Let's see your FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO828, Oct 11, 2016.
  1. Apr 3, 2024 at 1:09 PM
    #2901
    TacoTuesday1
    SD CA
    got an FJ tcase but thing is a bitch to move and store
    how hard are these to find? Is it better to just keep it rather than offload need to find again later
    want to reduce messing with the truck but it really should have a manual stick and ADD failure is expensive and unpredictable
    having flashbacks to finding things in junkyard for another part. Wrong part, half the shit missing, “mechanic” with a hammer looking to pull a valve cover for you by sawzalling it in half
    Driving far to yards walking around them all day for 50/50 hit or miss
    Probably hang onto it for that reason
  2. Apr 3, 2024 at 1:11 PM
    #2902
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Carry it around in your rooftop box?
  3. Apr 3, 2024 at 1:13 PM
    #2903
    TacoTuesday1
    SD CA
    I’ll see if it fits in a big strong bucket that would be convenient. Throw any bolts that I suspect may have come from it in there with it, label and close the lid
    leave it for another day figure everything else out like acquire ADD delete tube parts, twin stick, etc
  4. Apr 3, 2024 at 3:22 PM
    #2904
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Keep it unless you don't plan on doing the swap. Prices are only going up
    TacoTuesday1[QUOTED] likes this.
  5. Apr 3, 2024 at 6:51 PM
    #2905
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    If this is truly a mod you want to do, it'd be kinda silly to sell it now that you have it. You've got the one of the bigger obstacles out of the way with it in your possession. Keep collecting the rest of the little shit you need. The small harbor freight furniture dollies work well for moving it around the shop floor.
    If you don't have a trans jack, I'd recommend you invest in one. I used the white / orange pittsburgh scissor jack from HF the first time around, but it was definitely a challenge to get the the case perfectly aligned and sitting properly. I was trying to balance it on scraps of wood and large sockets, and it'd slip as soon as I got it aligned. I'd encourage you to spend the few extra bucks on the gray, hydraulic trans jack, which has some tilt adjustment. They go on sale for $180 regularly.
  6. Apr 3, 2024 at 8:25 PM
    #2906
    TacoTuesday1
    SD CA
    makes sense
    Used a trans jack before, has front and sideways level adjuster handles
    which the sideways one provides rotation
    surprised that was needed and not possible other way by hand, to just benchpress it in there or something and rotate as needed, like off the center with bolts slightly loose all around.
  7. Apr 3, 2024 at 8:25 PM
    #2907
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    I also used that thing, one of the sketchiest experiences of my life good god.
  8. Apr 3, 2024 at 9:52 PM
    #2908
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    I just bench press it on or off. Sure a trans jack would make life easier but I've lived without one so far lol
  9. Apr 3, 2024 at 11:07 PM
    #2909
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    I removed my stock tcase and test fitted my crawl box the old fashioned way, and bought the scissor jack for the final install after deciding my face was too pretty to smash. Yea, it absolutely can be done benchpressing, but its one of those things where having the right tools makes the job go a lot smoother.
    bhigbee likes this.
  10. Apr 3, 2024 at 11:23 PM
    #2910
    TacoTuesday1
    SD CA
    Roger that
    Maybe cheaper adapter or home made
    honestly rarely actually benchpress parts
    More of whatever body part works, like support with legs if that works better
    but yes like you said would not be good for it to fall on face, thing is big and heavy.
    And from what it sounds like more sensitive to getting the right angle than stabbing a trans back in that simply has to line up with the bolts and through the clutch.
  11. Apr 3, 2024 at 11:27 PM
    #2911
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Imo stabbing the case is easier than the trans....but then again I've gone up and down with case more in 2 days than I have with the trans during entire ownership.
  12. Apr 10, 2024 at 5:01 PM
    #2912
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    I found the culprit of the smell, the black rtv had a hole in it from where I sealed up the shifter coming through the boot. Got high temp heat and made sure it was covered hopefully that takes care of the gear oil smell!!:anonymous:
  13. Apr 12, 2024 at 10:53 AM
    #2913
    Alex3420
    Alex3420 New Member
    Alex
    2017 TRD
    Anyone done this on a 2wd 3rd gen?? I already have an AC60F trans but going with 1ton axles instead of the stock front setup. All I would need is the FJ tcase and then wire it up correct?
    tacoma16 likes this.
  14. Apr 14, 2024 at 1:05 PM
    #2914
    gtrotter07
    gtrotter07 Well-Known Member
    2007 Tacoma reg cab 4x4 on 37's; 2021 TRD Offroad, 6 speed
    37's,lockers, bumpers, bobbed etc.
    Anyone know the torque specs for the 12 mm bolts from t case to trans?
  15. Apr 14, 2024 at 1:11 PM
    #2915
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    18 ft lbs. I just snug em up
  16. Apr 14, 2024 at 2:27 PM
    #2916
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Yeah it's a hell of a lot less than you'd think it's kinda suspect how easy it was lol
    Strictlytoyz[QUOTED] likes this.
  17. Apr 15, 2024 at 6:13 PM
    #2917
    DiseasedAliens
    DiseasedAliens Member
    Daniel
    2014 Tacoma TRD Sport Blue
    https://www.youtube.com/watch?v=HX3PE_anrD4
    Ricardo13x likes this.
  18. Apr 15, 2024 at 6:30 PM
    #2918
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Fj transfer case does not require wiring to work. The case has 3 switches(those are the 6 wires coming out of it, 2 for 4h switch, 2 for N switch and 2 for 4L switch) that connect path to ground for the 4x4 ecu to do his thing and for the lights on the dash.
  19. Apr 19, 2024 at 1:54 PM
    #2919
    Adventure4x4
    Adventure4x4 Well-Known Member
    Adam
    San Antonio, TX
    2013 TRD off road MT
  20. Apr 21, 2024 at 11:18 AM
    #2920
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Yeah I still can't get the damn gear oil smell out. I'm going to have to sacrifice a Saturday and tear everything out and start again. Flex tape and rtv but it's still coming through. Not sure if I spilled some somewhere like it's just sitting somewhere I can't see lol
