Let's see your FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO828, Oct 11, 2016.
  1. Sep 23, 2018 at 1:18 PM
    #241
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    My typo was weird. Your response was more weird.
  2. Sep 23, 2018 at 1:20 PM
    #242
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    I see. Then there's some misinformation on the part of the salvage companies listing the 4Runner cases. Some say they are compatible with several models of 4Runner, like SR5, Limited, and Trail. I'm gonna have to look for listings where they show an actual picture of the part being sold.
  3. Sep 23, 2018 at 1:23 PM
    #243
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Can't help it. That's how I am weird.
  4. Sep 23, 2018 at 1:24 PM
    #244
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Also, since you mention limiteds, my '14 limited 4Runner was full time 4wd, so it had a center diff with a locker. I never took a look at the case tho. An AWD Tacoma would be kinda cool, but you probably have to have to manually wire up switches to get the actuators to function.
    I still need to wire up something to get my E locker to work.
  5. Sep 23, 2018 at 5:41 PM
    #245
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I like the front range off-road twin sticks. Much more solid feeling than Dave’s off-road
  6. Sep 23, 2018 at 5:56 PM
    #246
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Oh ok soo it's kinda like a universal thing for toyotas
  7. Sep 23, 2018 at 6:02 PM
    #247
    wrmathis
    Bonaire, GA
    parts and stuff
    Kinda. The chain cases have a different base than the geared cases. Just look for one that is for a fj case and you should be fine
    Basikbiker[QUOTED] likes this.
  8. Sep 25, 2018 at 12:06 AM
    #248
    Jcapen
    Jcapen Active Member
    2014 Tacoma Dbl Cab 4x4 6sp Man
    Any of you guys having done this and fab'd new shift rods for their fj case out of solid round stock notice the vibrations from the case are sent through the rod and slightly louder in the cab? The stock shifter obviously has the dampener.
  9. Sep 25, 2018 at 12:11 AM
    #249
    6 gearT444E
    Deep South
    Herculiner Hootus
    All the aftermarket shifters for twin sticks are like this there is no rubber dampener; there is no getting around it unless you somehow weld the rod back to the stock shifter (and buy two stock shifters). It does transmit some noise especially if you lean on the stick a little while the truck is in motion you can really feel and hear the gear noise of the truck. It's not much though to be honest, hell my floorboard isn't even 100% sealed yet and it's been that way for 6 or so years. To me, it reminds me of why I did the modification in the first place and I guess if it bothers you, turn up the radio.
    hoverlover and HomerTaco like this.
  10. Sep 25, 2018 at 12:14 AM
    #250
    tacotruck93
    tacotruck93 Well-Known Member
    Zach
    Akron,Ohio
    2012 TACOMA TRD OFF ROAD
    Might be a stupid question but what is the plus side of running the FJ box instead of the stock one that comes in the truck??
  11. Sep 25, 2018 at 12:17 AM
    #251
    6 gearT444E
    Deep South
    Herculiner Hootus
    The engineers theory when designing the electronic case:
    aka the design sucks
  12. Sep 25, 2018 at 12:17 AM
    #252
    Jcapen
    I dont care about the noise one bit, I suppose I just needed reassurance that what I was hearing was infact that and not something else.
    6 gearT444E likes this.
  13. Sep 25, 2018 at 12:20 AM
    #253
    tacotruck93
    Zach
    Akron,Ohio
    :rofl: Can't make everything bullet proof lol. But I agree I think that they tried way to hard to over complicate things when it wasn't broken in the first place and it worked.
  14. Sep 25, 2018 at 12:26 AM
    #254
    6 gearT444E
    Deep South
    Herculiner Hootus
    Yes, it kind of sounds like a mini bench grinder going down the road. I went to a 1 piece driveshaft and got rid of the sound deadening tube as well so any noise from the rear differential comes right up into the t-case sticks.
    Well yes nothing is bullet proof, but the rube goldberg layout of the front differential and t-case shifters is absurd. Just search "4x4 light blinking" or something similar and you'll see thousands of threads popping up with these parts failing; just think how much money toyota has made over the years through that piss poor design.
    You can thank the soccer moms who want the 4x4 switch on the dash and are too lazy to go out and lock some hubs and move a lever like the good old days. I think the ESOF should be an "option" if one wanted it, and the manual shifting should be standard equipment in any truck but I guess that's why I don't work for auto companies because I'd lose them alot of money lol
    tacoma16, hoverlover, vssman and 2 others like this.
  15. Sep 25, 2018 at 12:42 AM
    #255
    tacotruck93
    Zach
    Akron,Ohio
    Right in the end it is all about the money. Like you said it is all to stream line and make it "easy" for the soccer moms out there. I mean at least Toyota still has the gear selector in the middle of the seats while Dodge gear selector is like a damn volume knob. What would it run me to switch if mine ever gave me a problem down the road. I would do all the work myself.
  16. Sep 25, 2018 at 1:37 AM
    #256
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    lol @ rube goldberg:laughing:
    hoverlover likes this.
  17. Sep 25, 2018 at 1:53 AM
    #257
    6 gearT444E
    Deep South
    Herculiner Hootus
    Oh that's the Next mod for the 4th gen taco I'm sure :p
    The swap depends how cheap you can find a transfer case. I got mine on the cheap already twin sticked years ago, nowadays I'd say a decent tcase should be under $500.
  18. Sep 25, 2018 at 1:59 AM
    #258
    tacotruck93
    Zach
    Akron,Ohio
    Awesome that's not that bad at all. So has it been a problem with all the 2nd gen Tacoma's? Or is it certain years or is it just all across the board??
  19. Sep 25, 2018 at 2:06 AM
    #259
    6 gearT444E
    Deep South
    Herculiner Hootus
    No specific years, Seems the trend I see there are two major groups with failures: those who like to go off-roading the actuators get moisture and funk in them and stop working, and those who never use 4wd the dielectric grease they put inside the motors dries up. But it seems no specific year, model, or generation is worse off. The design of them has not changed since 2005
    HomerTaco likes this.
  20. Sep 25, 2018 at 2:12 AM
    #260
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    You don’t sleep anymore do you? :laugh:
    6 gearT444E[QUOTED] likes this.
