Let's see your FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO828, Oct 11, 2016.
  1. Jul 31, 2024 at 9:21 PM
    #2961
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Nope, I didn’t do the wiring and I would guess it’s different on a 3rd gen than a 2011 anyways.
  2. Jul 31, 2024 at 9:41 PM
    #2962
    FranksGotTacos
    FranksGotTacos donkey
    SB
    Denver
    16 DCSB. Geared, Dual Locked, 35s, Topperlift, wet AF
    5.29 gears, ARB locked, Lil Bs front bumper, Hooligan sliders and roof rack, cab and bed cap, Outgear solutions rear bumper, custom swingout. 35's. Icon rebound pros x 5, OME BP-51s. Topper ez lift. Decked. Full RCI full skids, misting system with 4 gal plumbed into 270 ironman awning, air plumbed to all 4 corners + decked, DK upper shear kit, Marlin LCA brace kit, 10 pc rock light kit, scene pods, u bolt flip, stage 3 deavers, poly bushings all around, archive garage hammer hangars, sumo springs rears, TC gusseted spindles, spiker hood struts, aux beam 8 gang, 50 watt solar on top of 2x pelican cases, Cascadia 4x4 mppt solar charge controller, jackery 1000, alpicool 45L fridge. Rear seat delete with fridge slide on passenger side (by me). Meso overhead rack, Meso cab, dome, rear interior lights, Meso x morrimoto tail lights. CVJ high angle boots,
    No worries. Thanks for getting back to me. I will keep trying to figure it out and if I do, I will make a post. Great builds ya got there
  3. Aug 12, 2024 at 4:49 PM
    #2963
    Toyotamudbogs
    Toyotamudbogs Well-Known Member
    Devin
    White Springs , FL
    06 Tacoma 4x4, 4 door sr5
    Tintedwindows,Rockforfosgate amp 2 10" sub , fire dept radio,Rock sliders, Body Armer front Bumper, CB, 3'' EZ leveling kit, fog light mod, beep on lock mod, front duallys rigid led lights, rigid led flasher kit
    Did you keep your add? If so how do I find the directions to wire up the switch?
  4. Aug 12, 2024 at 5:03 PM
    #2964
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    It is posted multiple times in this thread.
  5. Aug 14, 2024 at 7:11 AM
    #2965
    AlHago
    AlHago Well-Known Member
    Alan
    Huntsville, AL
    12 DCLB MGM
    Stock as all get out.
    Getting ready to tackle wiring a switch for the ADD and was set on having the switch under the radio and climate control but it requires a "mini" style switch and those seem hard to come by in a DPDT configuration. Luckily I stumbled upon this Australian custom switch company that makes a DPDT in a mini switch with custom text offerings. Im OCD and like a very OEM look in the cockpit.
    https://au.lightforce.com/collections/custom-switches
    https://ch4x4.com/product/ch4x4-custom-laser-etched-small-dual-push-switches-for-toyota/
    DoulosXP and DesertRatliff like this.
  6. Aug 14, 2024 at 12:32 PM
    #2966
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    2nd gen Black Tacoma SS 4.0l 4-dr 4x4
    1" Toytec body-lift, K&N filter, coolant by-pass, mesh cotton screen delete, TTBS, WeatherTech in channel visors, 2.5" Rancho full suspension kit, Oil Catch Can, Toyo 285/70 A/T-2's, 21.5" light bar in grill, blacked-out grill, de-badged entire truck; and again, more to come.....
    Question on the Front Range Twins; can you separate the sticks from the base?? Can the breather also be taken apart to add a hose or something to extend elsewhere?? Things are moving quicker than expected and I'm just trying to prepare... Thanks FJ swap fam, and all others..
  7. Aug 14, 2024 at 12:55 PM
    #2967
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Yes to both questions.
    Some stainless hardware and a main pin that you can punch out holds everything together so it can be easily separated to modify the sticks.
    The breather that comes with it is 1/8NPT thread so I just bought a 1/8" brass hose barb with 1/8NPT and connected a longer breather routed to my engine bay.
  8. Aug 14, 2024 at 8:06 PM
    #2968
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    Desertratliff; bad ass and thanks again!! TW is full BeastMode for mods, and smart wrench turning people!!! Thank you sir!! Will do both!! Thanks!!!!
  9. Aug 19, 2024 at 12:24 AM
    #2969
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    Question; I've got the 4wd light on with 4lo blinking (2013 FJ case swap), is this because I failed to do the ADD delete or wire up???
    My harness from 12thstate should he in tomorrow?? Please tell me this wold fix his issue.
    Note: I did already wire the case plugs to their respected wires. Thanks for any help.
  10. Aug 19, 2024 at 6:31 AM
    #2970
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    If you're waiting on your harness, it doesn't sound like you've done any wiring to your 4x4 ECU and/or the ADD system, right? If that's the case, the Tacoma 4x4 ECU is coding due to the lack of a transfer case solenoid and the harness should fix the issue.
  11. Aug 19, 2024 at 8:10 AM
    #2971
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    Correct. Nothing to the ECU, only the 4wd plugs on the case. I wasn't sure if the harness would use the same wires from the ECU??
    So even without the harness, I've still gotta get the 4 wires from the ECU connected and follow; of course with the harness??
    Thanks for all your help, bro. Where this would normally a wrencher, and a helper, man it's just me, Han "SOLO"!!! Thanks again. It's been my worst mod yet, but the finished product should be well worth it???
    DesertRatliff likes this.
  12. Aug 19, 2024 at 8:40 AM
    #2972
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    What is this harness? Does someone make something to plug in for this?
  13. Aug 19, 2024 at 8:42 AM
    #2973
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    The 4x4 ECU wiring is easy. Here's a repost of this image if you haven't already seen it.
  14. Aug 19, 2024 at 8:43 AM
    #2974
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Littles and fatfurious2[QUOTED] like this.
  15. Aug 19, 2024 at 8:46 AM
    #2975
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    12thstateoffroad I believe is one of the companies that makes a harness for the ADD.
    I think the harness allows you to keep the actuator, and rid the factory electronics, I believe, to work with the FJ case and dash lights.
    fatfurious2 likes this.
  16. Aug 19, 2024 at 8:49 AM
    #2976
    fatfurious2
    David
    Ashburn, VA
    Wow, thanks for the link. Thats what Id want
  17. Aug 19, 2024 at 8:50 AM
    #2977
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
  18. Aug 19, 2024 at 9:00 AM
    #2978
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Easy enough to make one but the plug and play is nice
    reallifedog and Littles like this.
  19. Aug 19, 2024 at 9:07 AM
    #2979
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    My thoughts exactly. I've never been shy when it comes to wiring and it's probably less than $50 in switches and wire, so I'd lean towards making my own, but at the same time, $130 seems pretty reasonable. It'd take me at least 2 hours to measure, cut, solder and all that, and while the streets may say differently, I'd like to think I'm worth $40-50 an hour.
    DesertRatliff[QUOTED] likes this.
  20. Aug 19, 2024 at 9:11 AM
    #2980
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Not everybody factors their time in like this so I agree with you. $130 seems reasonable. I think I had 2 hours in just finding the switch I wanted!
    Littles[QUOTED] likes this.
