Let's see your 1st Gen switch setups!
Discussion in '1st Gen. Tacomas (1995-2004)' started by MapleMoose, Mar 5, 2013.
  1. Apr 6, 2024 at 9:33 AM
    #261
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Has anyone come across a volt meter or trans temp gauge that would fit in a paranoid fab bracket?
    Yossarian likes this.
  2. Oct 24, 2024 at 7:23 AM
    #262
    GyvesHD
    GyvesHD Well-Known Member
    Edgar
    2000 Toyota Tacoma SR5 4X4
    https://rubyoffroad.com/ uses the factory ash tray for 1st Gen Tacoma and 3rd Gen 4Runners mainly for auxbeam but he can make custom ones if you can provide dimensions. Had a custom one made for my Vosswitch overall super happy with the location and build quality and material. You can use my discount code “Ruleteando” at check out for a discount on your order.
    dzuf, 15psd, tacoma_ca and 1 other person like this.
  3. Oct 24, 2024 at 8:21 AM
    #263
    cynicalrider
    cynicalrider #NFG
    Jersey
    That's incredibly clean.
  4. Oct 24, 2024 at 9:10 AM
    #264
    GyvesHD
    Edgar
    No drilling suction cups or double side tape used factory location easy install. 10/10 would recommend
  5. Oct 24, 2024 at 9:12 AM
    #265
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    For the upper switches left to right. They look pink when parking lights are on and illuminate red when activated
    1. Fogs
    2. Dual function reverse in rear bumper: up on with reverse, center off, down constant on
    3. Dual function light bar on bumper: up white, center off, down amber
    4. Rock lights
    I like my double din stereo, biggest deterrent from putting switches under the stock stereo, that and I like everything in one place and on the same hand controlling high beams. If I add a front locker I might move the dual battery switch to the clock, or might go away from the Blue Sea setup and go for a BCDC charger.
    Getting my wedge camper installed Monday after a 10 month wait :woot:any switches for outdoor floods, etc will go in there.
  6. Oct 24, 2024 at 9:15 AM
    #266
    Laxtoy
    Maltby, WA
    That’s a great use of space
    GyvesHD[QUOTED] likes this.
  7. Mar 19, 2025 at 6:41 PM
    #267
    snazycummins
    snazycummins New Member
    Light bar and ditch lights. Simple clean set up. Need to get some updated charging ability for
  8. Mar 28, 2025 at 6:08 AM
    #268
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    This blows all the other ash tray switch panels out of the water wow. I know what I'm getting soon
  9. Mar 28, 2025 at 7:53 AM
    #269
    mootiger49
    mootiger49 It’s mine, not yours!
    23’ Lunar Rock OFF ROAD. 24’ Underground 4-Runner. 2000 IJM OFF ROAD
    V2 grille OTT Tune 5100’s Pro rims
    What type of tool are you guys using to cut rectangle cut outs into the dash?
    I need to mount my switches and wasn't sure the best way to do this.
  10. Mar 28, 2025 at 7:56 AM
    #270
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Dremel with a plastic cut-off wheel.
    mootiger49[QUOTED] likes this.
  11. Mar 30, 2025 at 9:11 PM
    #271
    warmingupmymind
    warmingupmymind Well-Known Member
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    Paranoid Fab custom switchpros ashtray mount
    PXL_20250330_223917729.jpg PXL_20250330_223943246.jpg PXL_20250330_223949997.jpg
  12. Apr 1, 2025 at 6:57 AM
    #272
    cynicalrider
    cynicalrider #NFG
    Jersey
    What head unit is that with that much tilt?
  13. Apr 1, 2025 at 9:24 PM
    #273
    warmingupmymind
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    Kenwood Excelon DMX957XR at full tilt
