difficult to do. All of the mounting hardware is present, and I left more wiring attached to the fan motor than Dickinson originally gave me.
    Please find photos of the unit and bracket after removal from the camper:
    [​IMG]Dickinson For Sale by Michael Rickerd, on Flickr
    Here are two photos of the fireplace and chimney installed on my camper (Note; if you have the rear molle panels you have to cut a chunk out of one for the chimney):
    [​IMG]HSWOR - Day 7 - 125 by Michael Rickerd, on Flickr
    [​IMG]Fireplace! by Michael Rickerd, on Flickr
    I paid exactly $1,645.57 for these two items, and would like to list them for sale for $1,300 usd shipped anywhere in the contiguous US.
    At this point in time I am not interested in splitting up the fireplace and the mounting bracket. I'd like to sell them together.
    Please let me know if you have any questions.
    rob1208 likes this.
  10. Oct 21, 2024 at 6:16 AM
    #1310
    ScottThePainter
    ScottThePainter Well-Known Member
    2023 TRD Off-Road Magnetic Grey
    Loving the positive pressure vent on the Contour. This is that lovely fine gravel dust. there is zero inside the bed, even around the tailgate.
  11. Oct 21, 2024 at 8:03 AM
    #1311
    mrtonyd
    Tony
    Colorado
    how is that hitch extension? the bars on my bikes are within an inch of the back window when i use my 1up pulled as far out as i can with the lock still in the hitch. i was thinking of getting one of those swingarms.
    though i did drive down some rough roads by crested butte with my bike on the hitch and no glass cracked. definitely left a big mark in the bottom of the rack going over some rocks though
  12. Oct 21, 2024 at 1:25 PM
    #1312
    ScottThePainter
    It’s the 1up extension and it’s super solid. I ended up getting a Kuat Pivot after seeing a guy that had one this weekend (overnight Amazon shipping ftw). The extension serves its purpose but I was immediately annoyed while loading my bed and hitting my shins on the rack constantly.
    MR E30 and mrtonyd[QUOTED] like this.
  13. Oct 22, 2024 at 5:12 PM
    #1313
    SlippRott
    SlippRott Well-Known Member
    22 Silver OR
    Planning...suspension, front slimline bumper, winch, full skids, 2" lift, SCS Ray 10's, Pizza cutters, Power Tray, Switch-Pro, Alu-Cab Contour Canopy.
  14. Oct 22, 2024 at 5:26 PM
    #1314
    wazepd
    wazepd Waze Map Editor
    NJ / NY
    2022 Tacoma TRD Off Road
    Commercial Pilot
    57kgs / 125lbs is too heavy for the bed of a Tacoma? Its aluminum, weighs less than other fiberglass / steel caps
  15. Oct 22, 2024 at 5:40 PM
    #1315
    ScottThePainter
    I’d love to see how you have the Dometic faucet on the cabinet. Been wanting to do something similar. Also, what molle panels are those?
  16. Oct 22, 2024 at 5:41 PM
    #1316
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    Agreed. They're literally less than half the weight of fiberglass caps. AFAIK Alucab canopies are the lightest option in the Tacoma space.
    I’d install some bed support brackets with a cap, but outside of that? Send it.
  17. Oct 22, 2024 at 7:36 PM
    #1317
    mrtonyd
    Tony
    Colorado
    Gfc is also really light. Could probably be lighter if you don't get windows.
    On a side note, anyone with the alucab cross bars know if the groove goes on the front or the back? There's one on top and bottom, but one of one side too
  18. Oct 22, 2024 at 8:54 PM
    #1318
    Cetacean Sensation
    PNW
    You got me curious, so I just checked both on their manufacturer respective sites. GFC claims 135lbs while Alu-Cab claims 125lbs. Alu-Cab with windows is apparently only 136, too.
    That's near as makes no difference in practice, IMO. But it's nice to have the numbers.
    mrtonyd[QUOTED] likes this.
  19. Oct 22, 2024 at 9:12 PM
    #1319
    antwon412
    antwon412 Well-Known Member
    2022 Gladiator Mojave
    Lifted. Locked F/R. Method 705s. 37s.
    My mistake. I was talking about the full Alu-Cab canopy camper. I must’ve misread the post that I had responded to.
  20. Oct 23, 2024 at 3:54 AM
    #1320
    Dtax
    Massachusetts
    Mods = N+1
    dont think it matters but for where you may want to use that side grove to mount something like chase lights for example.
    I had my rear one facing back for that hope one day but ended up flipping it as I wanted the bar as back as far as it could go the way the Alu can mounts work to carrry a canoe.
    as a side note I have the lowest profile / height mounting brackets that mount to the cross bars on the side track being referred to.
