Let's see your FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO828, Oct 11, 2016.
  1. Aug 8, 2021 at 8:41 PM
    #2281
    Rames
    Rames Well-Known Member
    James
    Oakland, CA
    OME 3" lift, BAMF sliders, Demello front bumper
  2. Aug 8, 2021 at 9:18 PM
    #2282
    6 gearT444E
    Deep South
    Herculiner Hootus
    Rames[QUOTED] likes this.
  3. Aug 9, 2021 at 12:23 PM
    #2283
    Rames
    James
    Oakland, CA
    Thanks. One more question, in reading the various posts and trying to figure out my solution. It seems there’s a common issue with the ADD actuator in front of the diff. Is that the same that’s referenced in these posts as they are referring to replacing the axel tube for the ADD delete. Or does ADD delete require to lock the fork on the actuator and replace the axel tube?
  4. Aug 9, 2021 at 12:29 PM
    #2284
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It’s users preference what you want to do. If you want to retain ADD benefits and functionality, then you would wire in the switch. But that actuator can fail and you’re left without 4wd.
    The other option is to eliminate ADD. You can swap to an FJ solid tube or just leave the ADD engaged all the time. This is what I did.
    I switched to 4hi and then unplugged the 4wd ecu and did the fj case swap. The ADD is permanently engaged with the option to go back later on and wire in the actuator if I want to.
  5. Aug 9, 2021 at 12:33 PM
    #2285
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    I did the other, deleted ADD, 4WD ECU and put in the FJ solid tube.
    On another note, twin stick is amazing. I never thought 2 lo would a useful thing. It is great. No binding in the front end, but nice and slow on the trails.
    Most used part of the mod so far, I am always in 2 lo on the trails it seems :rolleyes:
    Rames likes this.
  6. Aug 9, 2021 at 12:45 PM
    #2286
    Rames
    James
    Oakland, CA
    thanks the the quick replay. That’s pretty much where I’m at currently, actuator failed. Looking to to FJ swap for manual J shifter. But with the swap (in reading the various posts) there’s still a possibility of failure unless I do the ADD delete. So I’m leaning towards doing the delete as you’ve confirmed my understanding with a failure point.
    EatSleepTacos[QUOTED] likes this.
  7. Aug 9, 2021 at 12:49 PM
    #2287
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Main failure point of the actuator is water seepage. I RTV’d the hell out of it and kept the ADD. My truck’s my daily, wanted to keep it close to factory as possible. If it ever acts up, I know how to fix it in the field and permanently engage it
  8. Aug 9, 2021 at 12:55 PM
    #2288
    Rames
    James
    Oakland, CA
    Yeh totally make sense. I noticed the hose to the actuator was disconnected over the weekend on my truck, I think water might have gotten in thru there. I’ll probably pull it over the weekend to confirm if that’s what caused the failure.
  9. Aug 9, 2021 at 2:56 PM
    #2289
    6 gearT444E
    Deep South
    Herculiner Hootus
    If you have to buy a new actuator to get your 4wd back, I'd just as soon buy the manual tube and forget about it. Buying a new front actuator with an FJ case installed is kind of dumb, I know Randy said he wanted to keep the "benefits" the ADD actuator has to offer but quite honestly I've yet to see any.
    If your current actuator is working, you could just wire the switch in and use it until it breaks (which it eventually will, those things suck)
  10. Aug 9, 2021 at 3:12 PM
    #2290
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Had a question the other day after doing an oil change. Interwebz says the 4wd base takes 5.5qt (with filter) while the prerunner takes 5-5.2(saw both figures), even though they’re both 4.0.
    Granted I always fill/check according to the dip stick, but what have you 4x4 swap guys been seeing when changing oil? I only pulled out about 4 1/4 qts when I drained with the filter. Added ~5.5qts.
    Anyone else notice the difference? Just want to make sure it’s not overfilled.
  11. Aug 9, 2021 at 3:17 PM
    #2291
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I kept my actuator (permanently engaged) solely because it cost me $0 and no time at all vs swapping to an FJ tube. There are benefits to the system, there's no denying that. Slightly less wear and tear on the front end. Whether or not that's worth it to someone comes down to preference. For you and I it's not worth it.
    6 gearT444E[QUOTED] likes this.
  12. Aug 9, 2021 at 3:34 PM
    #2292
    6 gearT444E
    Deep South
    Herculiner Hootus
    I never saw any of those benefits but I believe that's what is advertised. For me, I had to replace it twice because it had failed twice, before I finally replaced with the tube. So for that less wear and tear on the front end it cost me upwards of $600 to be able to keep my 4wd functional. For that price, I could have replaced both CVs and both wheel bearings and probably the front driveshaft ujoints too. But yes, if yours was working I'd do the same, keep it there until you need to replace it.
  13. Aug 9, 2021 at 3:36 PM
    #2293
    6 gearT444E
    Deep South
    Herculiner Hootus
    Maybe they are assuming the 4wd has the towing package which has the oil cooler, that might be the extra 0.3 quarts? I don't think I've ever paid attention to how much I put in as far as quantity, I just check the dipstick. I usually have 6 quarts (a 5 quart and a single 1 quart) ready to go when preparing for the oil change.
  14. Aug 9, 2021 at 5:23 PM
    #2294
    Rames
    James
    Oakland, CA
    yup that’s exactly what’s going thru my mind, either buy new actuator and wire up and still have a point of failure or go FJ with the ADD delete and FJ tube. So my guess is that what ppl meant when they say for the price of a new actuator, you can go manual FJ but will have to do the delete... that delete part was left out. Kinda sorta
  15. Aug 9, 2021 at 6:07 PM
    #2295
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    that’s what I was guessing. Just a random thought when I happened to see it. Had a brain fart when buying oil and googled to double check.
  16. Aug 10, 2021 at 8:29 AM
    #2296
    Rames
    James
    Oakland, CA
    Since I have ARB air locker up front, if completing the ADD delete with FJ tube, would that cause any issues when the locker gets pressurized?
  17. Aug 10, 2021 at 8:47 AM
    #2297
    6 gearT444E
    Deep South
    Herculiner Hootus
    the locker does not pressurize the axle tube.
  18. Aug 10, 2021 at 10:44 AM
    #2298
    Rames
    James
    Oakland, CA
    Thanks for answering my dumbish question.
    probably last question, in researching for the ADD delete and wiring to have the indicator lights on the dash. I saw folks wire directly to the dash and others cut and splice 2 wires from the 4x4 ECU. Both options works I assume? Is there any benefit to either or?
  19. Aug 10, 2021 at 10:54 AM
    #2299
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Bypassing the ecu is for trucks that have 4wd from the factory. Going direct to dash is for people converting from 2wd
  20. Aug 10, 2021 at 12:40 PM
    #2300
    Rames
    James
    Oakland, CA
    ahhh thank you, that makes sense
