Let's see your FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO828, Oct 11, 2016.
  1. Jun 5, 2021 at 2:23 PM
    #2141
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Not quite friend. That is my FJ part time case.
    But thanks for the assist.
    whatstcp, BillDaCat8 and llamasmurf like this.
  2. Jun 5, 2021 at 3:04 PM
    #2142
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    My bad. Overlooked the AWD part and just saw FJ case.
    BillDaCat8 and Ricardo13x like this.
  3. Jun 5, 2021 at 3:11 PM
    #2143
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    @6 gearT444E
    I not sure the toggle switch for disabling anything traction control related is needed, at least in my 2015 Off road it does not seem needed.
    I can push and hold the traction control button for 5 seconds, this disables ALL traction aids. I thought taking out the 4WD ECU effected this. It does not. I tried it out today, since it was the 1st time I have had to get the rig out since we modified it.
    I can still disable all traction aids in 4hi and pin it, it will just spin tires, no traction control lights flashing or getting involved in digging a couple holes.
    Put the anytime locker on in 4hi and do the same, 3 holes created instead of 2.
    :notsure:
    Leave the traction control on, in 4hi and pin it. Almost instantly it starts using the braking system to try and assist. Then throttles the engine shortly after it is not happy the brakes are doing enough.
  4. Jun 7, 2021 at 12:22 PM
    #2144
    llamasmurf
    Wes
    Northern Ontario
    BillDaCat8[QUOTED] likes this.
  5. Jun 8, 2021 at 8:41 PM
    #2145
    6 gearT444E
    Deep South
    Herculiner Hootus
    I never said it was, you can disable traction control in the 09+ trucks by holding the button for a few seconds, doesn't matter whether then truck thinks you're in 2hi, 4hi, or 4LO. What I did say was that if you want to be able to access the different traction control modes you will need the toggle switch. For example, Auto LSD which is only available in 2HI, TRAC which is available in 4HI, and ATRAC in 4LO.
  6. Jun 8, 2021 at 8:55 PM
    #2146
    6 gearT444E
    Deep South
    Herculiner Hootus
    I am not a traction control GURU by any means, but this fellow explains all the different features available. If you don't add a toggle switch, you will only get half these traction modes as your skid control ECU will either be permanently in 2WD OR 4WD, but it will not automatically switch between them once you delete the ADD switch and actuator.
    https://www.tacomaworld.com/threads...lsd-trac-off-vsc-off-a-trac-rr-locker.577229/
    tacoma16, llamasmurf and Ricardo13x like this.
  7. Jun 9, 2021 at 5:48 AM
    #2147
    llamasmurf
    Wes
    Northern Ontario
    Simple as I misunderstood, you explained it perfectly the 1st time, and again.
    :fistbump:
    I understand now, took me long enough :duh:
  8. Jun 14, 2021 at 10:53 AM
    #2148
    llamasmurf
    Wes
    Northern Ontario
    Added some sound deadening stuff to try an eliminate the new noises. :rolleyes: Worked really well.
    Now I want 3 of the same nobs.
    My stock transmission nob, does not fit with the twin sticks. With the twin stick in 4lo the transmission shifter can not go to Park.
    How can I get 3 of the same nobs? Or just the same as the twin stick black nob, for the transmission. The transmission is a different thread size. :bananadead:
  9. Jun 14, 2021 at 11:00 AM
    #2149
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    make all 3 the same thread pitch? Or convert the ones that are not, to match the others?
    llamasmurf[QUOTED] likes this.
  10. Jun 14, 2021 at 11:15 AM
    #2150
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    This is what I did. I could not find the knobs I wanted with the threads I needed, so I just bought the knobs I wanted, cut the ends off my shifters and welded bolts to the end with the matching threads.
  11. Jun 14, 2021 at 11:17 AM
    #2151
    fatfurious2
    David
    Ashburn, VA
    that or retapping the threads..
    Littles[QUOTED] likes this.
  12. Jun 15, 2021 at 3:37 AM
    #2152
    parel
    parel Well-Known Member
    Kin
    Calgary, AB
    (ex. 2014 Black Tacoma TRD)
    OEM FJ TRIBUTE EDITION (REPLICA)
    Get those “ridiculously over engineered billet aluminum shift knobs” made up as a set with mini versions of the main knob!
    907rx7 and llamasmurf[QUOTED] like this.
  13. Jun 20, 2021 at 11:35 AM
    #2153
    Jwithers
    Jwithers Master baiter
    Jacob
    Charlotte NC
    07 ACLB SR5
    OME 885 & Bilstien 5100 JBA UC DAKARS & OME NITROS Timbren Active bumps SOS Hybrid Front SOS sliders and skids
    You ever do anything with this?
  14. Jun 20, 2021 at 1:38 PM
    #2154
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    You really need to come look in my garage :anonymous:
    Jwithers[QUOTED] likes this.
  15. Jun 20, 2021 at 1:44 PM
    #2155
    Jwithers
    Jacob
    Charlotte NC
    07 ACLB SR5
    You bout ready to get started? I’m starting to put a list together. My 4wd has been acting up recently
    ovrlndkull[QUOTED] likes this.
  16. Jun 20, 2021 at 1:57 PM
    #2156
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yeah no mine requires a lot more and I may sell what I have and do something different. Contact Connor at 12thstateoffroad for the ADD switch and harness.
  17. Jun 20, 2021 at 2:28 PM
    #2157
    Jwithers
    Jacob
    Charlotte NC
    07 ACLB SR5
    Can’t I get a FJ axle tube and bypass it somehow?
  18. Jun 20, 2021 at 2:28 PM
    #2158
    Jwithers
    Jacob
    Charlotte NC
    07 ACLB SR5
    What do you have??.. if you go to sell keep me in mind..
  19. Jun 20, 2021 at 3:40 PM
    #2159
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    You can but if you do that I'd drop the front DS. If you swap tubes you'll be spinning the whole front driveline driving and it will rob MPGs. For a dd not very fun. Thats how I'm gonna roll just take the front DS out driving around then put it in for wheeling.
  20. Jun 20, 2021 at 3:42 PM
    #2160
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I have a TG verso case and doubler. Essentially an Inchworm lefty just TG brand. It's all Toyota gear driven and triple sticks. If I sold I'd get the new northwest fab doubler and an NP241 with the 4:1 ratio or a NP231 and put the 4:1 gearing in it.
