Let's see your FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO828, Oct 11, 2016.
  1. Jul 4, 2021 at 10:36 PM
    #2201
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    I had the non-ADD tube swapped in on mine. No change in mpg's on the highway. I have one on the way for my current taco as well.
  2. Jul 4, 2021 at 10:42 PM
    #2202
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    You do you. I have failed at getting out and camping, it hurts me. I have had a couple of weekends where I had nothing going on and it took two weekends and a the second calling in sick on a Monday to finally enjoy some relaxation. Get it while you can and enjoy all of it. Im just razing you. :D
    fatfurious2[QUOTED] likes this.
  3. Jul 4, 2021 at 10:58 PM
    #2203
    6 gearT444E
    Deep South
    Herculiner Hootus
    The only difference between and ADD and non ADD taco is the ring gear and front driveshaft. That’s not terribly much weight in the grand scheme of front end components. The difference if we had manual hubs might be noticeable but with live axles and spinning spider gears the delta between an ADD and non ADD setup is negligible IMO
  4. Jul 5, 2021 at 12:16 AM
    #2204
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Did you solder those connections?
    llamasmurf[QUOTED] likes this.
  5. Jul 5, 2021 at 5:30 AM
    #2205
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Yep! All connections were soldered, not by me, but @TjAeCeOpMAmiah did solder em all. :thumbsup:
    All working perfect so far :bananadance:
    Key-Rei[QUOTED] likes this.
  6. Jul 5, 2021 at 5:36 AM
    #2206
    xweslingx
    Wes
    Durham, NC
    I would agree as well. Only thing I would say and it was mainly for my own peace of mind is that I changed my gear oil to the front diff slightly more frequently. I never found that it was getting thinner more frequently due to the increased use though.
  7. Jul 5, 2021 at 5:46 AM
    #2207
    Key-Rei
    Key
    Florida
    An particularly reason why soldering vs the typical spade connectors?
  8. Jul 5, 2021 at 5:59 AM
    #2208
    llamasmurf
    Wes
    Northern Ontario
    Lack of connectors.
    Abundance of soldering supplies.
    :cookiemonster:
    If any problems show up, it will get re-done with the connectors.
  9. Jul 5, 2021 at 6:01 AM
    #2209
    Key-Rei
    Key
    Florida
    That makes sense lol.
    Was wondering if it was for a reliability concern but I can argue for either method.
  10. Jul 5, 2021 at 9:44 AM
    #2210
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    For reliability, my preference is to solder. I have had crimp connections pull apart many times because of a bad crimp. I have never had a solder connection connection come apart. If I need to do a spade, ring, or prong connector, I usually crimp, solder, and heat shrink them.
    6 gearT444E and llamasmurf like this.
  11. Jul 5, 2021 at 10:31 AM
    #2211
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    just all the busy-ness of thxgiving, xmas and new years..
    6 gearT444E[QUOTED] likes this.
  12. Jul 5, 2021 at 10:34 AM
    #2212
    6 gearT444E
    Deep South
    Herculiner Hootus
    they should just combine all those holidays and give a month off stretch.
    rheath08 and fatfurious2[QUOTED] like this.
  13. Jul 5, 2021 at 10:37 AM
    #2213
    fatfurious2
    David
    Ashburn, VA
    I agree. That would be awesome!
    hopefully you can help me with installing it? Ill reach out :fingerscrossed:
  14. Jul 9, 2021 at 6:33 AM
    #2214
    llamasmurf
    Wes
    Northern Ontario
    So I went a little crazy trying to figure out how to fix my shifting problem.
    Being that when in 4lo I can not shift into Park on the transmission shifter. Twin stick issue.
    The large Toyota stock shifter knob thing is to big.
    Bought these.
    The rod in the junior length, as I just need it up a bit from stock.
    https://ca.wearelikewise.com/collections/extensions/products/the-rod-stewart
    Then the knob to go on top, round and black just like the twin sticks. Should look pretty sick and fix my problem.:cookiemonster:
    https://ca.wearelikewise.com/collections/shifters/products/the-nad
    https://ca.wearelikewise.com/collections/adapters/products/disco-biscuits
    Also the adapter to get them to fit the stock tiny shift rod. M8x1.25mm
    :bananadance:
    BassAckwards likes this.
  15. Jul 9, 2021 at 6:39 AM
    #2215
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Modelled on the Dalai Lama’s left testicle, :eek:
    Hey Dalai, Dalai, hold still just a little longer, No we're not doing the right side too we just need the left, I know the right is bigger but its for the automatic shifters, we can use the left for the manuals.. No worries Dalai, just remember everytime someone shifts you'll feel it... :D
    rheath08 and llamasmurf like this.
  16. Jul 9, 2021 at 6:42 AM
    #2216
    llamasmurf
    Wes
    Northern Ontario
    One of the other shift levers is called 'The Finger Banger'
    Great company imo.
    :rofl:
    fatfurious2 likes this.
  17. Jul 9, 2021 at 1:41 PM
    #2217
    llamasmurf
    Wes
    Northern Ontario
    Fixed!@
    Windigo and fatfurious2 like this.
  18. Jul 11, 2021 at 10:07 AM
    #2218
    jawmes
    jawmes Well-Known Member
    James
    Kauai, Hawaii
    2007 Tacoma 4x4 PreRunner
    FJ case came without the shifter or the base plate:bananadead:
    if anyone has a spare they’d like to sell let me know!
    tacoma16 likes this.
  19. Jul 14, 2021 at 5:02 PM
    #2219
    fatfurious2
    David
    Ashburn, VA
    twin sticks time
    llamasmurf likes this.
  20. Jul 14, 2021 at 5:03 PM
    #2220
    fatfurious2
    David
    Ashburn, VA
    my tcase shipped today. Supposed to come tomorrow. Then it sits
    whatstcp, rheath08 and llamasmurf like this.
